    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 408.4k Views 172 Watching
      @pierreden said:
      @Gaieus: Of course. But is it possible to attach a rar file directly to the post?
      Yes - under the textbox when you write a post there is an "Upload attachment" tab where you can upload files.
        Pierreden
        Hehe, sorry about that. Latskap.
          And I have just checked; the extension "rar" is also allowed (I thought maybe that's the problem).
            Sergio Morera
            Thank you for your generosity. I look forward to give it a try πŸ‘
            • Didier BurD Offline
              Didier Bur
              Very interesting. Two remarks/questions: lots of branches have their faces reversed. Do you think this will be fixed in a future release ?
              Do I have to play with the parameters to make it 'grow', as it seems to 'fall' more than to climb ?
              Regards,
              DB
              • OxerO Offline
                Oxer
                A very interesting plugin, i have used Ivy Generator by Thomas Luft but it's better if you can make ivy into Sketchup directly.
                I use Mac and the plugin don't works on OSX, i hope that you can solved this problem.
                Bye and congratulations for this promising plugin. πŸ‘
                This is a unfinished old project, i would like make this into SU directly.
                ivy created with Ivy Generator (Thomas Luft)
                  robert111
                  can anyone make tuto for this nice plugin plzzzzzzzzzzz
                  thanks robert
                    andre51
                    Great plugin! Thanks a lot
                      Pierreden
                      @didier bur said:
                      Regards,
                      I think both off these issues have been fixed in the v.0.1 release πŸ˜‰
                      @Oxer:
                      I can take a look at it. If you could PM me the error output in the ruby console it would be of great help! ("windows" > "Ruby console" inside sketchup and then try to make a new Ivy with this window open and copy the error message)
                      • OxerO Offline
                        Oxer
                        I probe the plugin again and don't works, the Console window appears blank and happens nothing.
                        Console window
                        Sorry Pierreden but i would like help you more, if there are another mac users please comment about the use of the plugin on Mac OSX.
                        • Alan FraserA Offline
                          Alan Fraser
                          Some great improvements there...and pretty easy to customise (I doubled the float length). One issue I have on my system is that when the progress meter hits 100% I still can't see the red latent growth path. It's only visible from certain very specific angles, so I have to keep constantly orbiting to a new position to see where it's up to. I have the latest graphic drivers. It's no biggee, but I thought I'd mention it.
                          3D Figures
                          • N Offline
                            notareal
                            Interesting project. I am sure that this has more potent than just to grow a ivy. πŸ‘
                            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                              That's probably because the tool doesn't implement the Tool.get_extent method: http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#getExtents
                              @Pierreden: Beware that adding methods into the base classes risk running into conflicts with other plugins. It's the same as adding methods to the root namespace - everything is shared. Method names such as .to_v, .to_p, .all_faces could potentially be used by other plugins authors.
                              Even though it looks nicer to extend the base classes there always is a risk of clashes. I always advice people to void it just to be on the safe side.
                                Lobster
                                Looks really interesting but I too have a problem on a Mac OSX 10.6.6. Sketchup 8.
                                There is no output in the console window showing fault after choosing/ticking in the plugin list and clicking on a surface.
                                The extraction of the .rar seemed fine and i have the folder and .rb file in the correct directory. I presume that the files remain in the Sketchupivy folder?
                                Regards
                                Sam
                                  Lobster
                                  You should a file called si.rb that is in Plugins and a folder called SketchupIvy containing other files, that folder also goes into Plugins.
                                  If your .rar extractor has put these inside another folder then move the .rb and folder into the Plugins folder.
                                    Lobster
                                    Hi Tig,
                                    Thanks for the clarification. My path is correct. I have the Sketchupivy folder and the .rb file in the plug ins folder.
                                    Regards
                                    Sam
                                      Pierreden
                                      @lobster said:
                                      Hi Tig,
                                      Regards
                                      Sam
                                      I have little experience with mac, but try to replace the tool.rb in the "SketchupIvy" folder with the attached one. Might work πŸ˜•
                                      tool.rb
                                        Copy/paste this into your Ruby Console Sketchup.find_support_file("Plugins")
                                        It will give you the correct location for Plugins on your MAC.
                                        Both the si.rb and tool's folder should be in this folder...
                                          Pierreden
                                          Yeah. Im aware of this but do this mostly because my experiments and tests never leave my computer/Sketchup. Will do something about this soon.
                                            It is an interesting plugin. Thank you. Like Alan, I don't see the red latent growth path. Most of the time orbiting doesn't help. Also, even with branching probability set to .99 I don't get any branches. If I have units set to Fractional as I normally do I get the following in the console.
                                            %(#FF0000)[nil
                                            Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/tool.rb:43:in onLButtonDown'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/tool.rb:43]
                                            • 36
                                            • 37
                                            • 2 / 37
