    [Plugin] Align tool 3D (bug fix)
    58 Posts 38 Posters 155.4k Views 38 Watching
    • Didier BurD Offline
      Didier Bur
      Edson,
      You've understand ALL (and explained it clearly too).
      DB
        Magnus123
        Ohh Thanks Didier this will come veeeery handy for me!
          SU Reviewer
          Great plugin! I have been l;ooking for something like this
          At first it was tough to use but I got used to it. I made a little instructional animation enjoy..
          http://sketchuppluginreviews.com/wp-content/uploads/2010/05/align_tool.gif
          Living Einstein's dream through SketchUp.
          "Imagination is a preview of life's coming attractions" - Albert Einstein
          Joe Simhon ~ SketchUp Plugin Reviews
            Design Tech
            I am trying to install the Align tool in sketchup pro 7 on a mac. I followed the simple instruction in the PDF file but still cant seem to get it to work.
            What am i missing here, or what am i doing wrong?
            I put the file in my plugins folder and restarted sketchup, but dont see where the tool shows up to use?
            please help
              Didier Bur
              Doc says: "...you'll find a menu item under the "Tools" menu",..."if you select some entities and right-click, you'll find an "Align" option in the context menu, "if you select a group or a component and right-click, you'll find an "Align group/component" option in the context menu".
              So if you don't have any of these opttions in your menus, there is something wrong.
              Please open the Ruby Console and type: $align_loaded (Enter)
              Please report what it says then.
              Regards,
              DB
                Panoplos
                Hello Didier,
                I am also trying to install this on the Mac Version of Sketchup Pro 7. The plugins folder contains files with extensions of .plugin, not .rb. I tried both using the .rb and .plugin extensions with no luck.
                When typing $align_loaded in the Ruby Console, the variable is nil.
                Perhaps there has been some change the to plugin format in version 7?
                I am looking forward to using this tool, so your support is much appreciated!
                • jeff hammondJ Offline
                  @panoplos said:
                  Hello Didier,
                  yikes panoplos, you're in the wrong spot..
                  if your 'plugins' folder is showing .plugin files then you're at
                  applications folder > sketchup.app > (show package contents) > contents > plugins..
                  that's the actual app and those 'plugins' are the file importer/exporters..
                  ruby plugins go here:
                  Macintosh HD> Library> Application Support> Google SketchUp (#)> SketchUp> plugins
                  try that out instead.
                  • I Offline
                    irsa
                    thank you so much, its so useful
                    • simon le bonS Offline
                      simon le bon
                      Hi!
                      until Joe Simhon showed how "Align Tool 3D" was working I hadn't noticed its interest..
                      Playtime:
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/170px-Rhombictriacontahedron.gif
                      A rhombic triacontahedron consists of 30 golden rhombus perfectly identical. This Quasicrystal (Quasicrystals discovered in 1984) has been many fears for crystallographers because some had seen as a crystal with a symmetry of order 5, which is not like any self-respecting crystallographer knows!
                      Quasicrystal - Wikipedia
                      (en.wikipedia.org)
                      Golden rhombus - Wikipedia
                      (en.wikipedia.org)
                      Rhombic triacontahedron - Wikipedia
                      (en.wikipedia.org)
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/GoldenRhombus_th.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/RhombicTriacontahedron_02_th.jpg
                      [flash=640,480:2rhrdrml]http://www.youtube.com/v/qjuIm6Bd33s[/flash:2rhrdrml]
                      ++ simonlebon
                        Indispensable as soon as you have some objects who are not regulary oriented! πŸ˜‰
                          alexdobras
                          thank you !
                            jbrfrk
                            really useful.... thanks
                            πŸ‘
                            J=K
                            • archman212A Offline
                              archman212
                              fantastic..i have been looking for this one... πŸ‘
                              archman212@gmail.com
                              • O Offline
                                Omez
                                THANK YOU! πŸ‘ πŸ‘ πŸ‘
                                I even not trying it yet, but i believe its very useful... once again, Thanks! πŸ˜„
                                • john2J Offline
                                  john2
                                  couldn't understand 4m the pdf. 😞 is there any video tutorial πŸ˜’
                                  Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                    Didier Bur
                                    Yes here: http://sketchuppluginreviews.com/2010/06/01/align-tool-google-sketchup-plugin-review-2/
                                    Google is your friend πŸ˜‰
                                    DB
                                    • kenK Offline
                                      ken
                                      Didier
                                      Not asking anything to be changed, however it took me some time to determine that what you call the "X axis" and "Y axis" can be any particular orientation. I was always trying to determine what the "X and Y axis" were while using the plugin. Lead to much frustration.
                                      I always wanted to be able to get inside the plugin and change the "X" to "1" and the "Y" to "2". To me that would have been more logical to remember, I wanted the "1's" and "2's" to align with each other.
                                      Thank you for your contribution.
                                      Ken
                                        Didier Bur
                                        Hi Ken,
                                        You can also think that X represent the red axis, Y the green axis, just as when you locate/translate/rotate the SU axis system.
                                        DB
                                          raineysky
                                          Ken,
                                          πŸ‘
                                          I really like your idea too because I'm not use to the "x,y,z" language yet. Just now getting orientated in the 3d space πŸ˜„
                                          Thank You for the plugin Mr. Didier Bur.
                                            kevinbearshu
                                            Thank you very mach!
                                            • 1 / 3
