    Newbie desperately need help to keep her job
    18 Posts 9 Posters 3.7k Views 9 Watching
      Slimdog
      When you down load a plugin onto your mac typically they are unzipped. Copy or cut it from you downloads folder and paste it into this path.
      Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins
      Once your plugin is pasted into this folder you need to restart sketchup.
      Good luck
        Jet
        Yes. I'd done what everyone is saying two weeks ago more than 3 times.
        Originally, I placed the Plugins in the HD folder
        the path is like this:
        Mac HD/Library/Application Support/Google SketchUp8/SketchUp/plugins
        For "SoapSkinBubbleTool_Rel_1" I put it in:
        Mac HD/Library/Application Support/Google SketchUp8/SketchUp/tools
        Then, it didn't work. So I'd tried putting it in user's folders
        User/Library/Application Support/Google SketchUp8/SketchUp/plugins
        User/Library/Application Support/Google SketchUp8/SketchUp/tools
        but it didn't work either.
        BTW, all the unzipped file downloaded from the internet will be zipped automatically by the Mac os x system, a folder contains the content from the unzipped file would be generated by the system as well. The unzipped file will goes to the trash automatically. I copied the zipped folder to the plugins folder. Do you mean I need to put the unzipped file to the plugins folder as well?! 😲
        Here're some snapshot of what it looks like:
        Never give up, Never surrender!
          First problem...
          A simple .rb file goes straight into the Plugins folder.
          More complex tools are zipped - the zip-file contains multiple files and subfolders.
          When you extract such a zip file its contents are [usually by default] put into a new folder that's named after the zip file itself.
          These contents might be loose files or subfolders of files that are put into this new folder.
          NOW THE CRUNCHER...
          This new folder does NOT go into the Plugins folder!!
          The loose files and subfolders [still containing their own files] must be moved from this new folder into the Plugins folder itself!
          What is in the zip goes into the Plugins folder in exactly the same relative relationships of files and subfolders/files.
          THEN when you restart Sketchup the Plugins will auto-load.
          You need to read each tool's notes to see if its menu item is in say the Plugins or the Tools menu, if it's an Extension how you must activate it from Preferences, or if it has a Toolbar how you need to activate that from the View > Toolbars [or MAC equivalent name!] menu list...
          πŸ˜’
          • B
            bjornkn
            If you get your plugin problem sorted out - and still have your job πŸ˜‰ , there is one more tool to consider using/buying/trying - Amorph (or PhotoScan) from tgi3D.
            If you also have some good, uncropped photos you could model from them, eventually using PhotoMatch in SU (or PhotoScan) to get your models aligned with the potos, and ready for texturing all those carvings directly from the photos (you wouldn't want to model them in SU...)
            The attached images show a quick test where I algined the camera quite coarsely with your top photo (see that small red edge - it is a vertical edge aligned with the edge of the rack) drew the contours as curves in Amorph. Then they were view locked, and the second image shows a very quick view of the model from a different view, where I have moved the curves upwards along their lock lines (works alomst like normal inference locking), and a few holes filled in with meshes and smoothed. The proportions (and shapes) are not quite right, as the lack of truly aligned photos makes it a bit of trial and error. And I didn't spend more than about 15min here. The backs should be quite a bit higher compared to the seats...
            If you still have access to the couch and can shoot some more photos, place a big box/crate (or several) on the floor that can be used for aligning the cameras with SUs PhotoMatch tool. Or use the rack for reference (need to see more of it then).Clipboard-23.jpgClipboard-24.jpg
            Equipped with Amorph/PhotoScan, Artisan, Curviloft, EdgeExtrude tools etc you should be able to model anything your employer throws at you πŸ˜‰
              driven
              hi Jet,
              your very close on the mac front, so a few accumulated tips
              navigate to the HD plugins folder [like in your pic] and drag it to your side bar for easy access, you can Drag copies of any downloaded plugins into it when it's there or if you prefer Copy/Paste you can right/click or ctrl/click a select Open Enclosing Folder to go straight to it.
              You can just drag the whole folder into plugins if you want, but you need to take out or copy out, the right ruby and the support folder.
              They're normally in the right order, so move the lot first time intact
              with fredo's you need the LIBFREDO6_Dir_37 folder, I'll have a look later at what else is missing, unless someone else pipes in.
              here's an example pic
              rubies in sidebar
                Jet
                Hey Guys, Thanks a lot to all of you! You are all so warmhearted. It makes me want to cry. Dave helped me fixed the plugins problem yesterday. (Thank you, Dave!)
                I have a new project coming in and I'll work on the sofa later today(Can't wait to checkout all the tools). Anyway, I'll keep you posted.
                Thanks guys!
                • B
                  bahri
                  This is what i like from this forum ...even master solo give his advice.. πŸ˜› πŸ˜›
                    Jet
                    Hey Guys, bad news. It's been a week since I told my boss that he needs to buy the plugins for the sofa. So far, I never get any answer from him. I guess he doesn't want to buy it at all. He just had me work overtime doing tons of photo retouching and graphic works up to now. And later on, he will have me do 3d technical drawing in Autocad. It's a pity that I just get a hand on Sketchup 3D modelling and have the chance to do something fun. But I probably have to go back to some boring technical drawing...
                    • B
                      bjornkn
                      Sounds like a bleak future πŸ˜‰
                      You could always download fully working trial versions of both Artisan (15 days?) and tgi3D/Amorph/PhotoScan (30 days), make the sofa and impress him so much that he opens his wallet πŸ˜‰
                      It is not impossible to make it without plugins, but it would be a lot more difficult and time consuming.
                        Jet
                        Please don't laugh at me, Solo. I know your stunning works is from outer space. I would die for you skill and talent. It's shameful to show you this, but I have to.
                        I did 2 version so far. I used push/pull and follow me for both of them.
