    Strange Toolbar behavior
    19 Posts 5 Posters 1.2k Views 5 Watching
      I'd like a explanation on doing this registry clean. My SU flickers badly on startup with dialogue boxes taking an age to load and toolbars missing icons.
      • E
        ericschimel
        Mine do that flicker thing on another computer.... Does anyone have any good suggestions for clearing the registry? Manually by searching for Sketchup references, or a registry cleaner utility?
        -Eric
        http://plugin.sketchthis.net
        Sketchup Kitchen Design Plugin
        Custom Models
          Rich and Eric,
          Editing the Registry can be bit dangerous if you do the wrong thing but I've never had any difficulty with removing the SketchUp registry entries. It is an At-your-own-risk sort of thing, though. Here's how I do it.
          Click on Start>Run.
          Type regedit in the box and hit Enter.
          Click on the plus signs next to HKEY_CURRENT_USER, SOFTWARE, GOOGLE. Find SketchUp8. Delete this and when you open SketchUp again, it will look like a new installation although all of your plugins, materials and so on will still exist. You'll have to choose your desired Default template and set your toolbars again. I don't remember but I don't think you'll have to re-enter your license info for Pro after doing this. It would be wise to find that info first, though. You could also open the SketchUp8 folder and delete individual entries. You might delete all of the toolbar entries which would require resetting them but wouldn't affect template choice or other things.
            Well I had a look in the regedit and I've hundred of toolbar and custom toolbar entries.
            Haven't done anything as yet. πŸ˜•
            • E
              ericschimel
              I am going to kill mine off later on today. I'll just set a restore point before I do it....
              -Eric
              Custom Models
                ThomThom and TIG have talked about all the toolbar entries in the Registry. It seems like there are often more registry entries than there are toolbars. ThomThom made a .BAT file to automatically clear the toolbar entries. As i remember, though, there are two different kinds of toolbar entries and the .BAT file only gets one kind.
                • kachuppK
                  kachupp
                  If you think its a registry error try this
                  DAYOne.CMD
                  REG EXPORT HKCU\Software\Google GOOGLESU_.REG
                  REG DELETE HKCU\Software\Google /va /f
                  : Create Backup Restore Google Sketchup8 to DayOne
                  : THE BACKUP FILE GOOGLESU_.REG can be re-imported back into the registry with a click or two.
                  : THE DELETION of that registry hive gets recreated by the APPS google apps that use it.
                  : ITS SAFE to use because of the backup it makes for you.
                  name it DAYOne.CMD or *.BAT either way windows will handle it
                  πŸ‘
                  • E
                    ericschimel
                    Ok, I did this, and like you said everything got reset like it was a new install, but I am still having the exact same issue....
                    @dave r said:
                    Rich and Eric,
                    Click on Start>Run.
                    -Eric
                    Custom Models
                      So then it's not a defect. It's a feature. πŸ˜„
                      Did you delete the entire SketchUp registry?
                      Does anything happen differently if you change OpenGL settings? I wouldn't expect so. But who knows? It really seems like a weird graphics problem but if it only happens in SketchUp when grabbing toolbars, then I wouldn't think the graphics card has anything to do with it. The Select tool and inferencing and all that stuff works correctly, right? And it doesn't appear in any other programs.
                      • E
                        ericschimel
                        You are correct on all counts, the only think it effects is the toolbar selection and moving process. Sketchup, and other programs perform perfectly otherwise....
                        I will try deleting more registry stuff...
                        -Eric
                        Custom Models
                          Be careful.
                          • E
                            ericschimel
                            Ok, here's an update:
                            Sketchup's toolbars are still doing that thing that is happening in the video. Other applications on Windows aren't doing this... But, I loaded up an old piece of design software that we have, something that has a really old, Windows XP like set of toolbars, not these slick new ones that you see. THAT program does the same thing. So clearly this is not a Sketchup only problem.
                            So now I am really stumped. It can't be a hardware issue, and unless I missed something, I did rule a graphics driver issue because I completely wiped the drivers and reinstalled with a fresh, updated set of drivers.
                            -Eric
                            Custom Models
                              Is there anything related to setting the mouse pointer that would have any effect on this? I'm grasping at straws right now but no one else seems to have any ideas either.
                              • E
                                ericschimel
                                I had a thought about it being some sort of weird accessibility setting, I checked and everything appears to be normal on that front. One thing I haven't tried yet is booting into safe mode....
                                -Eric
                                Custom Models
                                • sketch3d.deS
                                  sketch3d.de
                                  you may try if disabling the Windows desktop composition does have any effect:
                                  "Right Click on SU > Properties > Compatibility tab > Settings > Disable desktop composition"
                                  http://www.sevenforums.com/attachments/tutorials/259d1225821393-compatibility-mode-settings.jpg
                                  hth,
                                  Norbert
