    [Plugin] (TIG) Rotate Plan View v1.1 20110316
    54 Posts 17 Posters 51.5k Views 17 Watching
    • C
      cobb89
      Copy/paste it into a file named Rotateplanview.rb in the Plugins folder.
      To use set up your Plan [Top] view, without Perspective and in the Ruby Console type Rotateplanview.new to rotate the camera 45 degrees clockwise, repeat to rotate it another 45 degrees etc. The extents are zoomed after each rotation.
      To do other angles provide an angle value in degrees - e.g. Rotateplanview.new 10 rotates the view 10 degrees clockwise or Rotateplanview.new -30 rotates the view 30 degrees counterclockwise.
      When you are happy with it save the view to a new Scene tab so you can return to it later.
      can anyone create a toolbar button for this plugin??
        As well as a toolbar you'd need a dialog for the angle ?
          Seems to me entering the text into the console works very nicely. And I don't have to find room for another toolbar.
          Oh, and Rich, I very happy to have your assistance while your wife is ironing. πŸ˜‰
            Prioritize Dave...Prioritize πŸ˜‰
            • C
              cobb89
              yeah....whatever is possible.... πŸ˜’
                Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=313264#p313264
                It includes View menu item and toolbar with dialog entry of angles - the Ruby Console version works as before for those of you not wishing clutter... The toolbar only gets made if there's a png file so that's a simple way to stop that being created if you don't want it!
                  Michaelv
                  TIG, can I use it to include into a tool I'm working on. It's an easy simple rotate tool, and I'd like to include this as planview rotation when hovering over the origin.
                    No problem, just give some acknowledgment in the header πŸ˜„
                    • C
                      cobb89
                      Thanks a lot!! πŸ˜„
                      • Bob JamesB
                        Bob James
                        It seems that whenever I go to parallel projection and top view the scene is never at the angle I want it, so this plugin is really handy.
                        Okay, so I'm lazy, but it would be very nice to speed up workflow if the plugin did the preliminary steps automatically: set camera to parallel projection and set to top view 😎
                        • EarthMoverE
                          EarthMover
                          Great idea and very useful. Thanks TIG!! πŸ‘
                          Content Creator at Skapeup
                            dan19936
                            Also available is the free Camera Controls by Smustard
                            http://www.smustard.com/script/CameraControls
                            Dan
                            • jwliiiJ
                              jwliii
                              Great Great Great - Donated!
                                Is there a way to lock the scene so that it cannot be identically dragged away from its intended orientation?
                                What do you mean by that? "Identically dragged" ????
                                Set up the orientation as you want it and create a scene. Or update the existing scene.
                                  seasdes
                                  If you click on the middle mouse button and drag (identically) the view will change. I would like to stop that from happening.
                                  Thanks Dave
                                  Using Sketchup Pro 2019
                                    seasdes
                                    This post may have a workaround unless others know of a better way
                                    http://sketchucation.com/forums/viewtopic.php?f=15&t=50685&p=457482&hilit=scene#p457496
                                      Make a Scene-tab to remember the plan-view camera as you have just made it... then after you zoom/pan/orbit and have mess it up, you simply click on the Scene-tab and that view is restored...
                                        Thanks Dave
                                        "identically" I don't think that word means what you think it means.
                                        As I said and now TIG has said, create a scene after setting the view. Then when you've changed the view by clicking on the middle mouse button and dragging (orbiting) you can return to it.
                                        Or if you don't want the view to change, don't press the middle mouse button and drag.
                                          seasdes
                                          Sorry Dave I meant 'accidentally'. I have corrected the typo. Another senior moment.
                                            seasdes
                                            This is a wonderful tool. I was made aware of it by Dave.
                                            Is there a way to lock the scene so that it cannot be accidentally dragged away from its intended orientation?
                                            • 2 / 3
