    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.2k Views 107 Watching
      paddyclown
      @bob james said:
      @gistman said:
      Seems like a fantastic tool, although I can't get it to work- "Can`t click "Next point". Any tool."
      Same for me.
      yeh, me too 😞, no second click possible, (SU pro 8 on Vista platform)....
      • TIGT Online
        I have now loaded the tool and get the same problems...
        Here are two 'tweaked' files that work.
        Replace one in Plugins and the other in the tool's own subfolder.
        I have swapped the \ to / in the 'require' statements.
        I have trapped a 'read_default' error. The author having used/tested the tool for some time won't have realized that his code crashed if a particular registry entry was missing [probably as he had written that entry ages ago in earlier tested code], but because it crashes at the start the entry never gets written ! In 'tst_main', at line #123, I've added a trap so there is no crash and it now works, writing the needed registry entry the first time you use the tool, and so all is now well...building_structure_tool.rbtst_main.rb
          macannurc
          thanks to both tak2hata & Tig πŸ€“
          I can finally test it, and it seems a plugin with great potential
          Google SketchUp Pro 7 (7.0.10248)
          Mac OSX 10.4.11, old PPC G4
            tak2hata
            Thanks TIG!
            Thank you for helping.
            It was not hit on at all where I am necessary to put up the hand.
            It was doubted that it was a problem of the inch in my conception.
            Now It work with your help!
            EDIT: by TIG - An updated version of all of the files is now available here...
            http://forums.sketchucation.com/viewtopic.php?p=315482#p315482
            Hi,howardhong!
            I'm grad to see you.
            Help from Korea and other countries will surely recovers Japan.
            Therefore, we also work hard.
            Thanks for all!
            best regard.
            by TAK2HATA
            • HumpmetwiceH Offline
              Humpmetwice
              Is there anyway to add beam sizes to this?
                paddyclown
                just a word: thankyou ! πŸ‘
                well done guys, a nifty tool is born... maybe you should get together with Goh who does the 1001bit tools ? Between you you may just turn SU into the only fun BIM program out there πŸ˜„
                all the best...
                • TIGT Online
                  In the folder 'building_structure_tool' there are two CSV files:
                  default_pflist.csv contains the steel sizes and standard sizes of other things used in the tool
                  You can edit those in plain text editor - e.g. around line #151
                  ##STEEL_BEAM,β€œSœ¬—À,,,,,,
                  b15,H-150x75x5x7,,,,matSTEEL,BLACK,BLACK
                  b19,H-198x99x4.5x7,,,,matSTEEL,BLACK,BLACK
                  This 'b15' is one country's standard 'code', and the 4 relevant sizes in 'mm', 'material' etc... but you can add your own - just ensure that the ',' count is the same...
                  You could also add other things like additional items at the end...
                  Also default_pipelist.csv contains 'tube' code/sizes.
                  • Bob JamesB Offline
                    Bob James
                    Does anyone have a "Rosetta Stone" to convert these codes into USA codes?
                    • W Offline
                      watkins
                      Don't forget this:
                      301 Moved Permanently
                      (www.cad-addict.com)
                      and this:
                      Flange Beams and Columns
                      Wide-flange and I-flange beams and columns
                      (sketchup.engineeringtoolbox.com)
                      There is also beamtool.rb and Steels.rb which can be found here http://rld.crai.archi.fr/rld/plugins_list_az.php
                      Regards,
                      Bob
                      • TIGT Online
                        try this http://www.structural-drafting-net-expert.com/steel-beam.html ?
                        My old SteelSections includes most UK/EU sizes... in the txt file...
                        • W Offline
                          watkins
                          Dear TIG,
                          Where would one find 'ye olde SteelSection.rb'?
                          Regards,
                          Bob
                          • TIGT Online
                            @watkins said:
                            ...Where would one find 'ye olde SteelSection.rb'?...
                            Try here http://rhin.crai.archi.fr/rld/plugin_details.php?id=412 [all all good scripts go in the twilight of their years.........]
                            • W Offline
                              watkins
                              Ah, didn't realise that Steels was the same as SteelSection.
                              Thanks, Bob
                                It would appear that this plugin causes the old grayed out menu items. I haven't seen that for awhile but it happened after I installed this one. I've deleted it and I have no problem.
                                  tak2hata
                                  Thanks about the info of world steel beam tables.
                                  I will read it later.
                                  Earthquake hit me now!
                                  Very Terrible.
                                  by TAK2HATA
                                  • TIGT Online
                                    @dave r said:
                                    It would appear that this plugin causes the old grayed out menu items. I haven't seen that for a while but it happened after I installed this one. I've deleted it and I have no problem.
                                    This new tool does add 14 additional commands, which might just tip you over the mythical limit and then causes gray-outs...
                                    It needs those for the Toolbar, but since it doesn't use context-menus it's weird as that is the usual connection...
                                    You don't need to uninstall the tool completely, you can simply rename 'building_structure_tool.rb' as 'building_structure_tool.rb.txt' so it isn't auto-loaded at startup; then later if you want the tool's functions you can type load "building_structure_tool.rb.txt" in the Ruby Console and it's loaded for the rest of that session...
                                    Do you have 'ContextMenuOptimizer' by AlexM, which tries to optimize 'commands' to reduce 'gray-outs'?
                                      Hi TIG,
                                      I know I could have renamed it but I still have the ZIP file. I don't have AlexM's ContextMenuOptimizer but I'll look for it. The greyed out menu thing was a big issue before with TOS or something else but the plugin was updated and the problem seemed to have gone away. I don't remember what the changes was to the specific plugin, though.
                                      • TIGT Online
                                        @dave r said:
                                        Hi TIG,
                                        I know I could have renamed it but I still have the ZIP file. I don't have AlexM's ContextMenuOptimizer but I'll look for it. The grayed out menu thing was a big issue before with TOS or something else but the plugin was updated and the problem seemed to have gone away. I don't remember what the changes was to the specific plugin, though.
                                        The 'ContextMenuOptimizer' is available here http://forums.sketchucation.com/viewtopic.php?p=252413#p252413
                                        There is a 'theoretical' limit of ~1000 commands being active before the context-menu 'breaks'.
                                        The optimizer tries to 'flush' unused commands so this is avoided...
                                        Unfortunately you have to have a 'command' made if you are to use a toolbar, so the more tools that you have that use toolbars the nearer you will get to the limit and then get possible gray-outs.
                                        The earlier problem with some of Fredo's tools [and a few others] was that they remade a new command every time you used the context-menu, and thereby it quickly used up the available command slots as the old command was still remembered too... and the dreaded gray-outs ensued...
                                        These issues were addressed in the tools' code, and one command is now initially defined and reused as needed, so as long as you've updated all of Fredo's tools etc then that particular problem has gone.
                                        However, I still get occasional gray-outs on context-menus when I have a lot of tools loading commands during tests etc, so it is possible to exceed this limit even with the optimizer running and when all tools themselves have been optimized...
                                        Remember that most context-menu items will remain available on the end of the Edit Menu, so you can usually do the required actions that way if the gray-out happens - but if all else fails you must save and restart πŸ˜’
                                          Thanks TIG. Installing it now.
                                          • TIGT Online
                                            Incidentally I have found that the one script that tips we over the edge is thomthom's selection_toys ad that adds dozens of new commands under three submenus in the context-menu. If I stop this loading I get no gray-outs πŸ˜•
                                            • 16
                                            • 17
                                            • 2 / 17
