    How to get dimensions parallel
    layout
    26 Posts 9 Posters 6.8k Views 9 Watching
    • bazB Offline
      baz
      Been following this thread for a while to see what you guys might come up with, I get myself tied in knots with dimensioning sometimes..... GO DAVE... a workaround that works.
      I'd like to know more about peoples' workflow with dimensioning, for example Dave, do you have a post or FW blog yours?
      ps: I'd love a ruby that put dimensions on their own layer by default.... wait! there it is!!! πŸ˜›
        Barry, thank you.
        I guess I haven't done a blog post specifically on dimensioning but I could. Since dimensioning became available in LO, I almost never use SketchUp's dimensioning tool. As far as my work flow in LO, I generally get all my views set and then start on the first page and insert dimensions where I need them. I try to go through one layer's worth of stuff before doing something else to avoid errors. So my SU views are on one layer, dimensions on another, leader text on a third and so on. I end up going through the document several times but at least I generally get like things on the same layer. I wish layer management was like SU's with the ability to move things to a layer without having to make that layer active.
        • bazB Offline
          baz
          Dave. Totally agree about clunkiness of layers in LO. (and most of the rest of it actually).
          I note you are a believer that boulder will get it betterer in next V, I fervently hope so.
          I use it exclusively for any presentation now, tho sometimes I give up and edit in Fireworks or PS to get rid of, for example, pesky dim lines which interfere.
          Be great if you did a dim blog post.
          Here's hoping the planet has a great easter, which, for alien visitors, is the time when we celebrate the life and death of a great man, and the possibilities and potentials of our planets' race's getting it's act together.
          baz
          • bazB Offline
            baz
            whoops
              Thanks for the suggestions. I'll work on them.
              It does seem like you have a bit of an apostrophe catastrophe going on. πŸ˜„
              • bazB Offline
                baz
                πŸ˜„
                You are too far cleverer than your own good(one).
                G'nite.
                  bjanzen
                  Ah, I see. Thanks Dave. So you're trying to get dimensions in LayOut to match dimensions in SketchUp.
                  b
                    Hi Barry, no. I don't really care about matching LO dimensions to SU dimension. I don't use SU dimensions if I'll be going to LO for the final product. I prefer the control I have over line thickness and arrowhead size as well as arrowhead style in LO. What I would like to see is LO's dimensioning tool being able to do is match the perspective in the SU view. That's a plus for SUs dimensioning tool which I end up faking in LO by using the guidelines as I showed.
                    • EdsonE Offline
                      Edson
                      @dave r said:
                      I set out some guidelines in SU and dimension between intersections. I set the dimension right at the intersections of the guidelines. Then I explode the dimension, delete the extension lines, draw new ones tracing along the guidelines to get the angles right and I turn on fill for the dimension text box. The dimensions are shown correctly so I don't have to edit the text.
                      http://farm6.static.flickr.com/5223/5639925443_16359f0240.jpg
                      dave,
                      forgive my thickness but I cannot follow some of your steps. how do you explode a dimension? Iright -clicked on it and there was nothing like explode on the contextual menu.
                      http://www.mahfuz.arq.br
                        Edson, I am exploding the dimension in LayOut. You should have that option available to you. In case I wasn't clear, I am not using the dimensioning tool in SU at all. I use the guidelines in SU to assist in placing the dimension in LO.
                        • EdsonE Offline
                          Edson
                          I came back to this topic as I needed refreshing on LO dimensions only to conclude once more that LO dimensions badly need to be revamped. it is fine to dimension 2D stuff but dimensioning a 3D view is a nightmare, dave's workaround notwithstanding..
                          let's hope the sketchup people under trimble will take LO ahead.
                          • 2 / 2
