HOW TO DELETE A TEMPLATE?
HI,
DOES ANYONE KNOW HOW TO DELETE AN UNDESIRED CUSTOM TEMPLATE WITHIN LO? THANKS, KEEA
In my computer (Windows 7) the templates reside in C:\ProgramData\Google\Google SketchUp 8\LayOut\Templates. If you need to delete a template, just navigate there and delete it just as you would delete any file. The ProgramData folder is invisible in the Windows explorer unless you make it visible from Organize menu>Folder and Search options>View pane.
Anssi
Thanks..I'm on a Mac, and when going to libray--application support--Google SU 8 Pro, there only appears Sketch Up and Style Builder folders. No Lay out folder, because I had tried that before...Any ideas...thanks,
Try going to the Users/Library/Application Support/Google SU8/Layout.......etc - you should find the template in question there.
or you could type the name of the template into the search bar at the top right of your screen.
HI,
I can't seem to locate...Here is a screen shot showing my attempts...thanks,
As mentioned previously you need to go into user library
HI....
Thanks..I missed the library on my users account and was going to the Mac library...thanks so much, Keea
