    HELP!! Building cabinets.
    18 Posts 10 Posters 3.0k Views 10 Watching
      STONEPLANET777
      what is it that you need to know? i design furniture with su8 and i haven't been using sketch up for a real long time but i do know how to create a board to size and move it and place it. i never get any feed back from anyone in this forum and i was reading the posts and i came across yours. believe me when i say that i do understand your frustration. every thing i've learned, i learned with no help from anyone; it's not that i didn't want help...it's just that no one ''would'' help me.i finally gave up asking for help and decided that if i was going to learn this, i was on my own. i've spent several months staying awake into the wee hours trying to learn as much as i can in su8 and it has been very stressful at times but i'm doing it now, no thanks to this stinking forum. my email is [removed] and i'll help you if i can or i can at least tell you what i know. bruce
        @stoneplanet777
        I removed your email from your post in case spammers get a hold of it. Think before your type πŸ˜’
        If anyone want to contact Bruce(stoneplanet777) I'd advise PM'ing to sort out contact arrangements.
          Dropout
          Can't find the thread, but look for Cabinet Sense here somewhere. It's a great way to build cabinets with Sketchup. It'll give you all the cutlists you need.
          • honoluludesktopH
            honoluludesktop
            @serpentine5 said:
            ..........it will not snap into place like all the videos I have watched do. It intersects the side and passes through or it wants to align in another position than what I want. I am not sure how to make these pieces "snap" together. .........
            Too lazy to read all the posts. Did you get your answer? If not, when you create a cabinet panel as a component, select glue to "any". Then when you insert or move a component it will snap to another.
              serpentine5
              Thanks for the replies. After I made my post last night I found the Sketchup For Dummies videos on boobtube. After watching about 2 hours of video I learned the trick of grabbing the board by the corner and mating it with the corner you want it to touch to get perfect alignment. On parts that dont have a corner, I learned to use the measuring tape to make a mark and then match the corner to the mark.
              I was able to get my cabinet together. I need to figure out my doors now, but I have it completed.
              I am not sure if this is the place, but I would like to upload it here to get opinions of the way I did it. Not of the construction itself, but of the way I used sketchup.
              Let me know if I can do that here.
              Also, what is "situ"?
                You can indeed upload your models here and I'm sure a number of folks would be happy to take a look and offer constructive suggestions.
                "in situ" means in place. If you looked at the videos I liked to, you'll see that I use that method when I draw furniture. In the case of the fern stand, after drawing the leg component, copying it and placing the copies every other part is draw in situ using the parts that are already drawn as references. As I said, this helps to reduce errors. It also eliminates the need to know a lot of dimensions ahead of time. Again, using the fern stand example, after the legs are in place, the aprons need to be drawn to fit. Beyond that, I don't really care how long they are until I'm ready to make the cutlist and then I have SketchUp tell me how long they are.
                If you don't follow that method but rather draw the parts separately, you will need to know or figure out all of the dimensions of every part. This is more time consuming and more prone to errors.
                  serpentine5
                  I will have to try everything in place my next time round, but this time, I already had everything on paper, and I wanted to do this to find and correct any measurement errors i had, which I did find some and was able to correct them... Now all I need to do is go to the store and buy all the materials I need and get to work. I didnt find any hinge or knob tools so I just put the doors in place and made a knob on the door before copying it.
                  Tell me what you all think of it, and how I could have done it better and or easier.
                  Completed Cabinet 001.skp
                    mac1
                    This link also has a good step by step tut on building abed side table http://www.srww.com
                    One thing that came to mind is make sure you have snapping turned off, this maybe a contributor to problems depending on how you are handling inferencing
                      Overall your model looks pretty good. I didn't check it in real detail but it's not bad.
                      As to hinges and knobs, you can likely find those on the 3D Warehouse. Open Window>Components and where you see the word Google, search for 'hinge' or 'knob.'
                        serpentine5
                        After I saved the cabinet file last night, I closed out SU, and today I opened it to make a few attempted modifications, but when i told it to open the file, it tells me that the file is locked by another user and asks if I would like to open it in read only format.... How do I open it back up where I can have full control of it? and why is it doing this? is this because I didnt "log" into google and sign it?
                        • honoluludesktopH
                          honoluludesktop
                          The message results from control of your model by another application or user. Are you sure that you closed SU? Look at your start bar to see if there is another instance of SU open. If none, and you are on a network, someone else may have the model open. If not, perhaps rebooting may help.
                          If you answer yes to the message, and open to read only the model, you can "still as" any modifications you make to it by changing its name.
                            serpentine5
                            No one else on my network... no other SK was opened. it may have stayed open in the processes... rebooted and it opened fine.
                              A reboot! - that usually works...
                              If it doesn't [which rarely happens - just now and again] there are free tools - 'unlock[er]' - that will force the system to release the file that's messed up - although sometimes it might require a restart anyway...
                              Be wary as many 'unlock[er]' related downloads are loaded with Malware - but this one seems OK http://emcosoftware.com/products/unlock-it/download.php
