    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 450.2k Views 172 Watching
      gaonirico
      @thomthom said:
      @gaonirico said:
      Mnn, maybe two errors: the first
      quietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledERROR: skpHelperClasses.rb:updateSkpMaterial, unable to find a material called: Ivyleaf_21
      ... the second and but notable is that not takes me the changes of parameters in the menu
      That is a V-Ray for SketchUp error. What version do you have installed?
      Im use Sketchup 8.0.4811 and Vray 1.49.00
        Not sure if it'll solve this error, but the latest version is 1.49.01.
          tulacong
          @pierreden said:
          After playing with "An Ivy Generator"(found here) I thhought about how awesome it would be to be able to play with something like this directly in Sketchup. I therefore started to port the ivy generator to ruby and Sketchup. As i now have working code with regards to the main parts of the algorithm, collition detection, adhesion and the growing of the ivy branches, i decided to post a proof of concept.
          Usage
          -Select "Sketchup Ivy 0.5" in the Plugins sub-menu
          -Adjust Parameters in Menu
          -Every time you click your left mouse button, the ivy will grow
          -CTRL-Click for leafs (repeat as many times you want)
          -When you're happy with the ivy Shift-click to make it into actual volumes.
          http://i.imgur.com/eSwjM.jpg
          VERSION 0.5
          UPDATE 09.05.2011
          • Will now use components with "ivyleaf" in the name as leafs. 3 included by default.
          • Hopefully better mac support πŸ˜’
          • Small algorithm changes πŸ‘
          • ALT+click to make ivy grow towards pointer
            - Thea users: uncheck 'export as components' before exporting. (Thanks Solo)
            Fix 0.5.2
          • Tool startup fix (maybe?)
          VERSION 0.3
          UPDATE 05.05.2011
          • Simple gui. (More parameters to come)
          • Leaves
          • Speed and reliability
          • I know theres some issues with mac. As i haven't had the opportunity to debug on a mac, im not sure if its working now. Mac users with issues are very welcome to PM me or write here. (Guess this goes for everyone with issues, im sure there is lots πŸ˜’ ).
          VERSION 0.1.5
          UPDATE 28.04.2011
          [Uploaded buggy file !! Sorry]
          • Added Wind (comming from the position of the sun atm)
            -Bug fixes
          VERSION 0.1
          UPDATE 27.04.2011
          • Faster Preview
          • Better Ivy "Resolution"
          • Faster and more reliable volume generation (less buggsplats?)
          • Face normals should now be oriented correctly
          • More reliable collision detection
          • A few bugs in the force algorithms fixed.
          • Works as before. Edit the values in Plugins/SketchupIvy/setup.rb πŸ˜‰
          TO COME
          • Leaves as Components
          • More Parameters and grow patterns.
          • Other Plugins. Fur, Cloth and Tree.
          Notes
          • Never shift-click when there is more than 150 branches (information in the ruby console). This will often cause a bugsplat (seems like sketchup realy, realy, realy doesn't like programmaticaly adding of entities or seemingly infinit loops πŸ˜• )
          • For the adhesion to work, you have to be in the same scope (i made this to clearify (face.classify_point seems buggy)
          • This script has only been tested in SU8. As far as i know this script might cause bugsplat infernos and generally fuck shit up in other versions
          • If you find any bugs or problems please PM me πŸ˜‰ If you're extra awesome attach the error description from the ruby console.
          Any suggesions, comments or crits are very much welcome!
          Peace
          Pierre
          thank you very good
            Pierreden
            Completely delete previous versions from the plugins folder and install the new 0.5.4
            • PixeroP Offline
              Pixero
              I can't get leaf size to work in the latest version.
                driven
                mostly works on the mac here.
                if key == 105 #i as in ivy, isn't an english SU shortcut key and works...
                  gaonirico
                  I installed the version 0.5.4 but from the previous version 0.3 the menu not shows correctly and function the change of parameters. Happens because my monitor functions only to 800x600? or I must have installed some update of internet explorer?
                  This is the menu of SketchupIvy showed in my screen
                    dbalex
                    thanks! You're updating this plugin faster as hell! It's a nice improvement to have the stem (circle) made with more segments but maybe you should let the user choose between 3 and more, so we can keep the polycount low for big ivy walls.
                    anyway thanks for your hard work, this plugin IS epic!
                    http://www.bocostudio.com
                      JeZ
                      After I do shift+click I get either nothing or :
                      Error: #<TypeError: reference to deleted Group>
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:236:in entities' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:236:in birth_stem'
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:234:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:234:in birth_stem'
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:223:in birth' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:98:in onLButtonDown'
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:251
                      I have win7.
                      edit
                      This is when using 0.5.4 I have not tried other versions yet.
                      edit2
                      Ok I understand now that I need a leaf material. Sorry...
                      Then, the pluggin cant find now the stem material and stops after the first path and circle.
                      Hope this helps.
                      Jerome
                        Pierreden
                        @pixero: Its working now πŸ‘
                        @driven: Thanks for the tip! reset button is now "i" πŸ‘
                        @gaonarico: I dont know im afraid. It might be a javascript issue, if so, updating you IExplorer might help. But this problem is noted and i really hope to solve it soon.
                        @dbalex: Thank you man! glad you like it! You are right about the profile segments. I've added a parameter "branch detail" which sets the number of segments of the main branch. πŸ‘
                        @oxer: Good to see its working! πŸ‘
                        Peace out
                        Pierre
                        • KrisidiousK Offline
                          Krisidious
                          can Fredo's "Check Plugins for Update" be added to this?
                          404 Not Found
                          (forums.sketchucation.com)
                          By: Kristoff Rand
                          • PixeroP Offline
                            Pixero
                            Hmm...SHIFT+left mouse click doesn't finish the Ivy in 0.6 for me?
                              Pierreden
                              404 Not Found
                              Good idea. Will look into it.
                              Hmmmmm.... Weird. Cleaned up the code abit. Try the new 0.6.2. πŸ‘
                              • PixeroP Offline
                                Pixero
                                Sorry. 0.6.2 doesnt finish for me either. 😞
                                Interesting to hear if I'm the only one with this problem.
                                • soloS Offline
                                  Works for me, but pressing 'Y' does not reset for me.
                                    Pierreden
                                    @solo: Its "i", not "y".
                                    @pixero: I dont got this problem either. maybe you have some conflicting plugins installed. I suppose there's no messages in the console?
                                    • srxS Offline
                                      srx
                                      Me too...doesn't finish in 7.1, but in SU 8 it does...all the plugins are in 7.1 folder, so it could be conflict.
                                      THANK YOU! GREAT PLUGIN!
                                      Here is the problem:
                                      Error: #<NoMethodError: undefined method -' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:241:in birth_stem'
                                      C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in each' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in birth_stem'
                                      C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:223:in birth' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:99:in onLButtonDown'
                                      www.saurus.rs
                                      • OxerO Offline
                                        Oxer
                                        I have probed 0.6.2 beta on Mac and don't works, i have uninstall all plugins perhaps there was some conflict and it don't works.
                                        The previous version 0.6.beta works on Mac but the leaf are very small and i don't know change the size of the leaves.
                                        One question, on Pc the "i" key is = 73 but on Mac "i" key is =105, can you make a different between "i" key on Mac and Pc.
                                        Thanks Pierreden for your incredible work!! πŸ‘
                                        Problem with size leaves on Mac
                                          autarchos
                                          shift+click does not finish here in SU8 Windows...
                                          also having a hard time getting ivy to grow with successive clicks, sometimes it appears, sometimes it disappears, sometimes it grows "inside" boxes, usually doesn't grow past two or three clicks.
                                          nevertheless, the plugin is looking great and keep up the fantastic work!
                                          • PixeroP Offline
                                            Pixero
                                            I just tried on a different computer and it's the same. Doesn't finish. SU 8 Windows 7.
                                            I also have another problem, and that is that even if I click several times it still wont branch.
                                            Just one single "curve". Also it disappears completely after some clicks.
                                            Didn't have a problem with earlier versions.
                                            • 36
                                            • 37
                                            • 7 / 37
