    Why 13 Amps?
    21 Posts 12 Posters 1.2k Views 12 Watching
      It saves on material costs in wiring. It's a throwback to rebuilding after WW2. There's an article somewhere that explains the INS and outs but primarily safety and costs were the driving force.
      I think the article was on ring wiring. My dad's a lecky who bores us with this shit whenever we need stuff done. It may cost nothing but you pay in the end πŸ˜’
        50Hz AC has greater losses and is not as efficient as 60HZ.
        Due to the slower speed 50Hz electrical generators are 20% less effective
        than 60Hz generators. Electrical transmission at 50Hz is about 10-15% less
        efficient. 50Hz transformers require larger windings and 50Hz electric
        motors are less efficient than those meant to run at 60Hz. They are more
        costly to make to handle the electrical losses and the extra heat
        generated at the lower frequency.
        Oh well. He wasn't successful with the rubber cosh anyway.
        • BoxB Offline
          I didn't actually read to the end, was he charged?
            Here you go....
            Redirect Notice
            (www.google.co.uk)
              I'm not positive.
              • BoxB Offline
                Maybe because of the rubber cosh they decided it was an isolated incident.
                  These jokes are shocking. I'm resisting the urge to pull the plug on this thread. Keep it up and I'll blow a fuse. Jeez, I'm getting amped over this!
                    I suppose they wanted to keep the public insulated from the whole thing.
                    • EscapeArtistE Offline
                      EscapeArtist
                      Ohm my, this is a revolting current in this conversation and it should be rectified immediately. Such matters should stay grounded in fact and not arc too far out of bounds.
                        tim
                        That's quite enough. We've all had ample.
                        I just wish that north america had adopted a sensible plug/socket design like the UK. Having just built a house I have been quite horrified at how flimsy and tacky the electrical stuff is. On the other hand, I wish the UK would adopt the decidedly more civilised plumbing standards...
                          @alan fraser said:
                          (and if you think UK plunbing is bad, you should try Greece)
                          True...
                          • daleD Offline
                            dale
                            I just started laughing till it Hz. πŸ˜’
                            • Alan FraserA Offline
                              Alan Fraser
                              I suppose that the fact that he couldn't get her to stay in the chair long enough to throw the switch 'ampered his plans somewatt.
                              (and if you think UK plumbing is bad, you should try Greece)
                              3D Figures
                              • david_hD Offline
                                david_h
                                I guess that's what the riots are all about. . .
                                • Mike LuceyM Offline
                                  Mike Lucey
                                  .... I see there are some 'sparks' flying in this thread πŸ˜‰
