    [Plugin] Pen Tool +
    126 Posts 40 Posters 101.1k Views 40 Watching
      Look for a folder called 'rob_hsltool'
      The 'Draw' menu contains the modes of drawing also
      • boofredlayB Offline
        boofredlay
        Not there that I can see. Weird. Here is my plugins folder and a screen shot of the toolbar active.
          Any chance that's your SU7 Plugins directory?
            boofredlay
            Nope, I checked and the folder you see is here:
            C:\Program Files (x86)\Google\Google SketchUp 8\Plugins
            This is my SU7 Plugin folder.
              What's in that zipped PenTool folder?
                boofredlay
                Well that is what I downloaded from the first post in this thread. I can delete it from the plugins folder and I still get the pen tools to show up when I start SketchUp. They have to be referenced somewhere I just don't see it. I even did a search on the computer and they don't show up either. Maybe if I restart my machine it will go away???
                Odd.
                  Well I'm the wrong gut to ask. I probably contributed to 5-10% of the earlier part of this plugin. I'm not blaming TIG for this behaviour but maybe he can shed some light on this?
                  I can't see how this can happen because the .rb clearly states to look in the 'rob_hsltool' folder for the toolbar icons. You have neither in your Plugins folder? Have you 'show hidden files' enabled? In case you accidentally hid them πŸ˜•
                    boofredlay
                    Yep, show hidden files is on and after restarting and not having the zip file, the ruby file or that image file folder in the computer at all I still get the pen tools showing up.
                      Eric, that's very weird. πŸ˜•
                        boofredlay
                        I know right!?
                        One thought, since I am on a network here it might have been installed somewhere other than my machine and is pointing there...? Just a thought.
                          schnydix
                          Great Pen Tool Thanks for this nice work
                          Can you integrate an constr. Point
                            Yes, v1.4 will have this and another tool πŸ˜’
                              Pen Tools + v1.4 updated with 2 new tools and some bug fixes.
                              For latest version go here
                              EDIT: I corrected this link, TIG
                              [get a direct page link from right-clicking over the small 'post' icon under the post's title, and not from the top-bar html which leads to the page of posts containing the post]...
                              • H Offline
                                hebeijianke
                                weld draw error message
                                Error; #<NoMethodError; undefined method `GetString' for nil;NilClass>
                                F;/Google SketchUp 8/Plugins/PenTool+.rb;771;in `activate'
                                F;/Google SketchUp 8/Plugins/PenTool+.rb;1802;in `select_tool'
                                Error; #<NoMethodError; undefined method `add' for nil;NilClass>
                                F;/Google SketchUp 8/Plugins/PenTool+.rb;756;in `getExtents'
                                  From starting to use the tool? From performing certain actions?
                                    That sounds like a language-handler issue - do you have the standard files like sketchup.rb and langhandler.rb in the Tools folder ?
                                    If you type [copy+paste] $exStrings in the Ruby Console it should return this
                                    #<LanguageHandler;0xb7d5f2c @strings={"Select first end"=>"Select first end", "Point at Center"=>"Point at Center", "Box"=>"Box", "Create Box"=>"Create Box", "Material"=>"Material", "Adds examples of tools created in Ruby to the SketchUp interface.  The example tools are Draw->Box, Plugins->Cost and Camera->Animations."=>"Adds examples of tools created in Ruby to the SketchUp interface.  The example tools are Draw->Box, Plugins->Cost and Camera->Animations.", "Select By Material"=>"Select By Material", "Select By Layer"=>"Select By Layer", "Select second end"=>"Select second end", "Box Dimensions"=>"Box Dimensions", "Cost"=>"Cost", "Total Cost Estimate"=>"Total Cost Estimate", "Stop Spinning"=>"Stop Spinning", "Spin View"=>"Spin View", "Animations"=>"Animations", "Default"=>"Default", "Assign Estimate to Material"=>"Assign Estimate to Material", "Cost Estimate"=>"Cost Estimate", "Ruby Script Examples"=>"Ruby Script Examples", "Layer"=>"Layer", "Width"=>"Width", "Compute Estimate"=>"Compute Estimate", "Assign Estimate to Faces"=>"Assign Estimate to Faces", "Hide Rest"=>"Hide Rest", "Depth"=>"Depth", "Height"=>"Height", "Cost By Material"=>"Cost By Material", "Create Cylinder"=>"Create Cylinder", "Could not find Material named"=>"Could not find Material named", "Cost per sq. foot"=>"Cost per sq. foot", "FPS"=>"FPS"}>
                                    If not then that's the issue... not this actual tool per se, but your setup πŸ˜•
                                      SketchUpNoobie
                                      @tig said:
                                      type $exStrings in the Ruby Console
                                      Seriously though, thanks for the update Rich. Construction points should be nice.
                                      SketchUpNoobie: the complete noob in all things SketchUp.
                                        Unfortunately ' $exStrings' is what @Last/Google decided to call it years ago πŸ˜„ πŸ˜’
                                          nothing like a bit of nostrings$ex πŸ‘
                                            Ben Ritter
                                            Rich, thank you very much. By the way, why was the pen to draw an edge with a face included,if it does the same thing as the line command?
                                            Ben
                                            • 2 / 7
