    Trace pdf site plan
    20 Posts 13 Posters 5.2k Views 13 Watching
      mozzie
      I have found that importing PDF into Inkscape (open source) is sometimes helpful, especially if the pdf has been created from CAD program. It can then be saved as a DXF file for import to SU (or as a native svg if you want to make changes in a vector drawing program).
      Also, some of the programs based around Ghostscript can do a similar conversion, but I've had less success with these.
      • simon le bonS Offline
        simon le bon
        thanks Marcus for your CometDocs link 👍
        hum!
        Not the subject but related:
        How to bring layout of a site coming from Google Earth into Sketchup
        To extract approximate contours for an area, zoom into the location in Google Earth. Ensure your view is head-on and north-oriented. Go to Sketchup, and click on the Get Current View in the Google Earth Toolbar. Once imported, turn on the Toggle Terrain option....
        404 Not Found
        (www.architectionary.com)
        [flash=480,350:1og8h5jl]http://blip.tv/play/AYHJgyYC[/flash:1og8h5jl]
        *S
        • mitcorbM Offline
          mitcorb
          Thanks, Marcus-- and thanks, Simon
            Marcus, thanks for that link. How long does it typically take to get a conversion back?
            • focptF Offline
              focpt
              Alternateley, Open the PDF in photoshop and save as .jpg at the resolution desired.
              • Nathan
                http://www.focalpointstudio.net
              SU8, VRay 1.49
                I use PDFCreator as a virtual printer and it can also "print" into various raster image formats.
                • H Offline
                  HFM
                  If you happen to have Illustrator installed on your machine you could export the pfd to dwg that way. It also gives you the option to clean up the pdf before exporting...
                    miikka1978
                    Thanks for all the great suggestions! I tried the Comet Docs but I always get error when trying to convert the pdf to dwg. Also, there seems to be the same problem with quality when converting the pdf to image file. In the future I will be using this conversion tool for other purposes for sure. So, thanks a lot for the link.
                    Wintopo looks promising but the layout needs be converted to image because the software can't open pdf-file. I believe that this is the reason why contours get broken when creating dxf-file.
                    I don't have Illustrator and so I don't really know how well it could work in my case.
                    Here is the map that I am trying to trace in Sketchup:
                    http://www.golfpirkkala.fi/images/stories/pdf/gpi_layout.pdf.pdf
                      d12dozr
                      You're welcome, everybody.
                      ~15 minutes for the documents I tried
                      http://goo.gl/f7ooYh
                      • W Offline
                        wyatt
                        I think that file will be difficult to vectorize. There are lots of overlapping lines that are typically difficult for PDF-to-CAD programs to handle. You could try Scan-2-CAD http://www.scan2cad.com. They have a free trial (14 days I think) with full features enabled. I've had good luck vectorizing sketches, grading plans, contour maps, etc. When drawings get complex though, the program has had difficulty distinguishing which lines should be connected.
                        Do you have any kind of image editing program? If you open the PDF in something like photoshop, gimp, or corel, you should be able to save it as a higher quality image. Taking a snapshot captures the image at screen resolution and will thus be lower quality than you can get from other programs.
                          Funny. I've tried with three different PDF files--even signed up with them--nothing back from them in over 6 hours. I just checked and supposedly the last file I sent to them is still "processing".
                            JuanV.Soler
                            here are the dwg and the skp file
                            I did it with Aide Pdf to Dxf Converter
                            hope it helps yousiteplan.rargpi_layout.rar_____________________________________
                            and here is the skp file exploded, so to work better on it.
                            download the three compressed files to open it.siteplan-exploded1.part01.rarsiteplan-exploded1.part02.rarsiteplan-exploded1.part03.rar
                            It takes ages to explode ¡
                            good luck.
                              miikka1978
                              Juan, thanks a lot for doing the work form me. I didn't know that you can get the contours that nicely from pdf.
                                Late last night I got the DXF files back from the PDFs I submitted to CometDocs. Unfortunately the single lines were all doubled so they weren't usable floor plans. Ah well. It probably works for some.
                                  bjornkn
                                  That's the problem with many pdf site plans etc; that lines with a thickness (which is often all of them) gets converted to double lines.
                                  When I get pdf files I usually load into PS, with a resolution like 100 dots per cm. Then it's easy to get it into SU with the exact size/scale maintained.
                                  That's OK for us metric guys anyway, which according to a report I just read, is every country in the world except Liberia, Burma and USA 😉
