    SU 9 Wishlist
    436 Posts 99 Posters 85.7k Views 99 Watching
      TIG has a "SectionCutFace" plugin that utilizes this group from slice + already fills the faces + moves this group a little bit mack so that you can see it.
      You are right however. This plugin is necessarily inaccurate a little bit. A very cool plugin however.
        ArCAD-UK
        Already one of my must have plugins from way back, but sometimes I just want the lines and having the slice appear without adjustment would naturally simplify the drawing process and TIG could then remove his 0.2mm offset. πŸ˜‰
          If all you want is all of the line-work associated with a SectionCut it's built in.
          Select just the Section Plane and right-click context-menu 'Make Group from Section'.
          A group is made containing the line exactly over the originals.
          Switch off the SectionCut to see the lines and edit/use them etc πŸ€“
            ArCAD-UK
            This is where the core S.U. program needs fixing TIG. If the section is active the resulting slice lines/edges are hidden and deactivating the cut the lines merge with the rest of the model. There are many work arounds but it just seems to me that the current arrangement of not displaying the slice because it is coincident with the section plane desn't make sense in CAD world?
              That's why I move it a tiny distance into the view so you can see it...
              If you want lines only for my SectionCutFace group you can make it 'keeping all edges', then edit it [double-click] and with View > Component Edit > Hide Rest of Model you ban best see what you are doing... Then select all and use one of the several tools to deselect the edges and 'delete'. Now you just have edges. I suppose I could adjust my code to has a <None> option under face material so all faces are auto-deleted for you πŸ˜•
                Yes TIG but what he is saying is that it would be betterif you didn't need to move your face back a bit and SU would (still) display what is exactly on the cut (rather than hiding it already).
                To me, it would sound logical, too.
                  ArCAD-UK
                  Your app works just fine as is TIG, no criticism intended! As Gaieus has recognised it would be logical for the S.U. section process to make that little change from < to <= in the display calculation and bring many benefits with no negatives to the drawing process.
                    I've tweaked SectionCutFace to v2.5 here http://forums.sketchucation.com/viewtopic.php?p=315619#p315619
                    '<No_Face>' option added, so you get just lines without faces.
                    'Lock Cut' option added.
                    A class test replaces typename, optimizing speed.
                      publied
                      I was thinking to multithreading and 64-bit supports. But it would not hurt to have even support to Android. So we have SU for Tablet PCs and Linux. Not so bad.
                      hire me@ http://www.publied.it !
                      • 2 Offline
                        2Harry2
                        1. The ability to force a snap to a specific point, especially a mid-point or circle center, instead of having to estimate by eye and hover the cursor over your best guess, which sometimes takes a while, and sometimes doesn't seem to work at all.
                        2. Making the zoom function behave logically when the cursor is over empty space (as someone else already pointed out)
                        3. Allowing construction line placement to snap to points not on the plane of the construction line
                        • jgbJ Offline
                          jgb
                          Point #1, SU will readily snap to a circles center if you run the cursor around the circumference then hover near the perceived center. Won't work on exploded curves.
                          #2; Been bitchin about this for 3 years now; others probably longer. SU Development will rather add more bells and whistles than tune up existing cracked bells and blocked whistles.
                          jgb
                            rv1974
                            I'd like see the real change in the performance field.
                            Something like this:
                            [flash=700,450:11o27hhi]http://www.youtube.com/v/Gz6bOU4JX1w[/flash:11o27hhi]
                            EDIT: I fixed your faulty flash-code and linking... TIG
                              rv1974
                              Additional teasing:
                              http://www.youtube.com/watch?v=VdxwWKBy4gU&feature=player_embedded#at=104
                              @TIG: thank you. Could anyone teach me how to transform url to the flash preview please? 😳
                                Here is a topic:
                                http://forums.sketchucation.com/viewtopic.php?f=79&t=10103
                                Jim also made a browser plugin (sometimes you may want to adjust the size to make it "nicer" but not necessary):
                                http://forums.sketchucation.com/viewtopic.php?f=179&t=28717
                                  meh wants!!! 😲
                                    rv1974
                                    [flash=640,390:2bmvkra9]http://www.youtube.com/v/VdxwWKBy4gU&feature=player_embedded#at=104[/flash:2bmvkra9]
                                    @Gaieus: β˜€
                                      @rv1974 said:
                                      Additional teasing:
                                      Edit your original post and read what I added...
                                      To embed most movies this method works...
                                      Note that I've added spaces into the [url] and [flash] tags to 'break' them so you can read them !
                                      [url ]http://www.youtube.com/watch?v=VdxwWKBy4gU&feature=player_embedded#at=104[/url ]
                                      becomes the flash code
                                      [ flash=700,450]http://www.youtube.com/v/VdxwWKBy4gU[/flash ]
                                      [flash=700,450:1jujbepr]http://www.youtube.com/v/VdxwWKBy4gU[/flash:1jujbepr]
                                      Note how you specify the flash= width,height in pixels for the embedded 'window' and [for YouTube files at least] you change the http path to ...com/v/MovieTag
                                      • W Offline
                                        watkins
                                        It would be useful if when selecting the circle tool the circle pointer icon displayed the currently set number of segments. This small addition would prompt the user to consider 'more or less' segments before drawing the circle.
                                        Regards,
                                        Bob
                                        • jgbJ Offline
                                          jgb
                                          Regards,
                                          Bob
                                          It Does this now. β˜€
                                          When you click on the circle or arc tools, the current number of segments are shown in the VCB (Measurements box). Usually 24 for the circle and 12 for the arc.
                                          Start your circle/arc and that is the segments you draw in, until you select the tool next.
                                          To change the segment value, click on the tool, and then, before any draw operation, type the number of segments you want followed by "S" and <enter>. The tool stays in that segment count till you select the tool again and change it.
                                          You cannot change the segment count after you start to draw. However, you need to select some other tool or the select <spacebar> first, before the circle/arc tool again.
                                          jgb
                                          • W Offline
                                            watkins
                                            Dear Joel,
                                            Yes, I know about the VCB box displaying the number of segments, and I should check it more often than I do, but I often forget. What I am suggesting is a 'prompt' to remind you to change (or not) the number of segments.
                                            Kind regards,
                                            Bob
                                            • 11
                                            • 12
                                            • 21
                                            • 22
                                            • 10 / 22
