    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.7k Views 172 Watching
    • L
      lapx
      Vidy , yes! Thank you! Change the default values of the Spread from "0" to "1" and it works like a charm.
      • L
        lapx
        Spoke to soon. Was working fine. Now it's back to its old bad behavoir 😞 Shift click to make leafs is where I end up with a problem. It appears to make several duplicate copies of just 1 ivy branch and thats it. Leaves are not drawn. What can be going wrong? Using SU 804811.
        Thanks,
        • G
          gianpier1
          HI Boys.
          I have a problem. I can´t never see the leafs!!!!!
          Help me please! 🎉
          • G
            gianpier1
            Hello guys again!!!
            I can not see how the leaves are drawn? 😲 😲
            I don´t understand it!!!
            • romboutR
              rombout
              @gianpier1 said:
              Hello guys again!!!
              all depends on which version of SU you use...
              try searching this forum post for updates and working version! for me a custom revised version 6.05 something does the job... try to look for it!
              • G
                gianpier1
                i´m using ivy 0.6.3 to SU 8.0. but i didn´t find ivy 0.6.5. Neve i can´t see the leafs man
                not understand because the leaves do not work when I press SHIFT, the vines are also up.
                Thanks man
                • L
                  lapx
                  For me its sometime works and sometimes not. Cant put my finger on it. Mostly stops working when using shift click. If it means anything, I can see the google and standard tool bar ghosting when I hit shift click 😕 using ivy 0.6.3
                  • L
                    lapx
                    Any developement? This is such a wonderful program to let go. Does anyone have it working consistently in sketchup 8?
                    Shift click seams to be the problem. Its not making the leaves.
                    • L
                      lapx
                      Anyone else have consistent success with the plugin? Might it be in conflict with other scripts?
                      Would love to use it on this current project...
                      http://forums.sketchucation.com/viewtopic.php?f=333&t=38590
                      • V
                        vidy
                        still working at mine, i know i dont make it so dense.. but still work... 😉
                        here is the screen shot
                        still so much to learn..
                        • P
                          penniner
                          cool !
                          • L
                            lapx
                            Its working now. If I can just find out why its not working in some cases. The only thing done differently that I can think of is shutting down the computer and reactitvating sketchup_ivy.
                            • N
                              niks
                              hi.. i've used both Ivy version 0.6 and .5, its working if im on a new scene but once i usethe plugin on my saved sketchup model it does not work. im using sketchup v.8 pro,windows....here's the result of the plugin when i apply it to my saved file. when i shift-click, it only add a single black vine line.. i also tried different suggestion posted on this thread but no luck.
                              • C
                                carmelo
                                hi...
                                i have this problem: "Errore di caricamento del file LiveIvy.rb
                                no such file to load -- LiveIvy/LiveVector_core"
                                Why?
                                tanks
                                  hi...
                                  Why?
                                  tanks
                                  When you extract the files/folders from SketchupIvy.0.6.3.beta.rar you should have a file called LiveIvy.rb and a folder called LiveIvy [which contains several files and sub-folders].
                                  Put the LiveIvy.rb file and the LiveIvy folder into the Plugins folder.
                                  Do NOT move files from the LiveIvy sub-folder into the Plugins folder - if you have done that, then move them - it will probably break otherwise.
                                  This is what should be in this LiveIvy sub-folder... Capture.PNG IT: Quando si estraggono i file/cartelle da SketchupIvy.0.6.3.beta.rar si dovrebbe avere un file chiamato LiveIvy.rb e una cartella chiamata LiveIvy [che contiene diversi file e sottocartelle].
                                  Inserire il file LiveIvy.rb e la cartella LiveIvy nella cartella Plugins.
                                  NON spostare i file dal LiveIvy sottocartella nella cartella Plugins - se avete fatto questo, poi spostarli - sarà probabilmente rompere il contrario.
                                  Questo è ciò che dovrebbe essere in questo LiveIvy sottocartella...
                                  • C
                                    carmelo
                                    tanks for reply.
                                    there is another problem:
                                    can't convert nil into String
                                      Have you done ALL of the fixes that I suggested?
                                      The error message is incomplete.
                                      Can you post the full message...
                                      Hai fatto TUTTE le correzioni che ho suggerito?
                                      Il messaggio di errore è incompleto.
                                      Puoi inviare il messaggio completo...
                                      It may be that that you have to enter values into all dialog boxes - even if '0'...
                                      Può essere che che è necessario inserire i valori in tutte le finestre di dialogo - anche se '0'...
                                      • C
                                        carmelo
                                        yes, I followed your instructions. The attached images show the folders located.
                                        The error message comes up when the program starts.
                                        Also, when I start the script, the window does not shows me any command.
                                          Please open the file LiveIvy.rb with 'Notepad.exe' and see what it says.
                                          It should have these lines
                                          require "LiveIvy/LiveVector_core"
                                          require "LiveIvy/LiveIvy_branch"
                                          require "LiveIvy/LiveIvy_node"
                                          require "LiveIvy/LiveIvy_leaf"
                                          require "LiveIvy/LiveIvy_tool"
                                          If not the the file is corrupted 😕
                                          Si prega di aprire il file LiveIvy.rb con 'Notepad.exe' e vedere cosa dice.... Dovrebbe avere queste linee...
                                          Se non il il file è danneggiato
                                          You could type/copy+paste the five ' require...' lines into the Ruby Console in turn and see if the tool then works.
                                          Si potrebbe digitare/copia+incolla il cinque ' require...' linee in Console Ruby, a sua volta e vedere se lo strumento funziona allora.
                                          • C
                                            carmelo
                                            Now it works.
                                            Wrong with the folders...sorry 😄
                                            thank you very much 😉
                                            carmelo
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 36
                                            • 37
                                            • 16 / 37
