    [Plugin] Extrude Edges By Vector To Object v1.4 20110528
    32 Posts 20 Posters 34.8k Views 20 Watching
    • Rich O BrienR Online
      Extrude Edges by Offset πŸ‘
        Thank you for another useful tool, TIG. I must be doing something incorrectly though because I don't get the same results you show. I tried with the roof made into a component and not. I included in the selection the edges of the wall plan and either the roof component or just the bottom faces. The result is the same as shown here. I tried to follow the directions. The inner faces do get extruded to the underside of the roof but no higher.
        So what did I miss?
          Well, that was easy. there needs to be line segments draw across the wall plan aligned with the ridge line. Little detail. Easily missed. β˜€
            The funny of the thing is that works for separate objects in the same time! 😎
            • EarthMoverE Offline
              EarthMover
              Wow, great one TIG. Works great on the testing I did. (There is a project edges tool in the Projections toolset that does something similar, but the new faces remain perpendicular to the object. This is more practical in most cases.) πŸ‘
              (Not sure if Rich was hinting or renaming, but an extrude edges by offset would be a very useful addition to the toolset πŸ˜‰ )
              Content Creator at Skapeup
                Ben Ritter
                TIG, thank you once again. You are very generous and very talented.
                • Bob JamesB Offline
                  Bob James
                  Super addition, TIG, thank you for a great tool set πŸ‘
                  • W Offline
                    Wildchild
                    Awesome toolset man, just one thing, I played around with it a little, and I stopped at this point.
                    Wouldn't it be great if you could extrude any profile by a vector to any multiple objects, and of course the resulting shape is modeled by the objects it is intersecting with? Is this asking too much?
                    Eternity is very long, especially towards the end. Woody Allen
                      Divide the edges of the edge-set you want to extrude so they are 'small-bits'... so then it'll extrude better... it's very difficult to make the thing 'split' the edges so they extract as desired - I am looking at it...
                      One way would be NOT to do it as present... but extrude past, then use intersect_with and then delete the parts behind... BUT working out what to erase and what to keep is [almost] as hard as the present method... watch this space [I'm letting the gray-cells process this in 'background-mode'...] πŸ€“
                      • W Offline
                        Wildchild
                        Exactly TIG, performing an automatic extrusion-intersection-deletion would be a possible way, it's complicated though. In both cases being able to automatically add the necessary edges to fit the "shaping" object would make this a killer plugin! thanks for your past and future efforts!
                        • charly2008C Offline
                          charly2008
                          Thanks TIG,
                          another fantastic tool. It made ​​me immediately led to experiments.
                          Charly
                            Here's an updated version http://forums.sketchucation.com/viewtopic.php?p=331059#p331059
                            A new algorithm has been added for the intersecting with objects: now walls extend to soffits with additional apex vertices and so on so it extrudes fully to the faces/edges.
                            'Ghost' extrusions now show intersections as red dots.
                            The original selection is kept, unless the is group exploded.
                            ES lingvo updated by Defisto [thanks].
                            ALSO [same day]:-
                            a) Additional traps have been added for rare glitches when faced edge-selection was used.
                            b) Glitch fixed with 'undo' if you reversed faces etc...
                            c) Glitches fixed with 'commit' and extruding edges inside groups to objects outside.
                              The best is the ennemy of the better! 😎
                                Jean-Luc Clauss
                                Great work again TIG ! Thank you ! This plugin will be very helpfull for architects.
                                Auteur de guides et de mΓ©mos sur SketchUp aux Γ©ditions ENI
                                http://archi-com21.blogspot.fr/
                                  If it' very easy to make a volume3D with the extruded line result of the rectangular box 😎
                                  it's less easy for close the horizontal cylinder! πŸ˜‰ (of course the guy is added after! πŸ˜„
                                  PS the cool of the plug is that you can make the 2 extrusions in the same time! πŸ‘
                                  (Click on the image if scroolbar)
                                    Here's another update... several glitches fixed...
                                    http://forums.sketchucation.com/viewtopic.php?p=331753#p331753
                                    Here's another example of extruding lots of walls up to the underside of a complex roof form in one step...EEbyV2Obj-Roof.PNG
                                      dtrarch
                                      Hi TIG
                                      Very happy to send a thank-you to your profit(?) center but how about a link for PayPal and a path to donate.
                                      This is just a killer add-on and deserves some pay to play $ or = πŸ‘
                                      I think that most use PayPal as an option for payment and perhaps do not use as a funded account.
                                      Thx
                                      dtr
                                        d12dozr
                                        dtrarch, link is in the Plugins > TIGTools folder
                                        http://goo.gl/f7ooYh
                                          Or you can simply use PayPal.com with info @ revitrev.org - as given in the tools' 'notes'...
                                          PS: miss out the two spaces - they're added to try to foil spambots!
                                          [I know it's a crap account-name... but I also write stuff for 'Revit' 🀒 - they do pay more money = no one wants the pain πŸ˜’ - but I love SUp most πŸ˜„ ]
                                          PPS: Thanks for the recent donations πŸ˜„
                                            dtrarch
                                            Sir TIG
                                            Got it and thx πŸ‘
                                            dtr
