    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 317.9k Views 41 Watching
    • jolranJ
      jolran
      Spacing should be working now! Ver 1.1 added(in first post)
      Thanks KYYU!
      • jolranJ
        jolran
        The thing about curved surfaces in Sketchup is.. They consist of a bunch of lines!
        Look at the half cylinder in revealed hidden lines, one see how the cylinder is made out
        of edges. When running the plugin, even if the lines are hidden they will get detected,
        with following result.
        For NOW! A temporary fix for faces with holes (until I have included TIG's solution)
        is to create a temporary edge across the face(before running the plugin). It will need to be deleted in both the hatches and on the face...
        Alignment is still a little problematic. When running 2 faces next to each other(2 separate times) one would expect the lines to get aligned to each other, where the vertices meet.
        In my original idea the grouped edges where copied FROM center outwards 1 time in each direction, so maybe try to implement that behavior in this version too if possible.
        • atelierpaarA
          atelierpaar
          great plugin, that`s what we needed !
          While creating the hatching, the tool also creates an surrounding outline.
          Do you think, it would be possible to have a choice to hide or show this outline.
          thanks for the great work πŸ˜„
          Uli
          • K
            kyyu
            @jolran said:
            Guys, I'm glad youre showing interrest in this plugin! I will try to do by best to improve it.
            About Autocad compability.. You have to realize, 2 months ago I had no programming experience att all and
            that feature sounds fairly complex. I think priority must be made to get spacing OK, and holes get filled.
            You're doing good for 2 months. I started the same way, with no programming experience, about 1 & half years now. I still have alot to learn. Takes alot of time at our level, to do even simple stuff.
            file_loaded("Hatchfaces.rb")
            Hmmm, thought I did not need that. It's not loading right for you?
            Concerning this line of code. It put's your plugin in a list of loaded files. That's the list your are checking when you say "unless file_loaded?("Hatchfaces.rb")". So if you don't have the loaded line, then there is no reason to check if the file has been loaded in the 1st place.
            I thought Sketchup would give me a 2nd toolbar, if I loaded the plugin again. But it appears not. Maybe Sketchup won't let you have two toolbars with the same name? So I guess it didn't matter,after all, for your plugin. But, like I mentioned, then you could have left out the 1st line, also. Where it matters, is menu items. Sketchup will add a new menu item each time you reload a plugin, if you don't have those 2 lines.
            And as a fyi, these two methods are in the "sketchup.rb" file. That's probably why you have the line at the very beginning: "require 'sketchup.rb'"
            -Kwok
            • jolranJ
              jolran
              Thanks KYYU πŸ˜„
              And thank you for that explanation. You are most helpful!
              • sadyoS
                sadyo
                Thanks Jolran, it's really awesome plugin
                Then... AutoCAD would be far away now
                • jolranJ
                  jolran
                  Hi Atelerpaar!
                  I did not think of that until you mentioned it now. Good suggestion πŸ‘ That would be the behaivior one would expect. Also files would get smaller. I will try my best πŸ˜„
                  I have an new idea for getting different patterns. 2d DCs with intersection. Don't know if it is possible, have to do some research. But then a library of concrete and such could be made with a webdialog and thumbnails. Needles to say, quite a project..
                  Any interest in that? Or are textures already sufficient as they are for that purpose?
                  (my personal feeling is that textures get ugly in Layout unless perfectly scaled, Richards masking-method works ok, but is not 100% flexible)
                  • jolranJ
                    jolran
                    Been at it all morning. Seems not that easy to erase surrounding edges as I thought.
                    Outer edges are most possible, but I suspect you just want the hatched (eg45 deg or so) lines remained? Probably missing something in my code..
                    Damn right about that 😠 πŸ˜„
                    But you are far ahead of me in Ruby-knowledge 😳
                    Cheers Sadyo
                    I guess this thread is supposed to be about updates and wishes? So won't discuss too much code in here.
                      Do you mean erase the surround edges to the hatching ?
                      To do that you need to examine the hatching group's geometry before your code to finally erase all faces.
                      Make an empty array
                      edges2go=[]
                      then iterate the geometry
                      group.entities.each{|e|edges2go << if e.class==Sketchup::Edge and not e.faces[1]}
                      i.e. 'edges2go' is now a list of all edges in the hatching group that are on the 'perimeter' - i.e. they have only one face. We will now erase them - this will destroy their faces too so you probably never need to erase the group's faces as there won't be any left!
                      group.entities.erase_entities(edges2go)
                      All perimeter edges are erased en mass. πŸ˜„
                      How are you getting on with the 'holes' issue ❓
                      • jolranJ
                        jolran
                        He he! I can't make this work. I wish it was as simple for me as it is for you 😳
                        By that you mean after the intersection and before the erasing?
                        The "hole" issue is putting a hole in my brain.
                          The two relevant lines in the code
                          gents.to_a.each{|e|e.erase! if e.valid? and e.class==Sketchup::Edge and e.faces.length==0} gents.to_a.each{|e|e.erase! if e.valid? and e.class==Sketchup::Face}
                          The first line removes any unfaced edges.
                          The second removes all faces.
                          What you need to do between them is add these lines
                          edges2go=[] gents.each{|e|edges2go << if e.class==Sketchup::Edge and not e.faces[1]} gents.erase_entities(edges2go)
                          This will remove perimeter edges and thereby all faces anyway... So after a test you should find the original second line to erase all faces is no longer needed...
                          πŸ€“
                          • jolranJ
                            jolran
                            Ver 1.2 zip added at first post.
                            • jolranJ
                              jolran
                              Yeeyy!!! It works now!
                              I had to think a little bit πŸ˜„ Where some typos(I hope I did not destroy anything ❓ )
                              Anyway it works. Will post update soon..
                              gents.to_a.each{|e|e.erase! if e.valid? and e.class==Sketchup;;Edge and e.faces.length==0}
                                    edges2go=[]
                                    gents.each{|e|edges2go << e if e.class==Sketchup;;Edge and not e.faces[1]}
                              Thanks to TIG this plugin gets updated once more πŸ˜„
                                sergey2402
                                Well done! You are doing greatly desired work!
                                I really, really like it.
                                • jolranJ
                                  jolran
                                  Why thank you 😳 But I really think you should thank TIG and Kyuu.
                                  Feel free to ask for ways to improve! Or even come up with ideas πŸ‘
                                  • kenK
                                    ken
                                    Well, this is starting to look good. My suggested improvement
                                    1. If you do two hatches of the same face, is it possible to get both hatches in the same group.
                                    Thank you for your work
                                    Ken
                                      sergey2402
                                      Maybe hatches should be on its own layer?
                                      • jolranJ
                                        jolran
                                        Thank you for your input guys!! Good points!
                                        I will answer more profound tomorrow. I'm a bit in a hurry! For Now, here is a minitut or tips, as a compensation that the hole "issue" isent fixed yet. πŸ˜‰
                                          sergey2402
                                          TIG, kyyu, please do not leave jolran alone. You are all together make a very necessary work.
                                            We are helping him... [sometimes in the background πŸ˜‰ ] πŸ˜„
                                            • 17
                                            • 18
                                            • 1 / 18
