    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.5k Views 175 Watching
    • Bob JamesB Offline
      Bob James
      This is just such an incredible set of plugins that I had to jump into this thread to say Thank You again. 😍
        junoswayam
        excellent stuff... Thank you very much
        • eebeeE Offline
          eebee
          Fantastic! Just what I needed! Works great!! 😍
          -ed
          • BoxB Offline
            Just a thought Tig for another useful extrude.
            Extrude Edges by Rotation.
            I can see many uses for it. Most of them are possible another way but it would be nice to simply select an edge or face and extrude it around a point, much like extrude by vector. Handy for doing curved corners in pipes or adding a radius surface to a box etc.
            Just an idea as I find I use your extrusion tools all the time and this is the only one I seem to miss.
              Can't you already do this with my EEbyLathe πŸ˜• πŸ˜• πŸ˜•
              • BoxB Offline
                Indeed you can, I just didn't know how, now I do. Thanks again.
                  cupko
                  Hi TIG,
                  Thanks for plugins πŸ‘ .
                  I have problem with Extrude Edges By Edges plugin. I draw two bezier curves and when I want to use EEbE cursor changes to white, but I can't select curves? Nothing happens?
                  SU ver. is 7.0.10247
                    Thanks Pilou for the help...
                    As was said... unlike most of the the other EEby.. tools that require you to pick 'curves' to make the mesh, EEbyEdges requires that the two sets of edges are assembled into two separate groups [you then pick these two groups using the tool]. This grouping allows you to use edges that are not necessarily parts of curves, or indeed even connected together at all, in the EEbyE.. operation...
                      Have you transformed each curves in "Group?"
                      Menu Edit / Group
                      Then select the 2 groups
                      Then call the plug β˜€
                        cupko
                        Thanks for help β˜€. Make group isn't possible from right-clik menu, but this works perefectly! Great plugin .
                          All right-click context-menu items are also available at the end of the Edit Menu...
                            linco
                            @tig said:
                            Get the latest zip from the first post in this thread...
                            Extract everything into a temporary folder - keeping all sub-folders and contents intact.
                            Move ALL of the the files/sub-folder(with their files) into the v8 ../Plugins/ folder.
                            Overwriting when prompted to do so.
                            Check everything that is now in the ../Plugins/TIGtools/ folder... AND if there's a file with the exact same name in the main ../Plugins/ folder remove it from the ../Plugins/ folder - it should be in the sub-folder!
                            Now everything should work fine.
                            Run the tools with the Ruby Console open to see if there are error messages.
                            If you still get errors - if you have SketchyPhysics installed in v8 temporarily remove its .rb files to disable it and see what happens.
                            If it's still not working post the error messages here... πŸ˜’
                            Sorry -- I'm a Newbie and this is my first attempt to install a Ruby Plugin. Followed the instructions and I can add the Toolbar, however, it is missing the icons. If you roll your mouse over it, the little squares will light up but there are no icons on it to tell what you are using! So, what did I do wrong?
                            Also, I assume the Lingvo files are Help files? How do I access them?
                            Lin
                            SketchUp Pro 8
                            Windows7
                              I suspect that you have made a similar mistake to the one you've quoted.
                              I suggest that you remove all of the files that you have just put into the ../Plugins/ folder; to see a list of these read the contents of the zip file and its subfolders. Files that should be in the ../Plugins/TIGtools/ subfolder should never be put into the main folder...
                              Now... extract the contents of that zip file into a temporary folder somewhere - e.g. ../Desktop/ExtrusionTools/ keeping all of the files that are already in a subfolder in those subfolders - the main subfolder is called 'TIGtools'.
                              Now move all of these extracted files and subfolders keeping the files within them [i.e. /TIGtools/] into the ../Plugins/ folder.
                              Now it should work with a restart...
                              You will find that many complex tools have a subfolder with support files in it.
                              Often there will be one or two .rb files to go into ../Plugins/ that kick off the tool, and the rest of the files are in a subfolder or perhaps even subfolders within a subfolder!
                              In the case of the ExtrusionTools, because they are a compilation over time, there are several tools with .rb tool-files and a 'loader' .rb file in ../Plugins/. The 'deBabelizer.rb' tool is required to do language translations: the .lingvo files are the translations it uses [and these must be inside ../Plugins/TIGtools/]. The .png files inside the TIGtools folder are the image-files used for the toolbar button-icons [that's why I 'know' they are not in the right folder - otherwise you wouldn't have this problem!!] πŸ˜’
                              Please let me know how you fare and if you need any more help please post here...Capture.PNGCapture1.PNG
                                linco
                                Finally -- problem solved! Followed your directions and it still wasn't quite right - then I noticed that my Unarchive was putting everything into one big folder without your TIGtools subfolder. Used a different program to Unzip and now it all works!
                                thanks!
                                Lin
                                  thanks!
                                  Lin
                                  Aha! ALWAYS ensure the files stay inside their subfolders when you install ANY Plugin.; clearly there needs to be a .rb or .rbs file to use those BUT also note that some support files [like Fredo's LIBs all stay inside their supplied folder.
                                  • W Offline
                                    Wildchild
                                    TIG, I know this might sound silly πŸ˜’ , but what's the difference between curviloft and the extrude tools? For what I know they're pretty similar aren't they? can you (or anyone else) point out some cases where is best to use one insted of the other? thanks
                                    Eternity is very long, especially towards the end. Woody Allen
                                      Fredo's tools are quite a lot newer than mine.
                                      Some of the tools are very similar, like EEbyRails and EEbyLoft - BUT there are several in the Extrusion toolset that are NOT - like 'EEby.. Lathe, Vector, Lattice, Face etc...
                                      I have both toolsets and I use mine more, simply because I am used to it...
                                      Fredo's do have a prettier UI and there are extra options to dynamically adjust the mesh etc, and they can work better in some circumstances - like with lofting closed-loop profiles, they might make complex messes a little faster too...
                                      So use what you find works best for you in each instance... πŸ˜„
                                      • W Offline
                                        wibeon
                                        The plugin doesn't appears in tools menu. I put .rb in the plugin folder but it doesn't work.
                                        Can somebody help me ?
                                          @wibeon said:
                                          You should have several .rb files in the ../Plugins/ folder and several extra files in the ../Plugins/TIGtools/ subfolder ??
                                          This is a screen-grab of what the contents of the zip file look like. Capture.PNG The new files/subfolder+files should be replicated exactly as this after you've extracted everything...
                                          When you restart Sketchup there should be a drop-down submenu early in the 'Plugins' menu [Note that it's NOT in the 'Tools' menu πŸ˜’ - reread the tools' instructions] - this submenu is called 'Extrusion Tools...' and it has nine items each relating to a different tool; to activate the equivalent toolbar you must use View > Toolbars > 'Extrusion Tools'...
                                            Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                            It has an additional tool ExtrudeEdgesByVectorToObject... see here for more details of the new tool... http://forums.sketchucation.com/viewtopic.php?p=331059#p331059
                                            • 11
                                            • 12
                                            • 31
                                            • 32
                                            • 10 / 32
