    HOW TO DELETE A TEMPLATE?
    layout
    8 Posts 5 Posters 4.1k Views 5 Watching
    • keea1111K Offline
      keea1111
      HI,
      DOES ANYONE KNOW HOW TO DELETE AN UNDESIRED CUSTOM TEMPLATE WITHIN LO? THANKS, KEEA
      KEEA
      • AnssiA Offline
        Anssi
        In my computer (Windows 7) the templates reside in C:\ProgramData\Google\Google SketchUp 8\LayOut\Templates. If you need to delete a template, just navigate there and delete it just as you would delete any file. The ProgramData folder is invisible in the Windows explorer unless you make it visible from Organize menu>Folder and Search options>View pane.
        Anssi
        • keea1111K Offline
          keea1111
          Thanks..I'm on a Mac, and when going to libray--application support--Google SU 8 Pro, there only appears Sketch Up and Style Builder folders. No Lay out folder, because I had tried that before...Any ideas...thanks,
          KEEA
            Tasman
            Try going to the Users/Library/Application Support/Google SU8/Layout.......etc - you should find the template in question there.
              Slimdog
              or you could type the name of the template into the search bar at the top right of your screen.
              • keea1111K Offline
                keea1111
                HI,
                I can't seem to locate...Here is a screen shot showing my attempts...thanks,
                KEEA
                • wind-borneW Offline
                  wind-borne
                  As mentioned previously you need to go into user library
                  "To read between the lines was easier than to follow the text."OSX 10.11.6
                  %(#BF80BF)[SU 8 pro
                  • keea1111K Offline
                    keea1111
                    HI....
                    Thanks..I missed the library on my users account and was going to the Mac library...thanks so much,  Keea
                    KEEA
