    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 535.2k Views 108 Watching
      Incidentally I have found that the one script that tips we over the edge is thomthom's selection_toys ad that adds dozens of new commands under three submenus in the context-menu. If I stop this loading I get no gray-outs ๐Ÿ˜•
        It does add a few Command objects - but it's not leaking them. (I've checked.)
        However, it does appear that SketchUp has a limit to Command objects regardless - so if you have many plugins installed you may experience greyed out menus.
        If you load just Selection Toys it does not grey out. If you remove a few other plugins you'll not get the grey outs. The only thing is that Selection Toys adds a few items which fills up the limit more than others.
          Thomas
          I wasn't suggesting that your tool was faulty - it just adds lots of commands that use up the available 'slots'.
          It would be good if Google could resolve this issue as we are currently hitting a wall with the number of plugins we can load at once if they have commands set ?
          You don't need commands to have an item display in the context-menu, unlike a toolbar that has to have a command, but a command does allow 'validation_proc' etc... BUT if you disable selection_toys in the context-menu it still tips the commands over the limit and grays-out - it seems it's the commands total not the number used in the context-menu itself! The only way is to stop it is to stop it loading completely - OR if I want its functionality then I need stop some other tools loading that make numerous commands themselves. Which brings us back to this thread - these tools will cause gray-outs if you have many commands getting made by tools, so one way to temporarily disable some - selection_tools is a soft target as you can remove many commands with one disablement!
          It's a pity we can't dynamically load/unload commands without restarting Sketchup...
            Yea - the design of Selection Toys UI manager is troublesome with the current Command limitations. For version 3 it'll be completely different, but that's not an update that'll be coming in the immediate future. ๐Ÿ˜ž
              baldaman
              Dear TAK2HATA
              It is a great pain to see your country so violently damaged.
              Here in Paris we keep looking toward japan and pray for all japanese people.
              United, we shall overcome!
                tulacong
                thank you
                  diegog321
                  Thank you very much for the plugin
                  Hope you are doing OK
                  Diego
                  • ElibjrE Offline
                    Elibjr
                    @tak2hata said:
                    Thanks about the info of world steel beam tables.
                    I will read it later.
                    Earthquake hit me now!
                    Very Terrible.
                    First of all, thank you for the use if the plug-in. But after this seeing this note and looking at he latest news reports of a 9+ Richter scale earthquake that hit your country last week and the rising with issue with the nuclear power plant because of the earthquake, I am praying that you and your family are OK! Please let us know your status when you can so we know that you are OK. We all appreciate what the work you and others have done on this plug-in, but my family and I are praying that you and your family will be able to get though this tough time.
                    Elibjr.
                    • H Offline
                      howardhong
                      kanvare!..nippon...
                      • Bob JamesB Offline
                        Bob James
                        @tig said:
                        @bob james said:
                        @tig said:
                        This 'b15' is one country's standard 'code'
                        Does anyone have a "Rosetta Stone" to convert these codes into USA codes?
                        try this http://www.structural-drafting-net-expert.com/steel-beam.html ?
                        My old SteelSections includes most UK/EU sizes... in the txt file...
                        Thanks, TIG.
                        I think I'll stick with Profile Builder.
                          tocthieuso83
                          Thank you very much!
                            tak2hata
                            Thanks for a lot of people cheers us!
                            Japan still seriously,
                            but we will revive surely,thanks to everyone's assistance.
                            Thank you really.
                            I move to the west of Japan now, and am working.
                            So correcting this plugin seems for a while.
                            To become more convenient, I want to devise it.
                            Thank you for you ..true...
                            by TAK2HATA
                              Take care - all the best!
                              • ElibjrE Offline
                                Elibjr
                                Thank you really.
                                Great to see that you are alive and well. take your time with the plugin. Your well being is much more important! Thanks again for it. โ˜€
                                  tulacong
                                  @tak2hata said:
                                  Building structure tool for Sketchup
                                  Draw Structures and Modify Easy.
                                  v0.2--solved probrem about reading default first time by TIG.Thanks.
                                  [attachment=0:300teki1]<!-- ia0 -->building_structure_tool.zip<!-- ia0 -->[/attachment:300teki1]
                                  [attachment=1:300teki1]<!-- ia1 -->bst_icons.png<!-- ia1 -->[/attachment:300teki1]
                                  This is still a beta version.
                                  It released it though it was early for a moment.
                                  The animation of the operation explanation is here. http://www.youtube.com/watch?v=nr6CXOk1p3s
                                  A very huge earthquake hit Japan.
                                  It made a lot of miserable.
                                  If you feel this tool useful then I want you to donate for 2011 Japanese Earthquake and Tsunamim,please.
                                  It will cheer us strongly.
                                  Thanks.
                                  thanks verymuch
                                  • U Offline
                                    Uguzzone
                                    I just made the donation for save the children for japan.
                                    Thanks for the plugin
                                      ๐Ÿ‘
                                      • tibetT Offline
                                        tibet
                                        hi guys,
                                        from some odd reason i canยดt recover BST icons.
                                        any idea how to fix it please?
                                        i reinstalled it again without success.
                                        maybe, i miss something, because everything seems to be fine.
                                        thanks!
                                        http://i52.tinypic.com/6pw36v.jpg
                                        SU 2015 Pro on Win10 x64
                                          glro
                                          [quote="tak2hata"]Building structure tool for Sketchup
                                          [attachment=0:1inpg13m]<!-- ia0 -->building_structure_tool.zip<!-- ia0 -->[/attachment:1inpg13m]
                                          very efficient
                                          a limitation, though, that makes it useless when you have to draw steel beams that are not parallel to the global axis
                                          changing to a provisional axis system doesn't help
                                          in addition to girder, beam, column, which a re horizontal or vertical, ... would it be possible to draw a structural member in any direction?
                                            alexdobras
                                            a very big thanks for the plugin!
                                            • 16
                                            • 17
                                            • 3 / 17
