    [Plugin] Selection Toys
    594 Posts 121 Posters 504.0k Views 121 Watching
      Mra
      @thomthom said:
      Can't seem to turn off the "Edge loop" button, it is stuck!?
      It's a tool, the button stays down for as long as you use the tool. Activate another tool and the button goes back to its original state.
      Sorry for the late respsonse, but thanks for the reply!
        JPMays
        I'm really having trouble figuring out to use this tool, but please forgive my ineptitude. I first downloaded and installed this in order to select all faces that are at a certain orientation (as Thom lists in his initial post). However, I can't figure out how to actually do that. Additionally, even attempting to use the tool that selects all faces doesn't appear to work. what am I doing wrong/how do i select faces with a particular orientation?
        Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
          • Select a face
          • Right-click the face
          • Select > Coplanar Faces
          There is no function to select all faces. There is a function that filters out the current selection to include only the selected faces.
            JPMays
            That's not exactly what I meant. See this thread http://forums.sketchucation.com/viewtopic.php?f=79&t=35393 that resolved the issue.
              TheButtersShow
              πŸ‘
              Thanks! A Great Plugin.
              For my purposes most useful for digging through nested Components and groups and selecting only the particular entities I need without the time consuming process of having to explode or enter the context of every single one.
              πŸ‘
              • 66searcher6 Offline
                66searcher
                @ thomthom:
                thanks for your great plugins.recently I've installed Sketchup 8 pro .and i have some kinds of problem with using selection toys ! many tools in toolbar are not loaded?!
                would u help!?
                http://hamidtoliat.deviantart.com/
                  Do you get any error messages?
                    66searcher
                    πŸ˜‰ i found it out !
                    i haven't checked tools in UI ! πŸ˜„
                    thank u anyway πŸ‘
                    • Al HartA Offline
                      Al Hart
                      I have a suggestion for carrying over the name of the group as the name of the component definition as well:
                      The last three lines in this snippet:
                      		# Iterate through the rest of the copies
                      		protodef = proto.definition
                      		if (group_name != "")
                      			protodef.name = group_name
                      		end#if
                      It seems to work pretty well, and SketchUp adds #'s as needed to make the name unique.
                      Al Hart
                      IRender nXt from Render Plus
                        I'll make a note of that. πŸ‘
                          danbig
                          I think I'm still missing something simple on how to operate this incredibly helpful plugin.
                          I have a model with hundreds of instances of multiple components. I want to select all the instances of a single component definition. I cannot seem to get the plugin to do this; can someone go through the steps to perform this function?
                            Dan, this doesn't help you with the plugin I know but for something like what you want to do, couldn't you just right click on the component's thumbnail in the In Model component library and and choose Select Instances?
                              With the plugin, you should just right click on one instance and go to Instances > Select all or active (it can select instances even inside other components/groups)
                                danbig
                                Hi Dave -
                                Yes, that would work. Thanks for the tip. I haven't used the component library to browse components in my model very much, so I wasn't aware of that function.
                                Gai - that's exactly how I'm trying to use the plugin, to no avail. I'm stumped.
                                  FWIW, Csaba's directions work for me but using the Components tool on the Selection Toys toolbar doesn't seem to do anything.
                                    Can you provide a sammple model and/or video?
                                    Any errors in the Ruby Console?
                                      Maybe I'm using it wrong Thomas. I've tried selecting a component which I know has more than one instance. Then I click on the tool with the two green boxes. Nothing changes. I've tried getting the tool first and then clicking on a component. Nothing different there, either. I'll send you an example model though.
                                        That button is to filter the selection.
                                        To select similar instances, use the context menu.
                                          Thanks Thomas.
                                          • leedeeteeL Offline
                                            leedeetee
                                            Could someone help me with this ...
                                            I'm trying to get the Selection Toys to work, I have the following fodlers in Plugins:
                                            TT_Lib TT_Lib2
                                            and then also tt_selection_toys in there, too.
                                            SU loads up fine but then nothing is shown in the plugins.
                                            What am I doign wrong?
                                            Thanks.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 29
                                            • 30
                                            • 19 / 30
