    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 185.4k Views 108 Watching
      morisdov
      Thank you guys for the support.
      here is a link to a new 1.09 version.
      http://sites.google.com/site/morisdov/proper_animation_1.09.zip
      I modified error handling and exceptions bubbling, to better behave on a mac.
      on a maconly the 'animation attributes map' dialog should open in show_modal - Johns request (to mimic the behavior on windows ?).
      Let me know if its better on a macand does not crush even when there no scenes in a model, and the ruby console is not open.
      (the previous version 1.08 seemed to be working fine on a mac - if you have at leaset one scene, and the ruby console is open)
      Thanks, Moris
      • O Offline
        otb designworks
        Thanks Moris!
        I will test this version out and report results here. I much appreciate the quick fix!
        Cheers, Chuck
        OTB Designworks is on Youtube
        • dereiD Offline
          derei
          Hy! I find your plugin very useful ! I just animated some furniture with Proper Animation πŸ˜„ The only drawback is its ergonomics, but I think it can be improved by adding Start/Stop Scenes Observer in webdialog and also Set/Get position for current selection.
          Maybe a option to have a exclusive context menu (only set/get position)?
            Jay24
            I have just installed Proper Animation and I understand that it works with the Twilight render. But I can not seem to figure it out, would somebody be able to give some advice on how i can render the animation?
            Jason
              Hi Jason,
              In Twilight, under the animation tab, you have to set Twilight to render animated objects as well (top-most pulldown menu I think).
                Jay24
                @gaieus said:
                Hi Jason,
                Yes I have done that Gaieus. I also have the fps at 30. I have tried slowing down the transitions. but whan I render the animation is not there.
                  Indeed it works, see the video below.
                  YouTube - Twilight Render SketchUp Animation - Building Progress
                  [flash=600,360:31i9md3w]http://www.youtube.com/v/JKLp1q4b3YU?fs=1&hl=en_US[/flash:31i9md3w]
                  I suggest however to go to the Twilight Forums as the developers are very helpful there (the video was also made by one of them). This is rather a Twilight issue than that of the plugin itself. This is the topic about the video and the method:
                  http://twilightrender.com/phpBB3/viewtopic.php?p=16780#p16780
                    Jay24
                    I suggest however to go to the Twilight Forums...
                    Thank you
                      Pout
                      Gaieus,
                      Great movie,
                      Imagine that combiend with linking to scheduling...
                      Let's see what I can do πŸ˜„
                      • majidM Offline
                        majid
                        mates, I didn't read the entire replyes, but does this gem, works with v-ray? ( for sure no) but is there any way (maybe a tip or trick or another plugin..) to have renders using v-ray and this gem?
                          Pout
                          a question:
                          It seems to be impossible to add non-animation scenes?
                          If i don't set a position 8 and do set a position 9 then when selecting Scene 9 the position is not taken.
                          So if I understand correct all positions have to be set?
                          Thx
                            gtvdave
                            Thank you for this! πŸ˜‰
                              rstanley
                              Hello Moris,
                              Up until Proper animation. I have been limping getting along by erasing selected positions per any selected scene but it was a nightmare to set up.
                              Proper animation really offers a lot.
                              Am hitting a wall with Proper Animation in some respects though and I'd appreciate more details about proper animations operation in relation to sketchup's own quasi animation controls.
                              1. What is the relationship of it to sketchup's own animation controls: For example, does Proper animation override the other or is it a parallel function or a subset of it. (eg; scene transition time or delay times, or update scene versus your set position.
                              2. Animation easing this refers to what appears to be the degree of acceleration or deceleration of the transition between scenes.
                              3. Am trying to achieve a continuous smooth flow through the scenes without a distinct stop point on each scene. (Pls note too, that I am not trying to change directions between scenes in the attached animation of the express-local train concept). I can approach fluidity with your easing control but its still not a smooth transition between scenes. Sketchups "0" marker for scene delay versus your "-1" notation as the baseline leaves me guessing as to what is really the no-stop position at each scene. No subdivision of 1 is allowed and anything higher only delays it longer. What settings then, best assure fluidity ? and again, do we use Proper Animation's menu options and then ignore Sketchup's options or make them the same or ??
                              Proper Animation will be a great addition if we can understand the operational relationships/ heirarchy between it and Sketchup's inbuilt quasi animation controls.
                              Thanks, RStanley
                              AutoSave_Non stop train scene+ cmd E m 16 ,4,2011.skp
                                g863210
                                thank you! πŸ‘
                                  SDC
                                  I have an skp with 349 scenes.
                                  I'm just wondering if there is any way of scrolling down on the 'Scene Transition Times' window as I can only see the first 36...
                                    mgfranz
                                    OK, so I went through the whole process of creating the animation, exported it with Projection and built it with VirtualDub and all works fine, but as you can see from the video the hinges from the project come through the surfaces of the materials. How do I fix that so that the animation moves as it should?
                                    http://www.mgfic.com/SKPFiles/untitled0.jpg
                                    Folding Table.flv
                                    Are we not allowed to embed .flv files? I tried this.
                                    [flash=]http://www.mgfic.com/SKPFiles/Folding Table.flv[/flash]
                                    "If you like what you do, it will never be work..."
                                    In memory of Sam Maloof, 1916-2009
                                      Jim
                                      The rotation is a result of how SketchUp/Ruby interpolates the object's 'tween position. I'm not sure there is anything you can do about it without a re-write of proper animation.
                                      • dereiD Offline
                                        derei
                                        try to put the axis in such way, to rotate around one. Then you will have to remake the animation, but I guess it will rotate closer to what you want.
                                        • ashscottA Offline
                                          ashscott
                                          Yeah relocating the components axis generally works for me, just make sure you get the red green and blue axis pointing in the right direction. If it acts weird then you have the wrong colour axis pointing the wrong way.
                                          Ash
                                          Just some stuff I do with Sketchup.
                                            cody.sheridan-2008
                                            hi all,
                                            I have done an animation using this plugin but have run into a problem. When I get to the 9th scene the movement changes from fluid to suddenly moving to the next position. I have attached the model so if you can help that would be really appreciated!
                                            EDIT: No worry's I have solved my problem now...
                                            Sawmill Combo V1.5.skp
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
