    [Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
    123 Posts 51 Posters 186.2k Views 51 Watching
    • Chris FullmerC Offline
      Woohoo! Thanks to lots of persistence by others asking me nicely to get this one fixed, and thanks to finding the problems by Thom and Edson, and some great solutions by TIG, Jeff99, and others - I think I can finally say that this script is updated and working with SU 7.1!
      Well, hopefully. Please test it when you get a chance. I tried every combination of faceme and regular component scaling I could think of.
      v2.5 - SU 7.1 compatibility fix
      • Fixed scaling so that Face Me components don't freak out like they have been doing since SU 7.1 was introduced. Big Thanks to Edson and Thom for helping figure out what was breaking.
      • Cleaned up some code - a big chunk thanks to a tip from TIG!
      So if you have this script installed already, go back to the first post in this thread, and re-download. Then overwrite the existing file in your plugins folder. Thanks, and I hope this works now!
      • plot-parisP Offline
        plot-paris
        brilliant! another Christmas Present! thanks a lot, Chris 😍
        • N Offline
          nektares
          Wow thanks man, you are very creative with your scripts, they are very useful and easy to use. Thanks!
            Ah! Finally I can adjust the size of my forest without it flying away! πŸ˜„
            oh - one last request? Make it remember the values used last?
            • EdsonE Offline
              Edson
              chris,
              a big THANKS for fixing this bug! this plugin is used by me so much that it feels like recovering from a broken leg. i just tested it and everything seems to be back to normal. i'll let you know in case there is any odd behaviour as i use it more.
              http://www.mahfuz.arq.br
                plot-paris
                πŸ‘
                  j40
                  Great plugin! saved me so much tree rotation. Thanks Chris!
                  @plot-paris said:
                  πŸ‘
                  πŸ‘
                  Top3D Studio
                    Crevard
                    thank youuuuuuuuuuuuuu !!!!
                      bupaje
                      Hey Chris - great plugin. I was thinking it would be useful to add space between components before rotate.
                      For example on this stone wall
                      http://stormvisions.com/sketchup/srm1.jpg
                      your tool did a great job of jumbling the stones but turn more than a little and they intersect their neighbor. In this case it would be useful to add a 'gap.'
                      I'm sure there is probably another plugin that does just this, and this test project is easy enough to move by hand, but figured I'd suggest it anyway.
                      Burt
                      Stormvisions
                        Lersince1991
                        Amazing thanks a lot! Brilliant plug in, just made the landscape look so much better with random trees πŸ˜„
                          Cool, glad it helped!
                          @Bupaje - not sure I'll be incorporating that into the plugin soon. This really is only made to modify components in place. It would be hard to figure out how to "add spacing" since spacing in that sense is a linear movement.
                          However, I also think you could do what you wanted with the tool in its current state. Select the blocks and do a uniform scale only on the x axis. That will effectively add a space between the blocks. Then do it again and add some random rotation. See if that is about the same effect,
                          • I Offline
                            ishboo
                            Excellent tool, I can see a ton of uses for it. Great idea!
                            SketchUp plugin marketplace: http://extendsketchup.com/
                              bupaje
                              Thanks Chris. will give it a try when I get home tonight.
                              EDIT: tried this during my lunch break and works. Scaled the bricks, then hiit reset scale and that left the spacing. Thanks.
                              Burt
                              Stormvisions
                                lapx
                                Chris,
                                Thank you so much for an excellent program. I have trees as images to be exported as proxy's or instances for Kerkythea. Is there a way to random rotate images? Perjaps not if they are faceme objects which they are. Would like to know how others deal with this delima.
                                Lapx
                                  If they are face-me's then they will always face the camera in SU. I don't know how kerkythea handles proxy's, does it work with face-me billboards? I think other renders just end up exporting the geometry in the location it is when the export buttin is pressed. So the trees would all be facing the same direction. I'm not really sure that rotating them with this plugin will help fix any of these concerns though.
                                  • coulteriC Offline
                                    coulteri
                                    Hello,
                                    this is great plugin I am using every day. I think it would be much more powerfull if there was a possibility to scale randomly by all axis. One would be able to randomize e.g. stones or 3D vegetation.
                                    Is this possible to implement?
                                    Thanks.
                                    coulteri
                                    • E Offline
                                      Earroyo
                                      Hello everyone,
                                      CAN SOMEONE HELP ME LOAD THESE PLUG-INS.
                                      THERE ARE SEVERAL with the .rb extension that my Pc does not recognize.
                                        Hello everyone,
                                        Sounds like you don't understand how Plugins work at all ?
                                        πŸ˜’
                                        A .rb file is a text-file - often called a 'script'.
                                        If you put it into your Plugins folder and restart Sketchup it will auto-load the tool for you.
                                        The only time you need to 'open' a .rb file is to actually 'read' its contents - and if you are so inexperienced you don't really need to do that [just yet]! However, if you use Notepad.exe to open a .rb file you will find it's readable text [always use a plain-text editor - never use a wordprocessor as that will mess up the contents big time!]...
                                        In the case of this specific tool... it's quite a simple one - so the .rb file just goes into the Plugins folder and you restart Sketchup; and the Usage: says
                                        Select the components and/or groups to be scaled and/or rotated. Run the plugin at Plugins>Chris Fullmer Tools>Scale Multiple> . There are two plugins found here. One will scale everything equally. The other will scale them randomly based on minimum and maximum provided values. NOTE: The scale factors are not percentages. They are factors. Which means if you want to scale something to be twice as large, you enter 2. If you want something to be one half the size, enter .5 . Entering 50 will not a result that is 50% the original, but will give a result that is 50 times larger than the original.
                                        There's only one .rb file for this tool called ' clf_scale_rotate_multiple.rb' - you download it and put it into the 'Plugins' folder and restart Sketchup to activate the tool...
                                        So what "other" .rb are you referring to in your post ? πŸ˜•
                                        More generally... Read the installation instructions that come with each tool - on their download page.
                                        Some are in zipped sets and need extracting / installing into the Plugins folder, keeping the files in any subfolders etc so they work properly.
                                        Also ensure you know how the tool is used - e.g. Some are Extensions that need activating from Window > Preferences, some appear as menu items - typically under the 'Plugins' menu... BUT some can appear elsewhere [like 'Tools' or 'Draw'], some are context-menu specific [e.g. appearing only if you select a particular type of object], some have a toolbar activated from View > Toolbars, a few are run by typing a command into the Window > Ruby Console... πŸ€“
                                        • E Offline
                                          Earroyo
                                          Thank you all for your response. I am new to plug-ins and one thing i did not tdo was restart the program. I will do that this morning. Thanx for your input. Looking forward to a new crew.
                                            Jeggebis
                                            Hi Chris and the rest of ya
                                            I have been trying out this plugin + your component stringer since i am trying to recreate my little 1:50 model in sketchup. But i cant seem to find a smart way to do it, or maybe i am missing something.
                                            My idea was to draw a path using something like bezier curves or the free hand tool and then use different components in randomized pairs of 2 "rafts" in 1 component. These should then stack on top of each other with a random rotation. Simulating the way i glued all them sticks together in my model:
                                            1 2
                                            I have tried dividing the "path" for the stringer plugin in to 100mm lines connected in to one long line. That way the wood would seem to rest upon each other - as in stacks. It works great with the axes placed in the middle of the component, but I couldn't figure out how to do this on something like the bezier curve, as the components would then rotate along a wrong axis. Havn't been able to work out how to place the Axes tool to avoid this.
                                            3
                                            Also, when i just use the same component i wont get the more "spacious" look my model has + sometimes the wood would seem to through each other.
                                            4
                                            How would you guys approach this?
                                            Thanks for your time and wonderful plugins!
                                            • 3 / 7
