    [Plugin] Trace Ruby messages
    13 Posts 7 Posters 13.0k Views 7 Watching
      sahi
      šŸ‘ Thanks
      PS: Error a line 25 Dir.mkdirsdir >>> Dir.mkdir sdir
        @sahi said:
        :thumb: Thanks
        It's even better as Dir.mkdir(sdir) - then you don't those kind of typo make mistakes...
        It's also the future-proof coding method - the 'without-parenthesis' method might be deprecated soon...
        • Al HartA Offline
          Al Hart
          @sahi said:
          :thumb: Thanks
          AArrggh: 😔
          Thanks sahi and thanks TIG
          Al Hart
          IRender nXt from Render Plus
            sahi
            Thanks TIG.
              sahi
              Sometimes it is necessary to compare as was and as became
              It is possible to add here such code
               ffile1 = "c;\\tmp\\1_ruby_trace.txt"
                   if(File;;exists?(@sfile))
                     if (File;;exists?(ffile1))
                        File.delete(ffile1)
                      File.rename(@sfile, ffile1)
                   end #if ffile
              • fredo6F Offline
                Al,
                You should make your code portable on Windows and Mac
                tmpdir = (RUBY_PLATFORM =~ /darwin/i) ? "/tmp" ; ENV["TEMP"]
                @sfile = File.join tmpdir, "Trace_Ruby.tmp"
                This also avoids calling mkdir (since the tmp directories always exists)
                • Al HartA Offline
                  Al Hart
                  I'll make the change.
                  The only thing I hate is that it is often difficult to find the real temp folder on Windows,
                  Typing in %TEMP% in Windows Explorer will find it, but I don't know if everyone knows that.
                  Al,
                  Al Hart
                  • Al HartA Offline
                    Al Hart
                    Your script is working great for me! Just that timestamp needs to be logged with each console message.
                    I made a version with an optional parameter which will show the date and time for each message.
                    The new version is in the initial post for this thread.
                    # comment one of these out to add time to traces
                    @show_time = true
                    #@show_time = false
                    Here is output with timestamp:
                    Console messages from: !trace_console.rb
                    Sun May 01 23:14:29 2011
                    SketchUp Version: 8.0.4811
                    Sun May 01 23:14:29 2011: -----
                    Sun May 01 23:14:29 2011: Console messages are going to c:\tmp\ruby_trace.txt
                    Al Hart
                      driven
                      Hi Al,
                      I've been using this on a mac since you first posted it.
                      It took a day to find the .tmp file even though I always have hidden 'off' by default.
                      so I named your script auditMac.rb, made a plugins/folder put an empty text file in it like so.
                      @sfile = "/Library/Application\ Support/Google\ SketchUp\ 8/SketchUp/plugins/audit_mac_ruby/audit.txt "
                      it works great I drop auditMac.rb in the folder when I'm not having problems and put it out when needed.
                      your script just updates from the previous, so I just pull of copies if I need a log. I also park suspect rubies in the folder if I'm trouble shooting...
                      easy to find and use
                        Finding a suitable 'temp' folder location is easy...
                        tdir=ENV["TEMP"] tdir=ENV["TMPDIR"]if not tdir ### it's a Mac ?
                        So 'tdir' is the path to the 'temp; directory for that user...
                        To make the full path to a temporary file use...
                        tfile=File.join(tdir, tfilename)
                          dburdick
                          Very nice workin indeed Al. I'm still having issues re-directing error output to the log file. It seems as though Sketchup does not use stderr for error output. I've had some success just trapping messages in the Excpetion class StandardError but this is clumsy.
                            maricanis
                            I'm using latest version (from may 2011) and noticed strange problem.
                            When I have plugin wxSU installed and !trace_console.rb, while Sketchup is running - no problems, and CPU usage is as expected.
                            When I try to exit Sketchup,SU window is closed but Sketchup.exe process is not finished, and it uses maximal CPU load (when checked in TaskManager).
                            If only one of these 2 plugins wxSU and !trace_console.rb is installed Sketchup process is ended without problems.
                            It seems that writing to text file is blocked for some reason, and trace file can't be closed.
                            I'm using SU 7.1 and 8, on Windows 7.
                            Marija
                            With your input, this post could be even better šŸ’—
