    Artisan tool bar
    17 Posts 5 Posters 3.2k Views 5 Watching
      Is it docked?
      If so undocked and redock to see if the icons come back.
      I get this a lot with JPP, Tgi and Thea Exporter
      • kenK
        ken
        Is it docked?
        Well, thanks for the quick reply. However, docking and undocking did not do the trick.
        Ken
          Can i see a screenie?
            Are you still running with a large amount of plugins installed Ken?
            • kenK
              ken
              Here is a screen shot. I don't have it dock at present. The icons are grayed out, however, I can see at the bottom the name of each icon shows up as I mouse over the icons, so part of it is working. However, I get no other action then the name of the icon at the bottom right.
              Ken
              • kenK
                ken
                Well, I did trim the plugins back a month or two ago. And all plugins that I can, I have removed from the contents menu.
                Yes, I am a plugin hog. What I don't know is how long this has been like this, because I don't have much call for the Artisan tool bar.
                Ken
                  That I haven't seen before?
                  I suppose contacting Dale is the best advice i can give.
                  404 Not Found
                  (artisan4sketchup.com)
                  I'd be interested to know the outcome/cause or if anyone else has experienced this?
                    Can you try temporarily removing some plugins you have - just to make sure it's not the sheer number of plugins doing this again?
                    • kenK
                      ken
                      I will tonight, right now I need to move on, I have a PPP that I have to make some illustrations for, so I onto finishing my work.
                      Yes, I will remove some plugins, I will start with the latest installed and move backwards in time.
                      Rich and Thomthom
                      Thank you for your quick reply.
                      Ken, right now working in Rio de Janeiro, life doesn't get any better than this week.
                      • W
                        Whaat
                        Hi guys,
                        When the 15 day trial period expires, the toolbar and menu items become grayed out. You must now register the software to continue use.
                        Cheers,
                        Dale
                        • david_hD
                          david_h
                          same thing happened to me. Turns out I NEEDED TO PAY FOR THE PLUGIN!!!!
                          That might be it. πŸ’š
                          • kenK
                            ken
                            Well, thanks for all the reply, however, I am a registered owner of the plugin, since March 28 of this year. It appears it is treating me as a free user. I tried to use my registration code again and it said it was not a valid code.
                            Anyway, thanks for the reply
                            Ken
                            • david_hD
                              david_h
                              i was just kiddin'. 😳
                              • david_hD
                                david_h
                                I never take offense--I hate to give offense. Life is too short! No worries! πŸ’š
                                • kenK
                                  ken
                                  Oh, no offense taken. I never thought that it would go back to a trial version and apparently that what has happen. I tried the registration code and it did not work. So right now I am waiting on an answer to what happen or another registration code.
                                  Maybe in getting my laptop ready for deployment, with all the upgrade plugins from my desktop, I accidentally over wrote something.
                                  However, thanks for the help. Your email did remind me that I had saved the code in my email.
                                  Ken
                                  Edit by me, fingers are fast, went from trail to trial.
                                  • kenK
                                    ken
                                    Well, I have corrected the problem. With Dale's help. For some reason, the program reverted back to a trial version and it appeared the registration code wasn't working. However, the problem seems to be me. I guess I wasn't careful enough in entering either the email address or the code. Anyway, after being extra careful, the program was registered again with the original code. I wish to thank Dale for all his help and the program.
                                    Just wanted to be sure I have included the solution to this plugin problem.
                                    Thanks to all in your responses.
                                    Ken
