    Edit Texture Image problem
    6 Posts 3 Posters 307 Views 3 Watching
    • EdsonE Offline
      Edson
      ok, I am no newbie but the answer to this question may help many novices.
      in a new file I drew a face and painted it with a brick texture. then I right clicked on it and selected Edit Texture Image. this caused photoshop (my image editor) to open. I changed the color of the texture to a bright green, saved it and nothing happened back in sketchup. there was no consequence to my actions in PS.
      do you guys know what could be the problem?
      http://www.mahfuz.arq.br
      • Rich O BrienR Online
        If you save in a different format or name it won't update. So Material1.jpg sent to PS should be saved as Material1.jpg. You should get a dialogue box about overwriting existing file.
        Did you 'save' or 'save as'?
        • EdsonE Offline
          Edson
          I "saved" and did get the overwriting message but the texture in sketchup remained unchanged. I am sure there is a missing step somewhere.
            Well, I'm afraid that is strange. I do know SU places the file in a temp folder. But the fact your getting the overwrite box suggest your doing everything as normal.
            Have you tried this on a few textures?
            Let us know if you figure out the issue.
            • 0 Offline
              007
              Edson, did you flatten the image before saving, as it won't update in SketchUp then?
              007
              It ain't bragging if you've done it....
              • EdsonE Offline
                Edson
                it takes the likes of 007 to solve the riddle. you nailed it! 😍 the image needed flattening. thanks.
