    E-on-Lumenrt render for Sketchup
    extensions
    102 Posts 27 Posters 33.1k Views 27 Watching
    • E Offline
      Ecuadorian
      Other software companies allow you to download a demo to try before you buy, and you can also access the support forum so you can take a look at what kind of problems the users are facing. However, there's no demo for Lumen RT, and you can't even view its forum before buying it. Now that's a blind purchase...
      -Miguel Lescano
        Panga
        Yes totally agree with you Ecuadorian 'Blind Purchase'. I purchased it and It's still not working with my graphic card (Quadro Fx 1800), even if e-on staff are very present to help me...I followed some advices found on some places (also here) and purchased it, and I hope it was not a mistake.
        Normally I'm always waiting some feedback before buying a product, but I needed another tool for some of my works, so...I'll give feedback soon.
        Cheers.
          @Panga
          Are you 64 bit?
          I'm running it on Windows 7 64bit SP1 with no issues. Can you run the LiveCubes they provide on the site?
            Panga
            Yes I'm on Win7 64 bits SP1. But All liveCubes are not working. I have an error message saying that my graphic card is not compatible even if my system fulfil the requirements.
            • E Offline
              Ecuadorian
              How's the baking time, Rich, for a model with 600K + edges?
              -Miguel Lescano
                Plex
                Well Ecuadorian, I admire your optimism. There is a problem with 600K models. There is of course warning of 500k+ edges, but it seems to me that something gives away with models of that size. I usually get SU splat. Hopefully this is just a problem that will be ironed out, but at the moment you have to cut some corners and optimize the model to the bones.
                • E Offline
                  Ecuadorian
                  Yikes... All the house animations I make have more than 600K edges and 300+ textures. I've been using LightUp so far but I had hoped to improve them with Lumen, adding raytraced reflections and sharper sun shadows.
                  Looks like I'll have to wait.
                  -Miguel Lescano
                    I exported a model in the screenshot quite quickly (see also statistics) although the materials used are mostly low res, small tiles and I did not even tweak any of them (with special bumps or reflection).
                    Navigating in the exported live cube goes pretty well although not without minor lags. nvidia geforce 9600 GT (1Gb) on 32 bit system.
                    • AdamBA Offline
                      AdamB
                      FYI: LightUp is adding planar reflections just like lumenRT uses. 😉
                        dburdick
                        Hi Panga,
                        Can you visit the e-on Tech support page and enter a bug report on your issue with the Quadro 1800 graphics card. LumenRT should work fine with this card. Here's the link:
                        http://www.e-onsoftware.com/support/TechSupport.php
                          bravoddb
                          where can I buy nice 3d trees? so I can use it with Lumen RT
                            dbalex
                            Do you guys have something rendered in lumenrt you can show us? I would love to see something made by real users, not those demo stuff 😉
                            http://www.bocostudio.com
                              Panga
                              No,
                              I'm still unable to produce anything with it as the fix for my graphic card is not released yet...or did I miss something ?? Two or Three weeks after buying it... 😠
                                dbalex
                                I'm sorry to hear that, I keep thinking it's strange to not release a demo of the soft to try before buying, anyway I hope your problem will get solved quickly.
                                • E Offline
                                  Ecuadorian
                                  It's even stranger being completely unable to see the forum before buying.
                                  -Miguel Lescano
                                    dbalex
                                    yes indeed, it looks like they have something to hide
                                      Hi guys, here is a very quick and dirty example (probably e-on would not be proud of) I made when testing bump and reflection maps.
                                      http://dl.dropbox.com/u/25025526/Untitled.exe (Mac users, sorry but I did not export a Mac compatible version yet as I could not test it anyway)
                                      Note two things when loading:
                                      • the scene is a bit off my ground plane so if you start walking around, scroll a bit to zoom in and only then click the mouse.
                                      • LumenRT places your scene onto its ground based on the lowest point (in my case, the bottom of the pool) of the model so you can easily "fall off" if you have basements or such, deep pools (certainly I should have added a bigger ground plane to the model but again, it was just for a quick test, nothing "real" as a presentation)
                                        Press F1 to see all navigation and other options. Note that this model does not have SU scenes so exporting animation or playing it in kiosk mode is not possible (that was not part of my testing).
                                      I should probably make some better model/example to show. Here is what you can "expect".
                                      • jamalitoJ Offline
                                        jamalito
                                        I liked to works Vue and it Versions
                                        but
                                        Will it be a good rival for Vray RT ?
                                        Albert Einstein:
                                        ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                                          I cannot compare as I do not know Vray RT (to be honest, did not even know there is one).
                                          • jamalitoJ Offline
                                            jamalito
                                            @jamalito said:
                                            no Mr Gaieus there are Vray RT and they release Vray RT 2.0 demo true I see it in Vray Max right now I don't know is there version to SU in true i wish ?
                                            you can see this Tutorial For Vray RT
                                            http://youtu.be/KOHcTDyR44o
                                            Albert Einstein:
                                            • 3 / 6
