    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.1k Views 172 Watching
    • kaluK
      kalu
      Hi to all:
      I try the IVY plugin is awesome what I see but I don't understand what are the steps to make it grow. Can someone place here the shortcut keys to make it work and grow and show leaves and menu for some reason I cant see the menu I have sketchup pro 8 and Windows 7 64.
      Thanks.
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
      • L
        lapx
        Hello all,
        Installed yesterday and was working now i cant get leaves to grow with final shift click 😢
        • V
          vidy
          @kalu said:
          Hi to all:
          Thanks.
          try this kalu:
          ALT-Click : Make the ivy grow towards the mouse position (Mac: Cmd)
          Mouse-Click : Grow Ivy stem
          CTRL-Click : Grow Ivy leafs (Mac: Alt)
          SHIFT-Click : Finish Ivy
          Keyboard 'i' : Start over
          still so much to learn..
          • V
            vidy
            @lapx said:
            Hello all,
            maybe you can check on page 17 for this issue..
            regards,
            • L
              lapx
              Vidy , yes! Thank you! Change the default values of the Spread from "0" to "1" and it works like a charm.
              • L
                lapx
                Spoke to soon. Was working fine. Now it's back to its old bad behavoir 😞 Shift click to make leafs is where I end up with a problem. It appears to make several duplicate copies of just 1 ivy branch and thats it. Leaves are not drawn. What can be going wrong? Using SU 804811.
                Thanks,
                • G
                  gianpier1
                  HI Boys.
                  I have a problem. I can´t never see the leafs!!!!!
                  Help me please! 🎉
                  • G
                    gianpier1
                    Hello guys again!!!
                    I can not see how the leaves are drawn? 😲 😲
                    I don´t understand it!!!
                    • romboutR
                      rombout
                      @gianpier1 said:
                      Hello guys again!!!
                      all depends on which version of SU you use...
                      try searching this forum post for updates and working version! for me a custom revised version 6.05 something does the job... try to look for it!
                      • G
                        gianpier1
                        i´m using ivy 0.6.3 to SU 8.0. but i didn´t find ivy 0.6.5. Neve i can´t see the leafs man
                        not understand because the leaves do not work when I press SHIFT, the vines are also up.
                        Thanks man
                        • L
                          lapx
                          For me its sometime works and sometimes not. Cant put my finger on it. Mostly stops working when using shift click. If it means anything, I can see the google and standard tool bar ghosting when I hit shift click 😕 using ivy 0.6.3
                          • L
                            lapx
                            Any developement? This is such a wonderful program to let go. Does anyone have it working consistently in sketchup 8?
                            Shift click seams to be the problem. Its not making the leaves.
                            • L
                              lapx
                              Anyone else have consistent success with the plugin? Might it be in conflict with other scripts?
                              Would love to use it on this current project...
                              http://forums.sketchucation.com/viewtopic.php?f=333&t=38590
                              • V
                                vidy
                                still working at mine, i know i dont make it so dense.. but still work... 😉
                                here is the screen shot
                                • P
                                  penniner
                                  cool !
                                  • L
                                    lapx
                                    Its working now. If I can just find out why its not working in some cases. The only thing done differently that I can think of is shutting down the computer and reactitvating sketchup_ivy.
                                    • N
                                      niks
                                      hi.. i've used both Ivy version 0.6 and .5, its working if im on a new scene but once i usethe plugin on my saved sketchup model it does not work. im using sketchup v.8 pro,windows....here's the result of the plugin when i apply it to my saved file. when i shift-click, it only add a single black vine line.. i also tried different suggestion posted on this thread but no luck.
                                      • C
                                        carmelo
                                        hi...
                                        i have this problem: "Errore di caricamento del file LiveIvy.rb
                                        no such file to load -- LiveIvy/LiveVector_core"
                                        Why?
                                        tanks
                                          hi...
                                          Why?
                                          tanks
                                          When you extract the files/folders from SketchupIvy.0.6.3.beta.rar you should have a file called LiveIvy.rb and a folder called LiveIvy [which contains several files and sub-folders].
                                          Put the LiveIvy.rb file and the LiveIvy folder into the Plugins folder.
                                          Do NOT move files from the LiveIvy sub-folder into the Plugins folder - if you have done that, then move them - it will probably break otherwise.
                                          This is what should be in this LiveIvy sub-folder... Capture.PNG IT: Quando si estraggono i file/cartelle da SketchupIvy.0.6.3.beta.rar si dovrebbe avere un file chiamato LiveIvy.rb e una cartella chiamata LiveIvy [che contiene diversi file e sottocartelle].
                                          Inserire il file LiveIvy.rb e la cartella LiveIvy nella cartella Plugins.
                                          NON spostare i file dal LiveIvy sottocartella nella cartella Plugins - se avete fatto questo, poi spostarli - sarà probabilmente rompere il contrario.
                                          Questo è ciò che dovrebbe essere in questo LiveIvy sottocartella...
                                          • C
                                            carmelo
                                            tanks for reply.
                                            there is another problem:
                                            can't convert nil into String
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 36
                                            • 37
                                            • 16 / 37
