    Adding Stone window detail
    25 Posts 7 Posters 1.2k Views 7 Watching
    • leedeeteeL Offline
      leedeetee
      Hiya,
      Can;t get my head around how I go about detailing the stone windows/mullions of churches.
      For example, currently drawing the window attached, but the only way I can think of adding the detail to the stone so it appears correctly is to offset the panes, push/pull them out, then do a follow me between the pane and the new stone?
      Am i being extremely dense here? This is the sort of detail on the stone I am after: http://www.photosofchurches.com/images/Wales/Anglesey,%20Menai%20Bridge,%20St%20Tysilio%27s%20Church%20Window.jpg
      Current window
        How much do you want those profiles be detailed, Lee? (You could obviously detail it extremely but that could be an overkill).
        I used single edges then tube along pipe plugin with a simple square diagonally placed on some windows I made. If it is not a close-up, it is fairly good result like this one:
        http://sketchup.google.com/3dwarehouse/download?mid=4bbe1352c72a59f29309c12303f68245&rtyp=lt&ctyp=other&ts=1278183608000
        (click on the pic to get to the WH model)
          leedeetee
          I am just trying to do some renders of my local, I took some photographs this morning and am just working on the nave at the moment. Your method may work very well. Need to have a play though - not used the tube along pipe plugin ...... yet! Will download it now.
          Attached is one of the windows I am trying to re-create ...
          Thanks Gai. πŸ‘
          Holy Trinity
            leedeetee
            P.s. Is this the plugin?
            http://forums.sketchucation.com/viewtopic.php?f=323&t=1709&hilit=tube+along+pipe+plugin
            • EscapeArtistE Offline
              EscapeArtist
              It's not too difficult to detail a Gothic window, I did this one years ago with nothing more than the arc tool and follow me:
              Error 404 (Not Found)!!1
              (sketchup.google.com)
              You could also use the bezier plugin to have more curve options. The only other pointer I could remind you of is to make sure you build your model at 10x or more scale, when the curves intersect at the various points it can leave a lot of holes or SU won't want to intersect the small faces if modeled life size.
              • W Offline
                watkins
                Try looking here for inspiration
                http://forums.sketchucation.com/viewtopic.php?f=18&t=9781&p=62334#p62334
                Regards,
                Bob
                  leedeetee
                  Thanks, chaps. My brother is a stained glass window restorer so would really love to nail the techniques involved. I think I'm making the whole window thing more complicated than it needs to be. Will give it another crack tomorrow with a fresh head.
                    leedeetee
                    For anyone finding this thread in the future, I created my window(s) by using lines, arcs, follow me and intersection with model. Easy really, if a little bit of a ballache. πŸ˜„
                    Holy Trinity Window
                      EscapeArtist
                      Very nicely done. Thanks for showing what you came up with!
                        leedeetee
                        Thanks, EA.
                        Attached are a couple of basic renders showing the window. Turned out OK I think.
                          EscapeArtist
                          Nice detail!
                          I don't know what you rendered it it, but it would look great with some sunlight coming in and falling on the floor.
                            You have also Lattice-zicer by TIG
                            http://forums.sketchucation.com/download/file.php?id=28262&mode=view
                            or City Street Generator + Clean up by Thomthom
                            Make face for the big internal facets
                            http://forums.sketchucation.com/download/file.php?id=42058&t=1
                            and this method
                            http://forums.sketchucation.com/download/file.php?id=42166&mode=view
                            "Multiple Face Offset" By Remus 😎
                            Windowizer(3 free or 4) By Rick Wilson @Smustard
                            Selection Only faces by Selection Toys by Thomthom β˜€
                            Invert Selection by TIG β˜€
                            Geodegics! 😎
                            • TIGT Online
                              And of course there is a 'GothicWidow' Ruby - but as I helped a Masters student co-write it it's not in the public-domain... Here are all of the permutations you can set for a customized size/arch-spring/pattern etc Capture.PNGCapture1.PNG
                                Thanks πŸ˜’
                                • TIGT Online
                                  Your welcome!
                                  [Just one of my many talents that are still hidden under that proverbial bushel πŸ˜‰ ]
                                    Those look very much like the ones I made with the tube along path plugin (at least the composition and the cross section - as well as the "joins" where the certain pieces still need some care and intersecting).
                                    • TIGT Online
                                      Same idea, it's just all automated from a dialog where you input values for the various dims, arch-type etc.
                                      It needs so manual tidying after creation as that part can be awkward 'in code'...
                                        leedeetee
                                        Wow, that would have done the trick, TIG! 😲
                                        • TIGT Online
                                          Unfortunately it's subject to a NDA... 😞
                                            I won't tell anyone....not even that asshole you hate
