    Why 13 Amps?
    21 Posts 12 Posters 1.4k Views 12 Watching
      Here you go....
      http://www.google.co.uk/url?sa=t&source=web&cd=7&sqi=2&ved=0CFMQFjAG&url=http%3A%2F%2Fwww.theiet.org%2Fpublishing%2Fwiring-regulations%2Fmag%2F2006%2F18-plugorigin.cfm%3Ftype%3Dpdf&rct=j&q=bs1363&ei=1YJITajRMY26hAe_qojhBA&usg=AFQjCNGzEqKJY-io2tvy0dSMjH0JNT_Zqg&cad=rja
        I didn't actually read to the end, was he charged?
        I'm not positive.
        • BoxB Offline
          Maybe because of the rubber cosh they decided it was an isolated incident.
            These jokes are shocking. I'm resisting the urge to pull the plug on this thread. Keep it up and I'll blow a fuse. Jeez, I'm getting amped over this!
              I suppose they wanted to keep the public insulated from the whole thing.
              • EscapeArtistE Offline
                EscapeArtist
                Ohm my, this is a revolting current in this conversation and it should be rectified immediately. Such matters should stay grounded in fact and not arc too far out of bounds.
                  tim
                  That's quite enough. We've all had ample.
                  I just wish that north america had adopted a sensible plug/socket design like the UK. Having just built a house I have been quite horrified at how flimsy and tacky the electrical stuff is. On the other hand, I wish the UK would adopt the decidedly more civilised plumbing standards...
                    @alan fraser said:
                    (and if you think UK plunbing is bad, you should try Greece)
                    True...
                    • daleD Offline
                      dale
                      I just started laughing till it Hz. πŸ˜’
                      • Alan FraserA Offline
                        Alan Fraser
                        I suppose that the fact that he couldn't get her to stay in the chair long enough to throw the switch 'ampered his plans somewatt.
                        (and if you think UK plumbing is bad, you should try Greece)
                        3D Figures
                        • david_hD Offline
                          david_h
                          I guess that's what the riots are all about. . .
                          • Mike LuceyM Offline
                            Mike Lucey
                            .... I see there are some 'sparks' flying in this thread πŸ˜‰
