    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
      slimaczysko
      THX my friend ! Perfect tool ! I use it to many project ! THX AGAIN πŸ˜„
      Some of my works and photos... http://slimaczysko.digart.pl/digarty/
        jorge2011
        I have a small problem with a geometry.
        The sides of the circle does not coincide.
        Is this normal? It is possible to fix it?
        regards
          jorge2011
          image correction
          http://forums.sketchucation.com/download/file.php?mode=view&id=71839
          • fredo6F Offline
            @jorge2011 said:
            image correction
            Jorge
            I don't see the image
              jorge2011
              see the file
              01.skp
              • fredo6F Offline
                Jorge,
                When you draw the circle, try to align the radius on the existing grand arc of the sphere.
                But anyway TOS will not consider your sphere in any specific way as it expects to work on any kind of surface.
                  You're still not seeing the animated screenshot? He is in fact aligning and snapping to the arc of the sphere.
                  • fredo6F Offline
                    ToolsOnSurface is only an approximation tool.
                    In this precise case, the sum of angles at the pole of the sphere is slightly under 360 degrees, whereas TOS generates circles on a base of 360 degree total, as if it was drawing on a plane.
                    This explains the slight discrepancy for segments generated.
                    Unfortunately, as mentioned, TOS does not make assumptions on particular situations like this one.
                      jorge2011
                      Mr. Fred thanks for the reply.
                      Just a clarification.
                      If I make a flat circle and the sphere 3d project, the sides if they match.
                      The problem with TOS tool is that the edges are not equal.
                      to fix, I can draw with sketchup tools and project the circle or use the tool offset of TOS.
                      greetings and thank you very much:
                      • dereiD Offline
                        derei
                        strange Pie on curved surface... in certain points (very sensitive) it draws OK, but if I move a little from that points, it does that 😲 or similar.
                        My directory is TOS_Dir_18, but when I looked inside ZLoader__OnSurface.rb, last update is 20 Jul 2009 - version 1.5
                        Thanks for paying attention.
                        EDIT
                        It might be useful if you could add a Text On Surface feature, I don't know how hard it would be, or if even possible, but I'm thinking to a inputbox for text and a list for font, then that text to be drawn on surface. Not 3d, like Sketchup text, but lines, like geometric shapes on surface.
                        Even nicer would be some kind of Copy/Paste. To copy lines of a custom plain shape, then paste them on curved surface. In this manner, each vertex position would be recalculated to fold on surface, much better than intersection of a extruded geometry with the curved face.
                        DESIGNER AND ARTIST DEREI.UK
                        • dereiD Offline
                          derei
                          I have a problem with Arc tool. The number of segments is set fo 360degrees, so for half circle, I should have half number of segments.
                          I needed an arc with 7 seg, so I set 14seg/360. Instead I got a 6seg arc. See the image. is this any bug, or you wanted the tool to behave this way?
                          Thank you.
                            bluegravy
                            Fredo6,
                            I have been trying to download this very useful tool but have been having some problems. Followed you instructions to the letter but nothing appears in the Tools menu.
                            I loaded your Libfred06 first.
                            I just noticed that this is compatible with version 6 and 7, my version 8 is probably the problem?
                            Peter
                              Tools on Surface is also compatible with version 8 of SketchUp.
                              We've had others who have had a difficult time getting plugins installed on Lion. Would you post a screen shot of your Finder to show the contents of the Plugins folder? That will help to identify possible install problems.
                                jeffbrad
                                Hi. I am having big problems downloading the latest Library. It keeps on saying it's corrupt and wont progress any further. Is there a known problem with it. Is it possible to get an earlier version as I have had no problems with downloading the TOS files and other stuff from the site?
                                Regards and many thanks for you excellent work
                                Jeff
                                  jeffbrad
                                  Ok, I need to post an update to my problem this morning. Trying to Download the Library having no success. All I got was the 'corrupt file' message coming up. I searched the forum and saw a reference to issues with Google Chrome and so switched to Internet Explorer....hey presto...problem solved and downloaded perfectly? So I was extatic that was going to be able to carry on with my project to model a Chinese Guzheng musical instrument...Well, it didn't finish there. I am using the free version of Sketchup 8 and even though the files all installed ok, nothing would work. The tool bars were there and I could click the buttons, but nothing would actually happen. So I switched to the Sketchup 7 installation and installed the same files there....and Perfect. Everything works and no problems at all. So firstly,,,Why do I have problems with Chrome when the Sketchup software is a Google product! And secondly, how come the Tools on surface and Library won't work on my version 8? I only have a short time left on the Version 7 installation before it does something like locking it, so need to sort this out soon...Any suggestions??
                                  Regards
                                  Jeff
                                  • fredo6F Offline
                                    Regards
                                    Jeff
                                    Can you turn the Ruby Console on and check if there is any message when you launch a Tool on Surface tool.
                                      jeffbrad
                                      Hi Fredo. Just cuta % Pasted what happens in the Ruby Window. The same no matter what I click on....
                                      Error: #<NoMethodError: undefined method +' for nil:NilClass> C:/Program Files/Google/Google SketchUp 8/Plugins/MatchboxPlugin/Population.rb:174:in +'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_42/Lib6Config.rb:148:in selected_folders' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_42/Lib6Plugin.rb:402:in picture_selected_folders'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_42/Lib6Plugin.rb:1020:in create_cursor' C:/Program Files/Google/Google SketchUp 8/Plugins/TOS_Dir_18/ShapeOnSurface.rb:714:in get_id_cursor'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/TOS_Dir_18/ShapeOnSurface.rb:69:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/TOS_Dir_18/ShapeOnSurface.rb:47:in new'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/TOS_Dir_18/ShapeOnSurface.rb:47:in launch_shape' C:/Program Files/Google/Google SketchUp 8/Plugins/TOS_Dir_18/PaletteOnSurface.rb:100:in action__mapping'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_42/Lib6Plugin.rb:131:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_42/Lib6Plugin.rb:131:in launch_action'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/TOS_Dir_18/bootstrap_OnSurface.rb:313:in launch_action' C:/Program Files/Google/Google SketchUp 8/Plugins/TOS_Dir_18/bootstrap_OnSurface.rb:374:in declare_command_shapes'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_42/Lib6Plugin.rb:919:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_42/Lib6Plugin.rb:919:in command_invoke'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_42/Lib6Plugin.rb:901:in build_config_commands' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_42/Lib6Traductor.rb:948:in call'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_42/Lib6Traductor.rb:948:in add_command' C:/Program Files/Google/Google SketchUp 8/Plugins/MatchboxPlugin/Population.rb:174:in call'
                                      Hope this helps to fault find...Many thanks in advance
                                      Jeff
                                        Please remove the 'Matchbox' plugin from the folder - it is known to cause several issues, as it ill-advisedly overwrites some standard methods! πŸ˜’
                                        Retry and publish any error messages if it recurs... πŸ˜•
                                          jeffbrad
                                          Awesome....That did the trick. Thank you so much for sorting this out. It is very much appreciated. Just got to sort out the menu madness now...funny, sure everyone does the same when they get started...download everything to see what they do and end up with so many menu items that you don't know what's where and what does what. Great fun though!
                                          Regards
                                          Jeff
                                          • E Offline
                                            Elora
                                            FAIRLY NEW USER, can anyone help. I have installed ([Plugin] Joint Push Pull - v2.0b - 17 Jul 11), and (LibFredo6 4.3c - 31 Jan 12) as instructed to (On Mac the SU plugin directory should be:
                                            Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins). I am having difficulty locating the toolbar. It is not under TOOLS>fredo6collection>toolsonsurface.
                                            Any suggestions where else to look for these cool tools.
                                            Mac os 10.6.8 goole sketchup pro8
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 31
                                            • 32
                                            • 12 / 32
