    Faster Autosave!
    30 Posts 11 Posters 21.2k Views 11 Watching
    • kenK
      ken
      Try this plugin by TIG. I set my autosave to 30 minutes and use the archiver.rb plugin. So a search and check it out, it is fast.
      Ken
      • Bob JamesB
        Bob James
        Archiver
        http://rhin.crai.archi.fr/rld/plugin_details.php?id=20
        • jbacusJ
          jbacus
          Ken
          This looks like a tool that is similar to SketchUp's existing "Save A Copy As...", though it automatically names the file for yu so you don't have to navigate a dialog. Are you saying that this script saves large SketchUp models faster than a simple "Save" operation?
          "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
          John Bacus
          jbacus@sketchup.com
          • mitcorbM
            mitcorb
            This may be off topic, but related. I rarely get a fix report in Validity Check. Maybe I ain't mean enough. Should Validity problems be a frequent occurrence? How frequent?
            Moderator, feel free to move this.
            • kenK
              ken
              Ken
              I can select the archiver selection and go back to work as fast as the mouse can move to another tool. It is quick.
              Ken
                I was asked ages ago to set up a timer to remind you to archive every 10 minutes BUT it's annoying to get dialogs popping up in the middle of something and reworking it to be automatic AND wait until you've stopped some complex operation is also making it into just the bastard-child-of-AutoSave ???
                • jbacusJ
                  jbacus
                  Well, I've looked at the code, and it looks like it is doing a "model.save" to do the actual archiving operation. Which is the same code path that SketchUp executes from the File menu. Not sure why that would be faster.
                  TIG: Can you explain what your script is doing differently?
                  John Bacus
                  jbacus@sketchup.com
                  • Bob JamesB
                    Bob James
                    I did a Save on one of my large models and it took 90 seconds. I then made a copy of the file, opened it and uses Archiver: it took 80 seconds.
                    I guess I don't see much advantage of Archiver over a regular Save.
                      Archiver simply uses the model.save(name) API method to save a 'tmp' snapshot of the SKP at that second, it then copies it to an 'Archives' subfolder, renaming it with an additional date-stamp etc and erases the tmp version.
                      It shouldn't make any significant difference to the built-in autosave timings - it even has to copy/delete the file into the subfolder too... however, it does seem a little quicker 😕
                      • jbacusJ
                        jbacus
                        As I said earlier in this thread, "Check Validity" (if enabled in preferences) can cause a save to take longer. If a model is checked for invalid geometry, then that geometry is fixed... it doesn't have to be fixed again the next time you save a model. This might account for a small difference in save speed (~10%) between successive operations.
                        My guess is that optimization of the rendering pipeline has allowed you to work on increasingly large models (Bob: 80-90s save times! How large is your model?) and you're now beginning to feel a new performance bottleneck. Of course, there will always be a performance bottleneck somewhere in the system.
                        John Bacus
                        jbacus@sketchup.com
                          Yup - I find working on 500K face models and more without much trouble. It's usually depending on transparency use and textures.
                            monkers
                            I find the auto save tends to kick in right when I'm right in the middle of an operation or by some miracle I'll click something at the exact instant that it starts saving and it instantly crashes. No bug splat. Just. "see ya..." I have found this on many rigs and versions of sketch currently on 15.3.331 and still getting it. It has to be the autosave because the last auto save increment is always within a minute or so of the crash. Just got one then by selecting a line at the same time and I had to come here and rant.
                            Is there a way for you guys to make it wait or disable the mouse about a half second before? My computer is one more sketchup crash/bugsplat from exiting the building in flames via the window.
                            I've had a long and rough night.
                            • jgbJ
                              jgb
                              Best way to speed up SAVE and AUTOSAVE as well as loading a file is to get a Solid State Drive (SSD) either replacing the C:\ drive or adding/replacing a D:\ drive.
                              My old spinning HD would typically take over a minute; my SSD takes about 3 - 5 seconds for even bigger files. AutoSaves are almost un-noticeable now.
                              jgb
                                monkers
                                For me it not really save time. I work off an SSD RAID0 array so its as quick as it can be. Its just in instability of it.
                                Working with large files in sketchup reminds me of this scene from the simpsons.. The slightest breeze will bring it down.
                                http://40.media.tumblr.com/113f03ae8273b9c615fa3ba7d26754c9/tumblr_mw81owlUhQ1rn9p3do1_500.jpg
                                  monkers
                                  Maybe even a little box which counts down till the next autosave and warns you a couple of seconds before it happens. I'm sure a bunch of other programs could do with a feature like this. It could take the worst possible moment feeling out of it.
                                  • K
                                    kaas
                                    did you try disable-ing <window> - <model-info> - <file> - <redefine thumbnail on save> ?
                                    For normal saves, that can save up to half a minute for my files (< 50Mb). I never do auto-saves so don't know if this would help.
                                      monkers
                                      Just an update/possible solution for anyone that might find this useful. I have set up a small 10GB RAM disk (Storage drive mounted on RAM) as a temporary location where I can locate my working files. As RAM Disks don't retain data when power is cut I also set up a sync in-case of an unexpected power down. This has massively reduced save/auto save times.
                                      I'm not sure what the exact speeds are but from what I've read at 10GB/s I assume its around 10 times faster than my SSD RAID0 array and about 20 times faster than a standard 7200RPM HDD. Ill have to do some testing later.
                                        monkers
                                        Thanks for that i gave that a shot and combined with my new RAM disk in the above post.. Wowee 😮 150mb files are saving in less than 1 second.
                                        Hopefully the less time it spends saving and locking up the less chance it has for the breeze to come along and push it over
                                        • Bob JamesB
                                          Bob James
                                          10GB RAM disk is small 😲
                                          I have 32GB of ram so to use one third of it for a ram drive would really not be small to me.
                                            monkers
                                            It would be rude not to put it into double figures when there's 64GB there. Its all DDR4 as well so nice and quick. I'll be using it for other program scratch disks as well.
