    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
      I guess, if I were you, I would wait until it shows up again and note what it says. Then report back. If you can make a screen shot showing it, that would be very useful.
      • EdsonE
        Edson
        @dave r said:
        I select the softened edges (View>Hidden Geometry) and then set the slider to 20 where it normally is by default. In the lower of your screen shots, there's a softened edge at the bottom to take care of.
        dave,
        I followed your advice and it worked. thanks. never had this problem before.
        http://www.mahfuz.arq.br
        • B
          BlueFalcon
          I selected my group and clicked the shape bender icon, i click on the straight line than the curved line, and it gives an error telling me to select the group before clicking the shape bender icon
          wath is the problem? i did everything like you did in the video and it wont work
          also, how can i make those really soft curved lines?
          I'am not new to sketchup or somthing, but i never had problems using plugins.
            It would be a big help if you either post the SKP file or at least a screen shot.
            • EdsonE
              Edson
              just to let you know that the crashing SU8 when running Shape Bender was due to the fact that I was running an outdated version of HOlePunchTool (1.6). as soon as I updated it the crashes stopped.
                Edson,
                Glad that is sorted out. Now you can bend and punch. πŸ˜‰
                  Edson
                  v1.7 of HolePunch was done around late January and it was to fix a reported conflict with the unusual way ShapeBender made groups, "It appears that the way ShapeBender copies/adds component-instances/definitions and also uses 'make_unique' etc fell foul of the HolePunch definitions-observers: a definition could occasionally get two of the same HolePunch observers added which really messed everything up big time!" πŸ˜’
                  See http://forums.sketchucation.com/viewtopic.php?p=302853#p302853 [and presumably Solid Tools was doing something similar ?]
                  All fixed now anyway [btw v2.0 is the current version]...
                  • EdsonE
                    Edson
                    @tig said:
                    Edson
                    I am sorry I missed that. as I said somewhere else, it is quite hard to follow all the threads about the plugins one has installed. in my case, I have 315 items in my plugins folder...
                    • Chris FullmerC
                      @tig said:
                      Edson
                      Oh my, I missed all of this also TIG. Hopefully its all sorted now. I'll have to make sure to adjust the way shape bender does that if I ever get around to re-writing it.
                      • B
                        BlueFalcon
                        Here is a picture of my problem:
                        http://portablenetworkgraph.deviantart.com/art/shape-bender-202454409
                        • GaieusG
                          BlueFalcon,
                          In those pictures I cannot see the axes. Don't forget that ShapeBender works only along the red axis.
                            Assuming that the straight line is drawn along the red-axis...
                            How big is the group ?
                            If bending it would make facets <1mm then it might fail...
                            • B
                              BlueFalcon
                              I have done the same procces along the red axis with lines all higher than 1 meter, and the same happens.
                                Could you post a screen shot of your Plugins folder as well as the contents of the folder called clf_shape_bender?
                                • Chris FullmerC
                                  Hmm, not sure why the previes is not shoing up. Just try pressing "enter" after you select the line and curve. See if that does anything.
                                  Also, run it with the ruby console open, see if it shows any errors.
                                    The line should be ON the red axis ??
                                    • B
                                      BlueFalcon
                                      i have tried everything thats told me, nothing helps.
                                      i have a screen shot of my folder with the plugin and the folder, but i cant upload cause the site is down.
                                      only when i opened the ruby console, an error appeared.
                                      the error:
                                      Error: #<NoMethodError: undefined method `/' for nil:NilClass>
                                      here is the picture but i dont know if this link works:
                                      file:///C:/Users/Gebruiker/Pictures/shape%20bender%202.png
                                        BlueFalcon
                                        Please attach your image to your post, using the tools accessible at the foot of the page when you are typing your reply = 'Upload Attachment'...
                                          To avoid potential confusion, the line needs to be parallel to the red axis but it does not have to be literally on it.
                                            it's better also to make all the process on the positive quadrant x,y,z in case of πŸ˜‰
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 63
                                            • 64
                                            • 37 / 64
