    [Plugin] FredoTools::MarkVertices - 1.2a - 20 Jul 11
    16 Posts 6 Posters 29.2k Views 6 Watching
    • GaieusG
      It is really great when it comes to welded curves (like circles or arcs and such) because displaying endpoints on them does not work with styles.
      Thanks a lot - again - Fredo! πŸ‘
        3dvisual
        Good idea thomthom, thanks!
        But, not align in the center!
        Am I wrong somewhere or a problem with the plugin Insert Components at CPoints?
        • GaieusG
          I don't have that plugin but I can imagine that you need to adjust the component axes so that the component origin is in the component's centre.
            As Gai says... the vertex marker component needs its origin at its center.
            Also using a 'sphere' adds a lot more geometry to the model than a cube would - you could also perhaps add code to orient the cube with the face vertex normal if available but that would be convoluted to write...
            Also that component needs to be made to not cast/receive shadows etc to make it have less impact on the processing/rendering...
              Correct.
              • GaieusG
                Now I would also like to "imagine" what the lottery numbers are going to be here at the week-end. (It will be more than € 6.1 million or $ 8.7 million here...) πŸ˜’
                  3dvisual
                  Lottery numbers ... It's easy 2,9,18,24,35, ... πŸ˜† (€ 6.1 million )
                  Planimetry and stereometry (3D geometry) is a bigger problem πŸ˜’
                  Thanks for your solution, component axes it was the right solution.
                  Maybe someone knows, how to get from a regular line dashed line? (but without smustard.com DashedLines script - I do not have Paypal). Thanks again!
                    2Dtools 2D LineStyle ?
                      3dvisual
                      I tried.
                      But, does not match.
                        @3dvisual said:
                        I tried.
                        Does not 'match' what ??
                          3dvisual
                          Sorry for my English, Google translate does not translate always correctly!
                          2D lines is in 2D space, I need a full 3D space.
                          All lines should be viewed from all angles!
                          I try to show problems from stereometry in full 3D space, interactive.
                          SketchUp is a great tool for working in 3D but for use in mathematics there is no option for point, line width, line styl and color.
