    [Plugin] Align tool 3D (bug fix)
    58 Posts 38 Posters 154.1k Views 38 Watching
    • EdsonE Offline
      Edson
      @watkins said:
      Dear Didier,
      I cannot seem to get the "Align Group/Component" option to work properly from the right-click context menu. The "Align" option works fine. When I try the "Align Group/Component" option the script first toggles on the group/component axes and then sets the starting co-ordinate system co-incident with the axes of the selected group/component(no choice given). It then asks one to define the end co-ordinate system. I was expecting to define the start co-ordinate system, as per your user guide. Also, in this mode I have to toggle off the group/component axes by going to Model Info and then deselecting the component axes option.
      Is this how you intended the script to work?
      Regards,
      Bob
      bob,
      i also wondered about that but later realized i was not 'working properly'. in many cases all you need is to set the ending system; in this cases go for align group/component (as it takes the axis alignment of the group/component as the origin system); it saves you half of the work involved in the process. in cases when you do need to set the origin, then choose align and set both systems. does it make sense to you?
      http://www.mahfuz.arq.br
      • W Offline
        watkins
        Dear Edson,
        Yes, that does make sense. It also makes me think more carefully about the axes when creating a component.
        Thanks for your interest.
        Kind regards,
        Bob
        • Didier BurD Offline
          Didier Bur
          Edson,
          You've understand ALL (and explained it clearly too).
          DB
            Magnus123
            Ohh Thanks Didier this will come veeeery handy for me!
              SU Reviewer
              Great plugin! I have been l;ooking for something like this
              At first it was tough to use but I got used to it. I made a little instructional animation enjoy..
              http://sketchuppluginreviews.com/wp-content/uploads/2010/05/align_tool.gif
              Living Einstein's dream through SketchUp.
              "Imagination is a preview of life's coming attractions" - Albert Einstein
              Joe Simhon ~ SketchUp Plugin Reviews
                Design Tech
                I am trying to install the Align tool in sketchup pro 7 on a mac. I followed the simple instruction in the PDF file but still cant seem to get it to work.
                What am i missing here, or what am i doing wrong?
                I put the file in my plugins folder and restarted sketchup, but dont see where the tool shows up to use?
                please help
                  Didier Bur
                  Doc says: "...you'll find a menu item under the "Tools" menu",..."if you select some entities and right-click, you'll find an "Align" option in the context menu, "if you select a group or a component and right-click, you'll find an "Align group/component" option in the context menu".
                  So if you don't have any of these opttions in your menus, there is something wrong.
                  Please open the Ruby Console and type: $align_loaded (Enter)
                  Please report what it says then.
                  Regards,
                  DB
                    Panoplos
                    Hello Didier,
                    I am also trying to install this on the Mac Version of Sketchup Pro 7. The plugins folder contains files with extensions of .plugin, not .rb. I tried both using the .rb and .plugin extensions with no luck.
                    When typing $align_loaded in the Ruby Console, the variable is nil.
                    Perhaps there has been some change the to plugin format in version 7?
                    I am looking forward to using this tool, so your support is much appreciated!
                    • jeff hammondJ Offline
                      @panoplos said:
                      Hello Didier,
                      yikes panoplos, you're in the wrong spot..
                      if your 'plugins' folder is showing .plugin files then you're at
                      applications folder > sketchup.app > (show package contents) > contents > plugins..
                      that's the actual app and those 'plugins' are the file importer/exporters..
                      ruby plugins go here:
                      Macintosh HD> Library> Application Support> Google SketchUp (#)> SketchUp> plugins
                      try that out instead.
                      • I Offline
                        irsa
                        thank you so much, its so useful
                        • simon le bonS Offline
                          simon le bon
                          Hi!
                          until Joe Simhon showed how "Align Tool 3D" was working I hadn't noticed its interest..
                          Playtime:
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/170px-Rhombictriacontahedron.gif
                          A rhombic triacontahedron consists of 30 golden rhombus perfectly identical. This Quasicrystal (Quasicrystals discovered in 1984) has been many fears for crystallographers because some had seen as a crystal with a symmetry of order 5, which is not like any self-respecting crystallographer knows!
                          Quasicrystal - Wikipedia
                          (en.wikipedia.org)
                          Golden rhombus - Wikipedia
                          (en.wikipedia.org)
                          Rhombic triacontahedron - Wikipedia
                          (en.wikipedia.org)
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/GoldenRhombus_th.jpg
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/RhombicTriacontahedron_02_th.jpg
                          [flash=640,480:2rhrdrml]http://www.youtube.com/v/qjuIm6Bd33s[/flash:2rhrdrml]
                          ++ simonlebon
                            Indispensable as soon as you have some objects who are not regulary oriented! πŸ˜‰
                              alexdobras
                              thank you !
                                jbrfrk
                                really useful.... thanks
                                πŸ‘
                                J=K
                                • archman212A Offline
                                  archman212
                                  fantastic..i have been looking for this one... πŸ‘
                                  archman212@gmail.com
                                  • O Offline
                                    Omez
                                    THANK YOU! πŸ‘ πŸ‘ πŸ‘
                                    I even not trying it yet, but i believe its very useful... once again, Thanks! πŸ˜„
                                    • john2J Offline
                                      john2
                                      couldn't understand 4m the pdf. 😞 is there any video tutorial πŸ˜’
                                      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                        Didier Bur
                                        Yes here: http://sketchuppluginreviews.com/2010/06/01/align-tool-google-sketchup-plugin-review-2/
                                        Google is your friend πŸ˜‰
                                        DB
                                        • kenK Offline
                                          ken
                                          Didier
                                          Not asking anything to be changed, however it took me some time to determine that what you call the "X axis" and "Y axis" can be any particular orientation. I was always trying to determine what the "X and Y axis" were while using the plugin. Lead to much frustration.
                                          I always wanted to be able to get inside the plugin and change the "X" to "1" and the "Y" to "2". To me that would have been more logical to remember, I wanted the "1's" and "2's" to align with each other.
                                          Thank you for your contribution.
                                          Ken
                                            Didier Bur
                                            Hi Ken,
                                            You can also think that X represent the red axis, Y the green axis, just as when you locate/translate/rotate the SU axis system.
                                            DB
                                            • 1 / 3
