    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.3k Views 107 Watching
      dtrarch
      Dear tak2hata
      Needless to say out hearts go out to the people of Japan and most personally to yourself as an example of generosity and the goodness of your people.
      World Vision and the Red Cross are secure recommends to send help to.
      Thank you for giving us all a heads up to help.
      We pray for you all.
      David Rich Architect
      aka dtrarch
      • W Offline
        watkins
        For those in the UK, here is a news bulletin from the Disasters Emergency Committee:
        ERROR: The request could not be satisfied
        (www.dec.org.uk)
        They point to the Red Cross as the most competent organisation to help in a developed country like Japan:
        Document Moved
        (www.redcross.org.uk)
        Save The Children have also launched an appeal:
        Page Not Found - 404
        404 error page
        Save the Children UK (www.savethechildren.org.uk)
        Regards,
        Bob
          tak2hata
          Thank you a lot.
          At present, because I am away from a horrible place,I am safe.
          Please use this plug-in without holding back because it is completely free.
          It is hope that it is the most insufficient in Japan now.
          The following are donation. πŸ˜„
          Hi,d12dozr and watkins.
          "Red Cross" is a famous group also in Japan.
          That is one of best choices.
          And the site made by Google also accepts donation.
          http://goo.gl/saigai
          If you have google wallet,it is easy to donate.
          by TAK2HATA
          • H Offline
            howardhong
            i'm in seoul, korea
            i got a lot of photos from japan
            it's really,really big disaster
            we korean people's now gethering a donations for japanese
            and rescue team of 200 with 3 military aircraft was sent this morning
            and tanker ship of LNG is ready to start
            lets pray for japanese people
              maxosmedia
              Error Loading File building_structure_tool.rb
              no such file to load -- building_structure_tool\tst_main.rb
              MacOSX SU8
                maxosmedia
                Cant click "Next point". Any tool. Tools dont work now on Mac
                MacOSX SU8
                  MacOSX SU8
                  I suspect you have misinstalled from the zip file.
                  When a script comes in a zip file you usually get one script [.rb] file and a folder containing everything else that the rb file 'loads' or needs to work.
                  The 'loose' rb file and the folder MUST be put into your Plugins folder exactly as they are arranged in the zip file.
                  Do not move files from the subfolder into the Plugins folder.
                  This shows the only two additional things that you should have in your Plugins folder after the installation.Capture.PNG If you have put some of the files in Plugins that should actually be in the subfolder then please move/remove as needed...
                    gistman
                    Seems like a fantastic tool, although I can't get it to work- "Can`t click "Next point". Any tool." Same as maxosmedia. I'm using windows XP with SU v7 and reloaded it as TIG suggested. I was wondering if there is conflict with another plug-in? Just a guess as I have no experience writing ruby.
                      maxosmedia
                      MacOSX SU8
                      This shows the only two additional things that you should have in your Plugins folder after the installation.[attachment=0:3vlvifww]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:3vlvifww] If you have put some of the files in Plugins that should actually be in the subfolder then please move/remove as needed...
                      TIG, Thank you! I just did. Therefore, no error at this point. Error may be found in document building_structure_tool.rb strings 5β€”10:
                      %(#FF0000)[require 'building_structure_tool\tst_main.rb'
                      require 'building_structure_tool\tst_extend_to_face.rb'
                      require 'building_structure_tool\tst_extend_to_structure.rb'
                      require 'building_structure_tool\tst_chamfer_structures.rb'
                      require 'building_structure_tool\tst_grow_to_structure.rb'
                      require 'building_structure_tool\tst_grow_to_face.rb']
                      These lines contain a "" instead of the "/" for macintosh file system.
                      If I correct the document building_structure_tool.rb, the tool is loaded with no error messages, but the tool does not work!
                        tak2hata
                        Hi, TIG and maxosmedia.
                        Thank you for helping.
                        I am out now.
                        I will correct it after.
                        I will investigate the cause.
                        Please wait for a while.
                        by TAK2HATA
                        • Bob JamesB Offline
                          Bob James
                          Same for me.
                            paddyclown
                            @bob james said:
                            Same for me.
                            yeh, me too 😞, no second click possible, (SU pro 8 on Vista platform)....
                              I have now loaded the tool and get the same problems...
                              Here are two 'tweaked' files that work.
                              Replace one in Plugins and the other in the tool's own subfolder.
                              I have swapped the \ to / in the 'require' statements.
                              I have trapped a 'read_default' error. The author having used/tested the tool for some time won't have realized that his code crashed if a particular registry entry was missing [probably as he had written that entry ages ago in earlier tested code], but because it crashes at the start the entry never gets written ! In 'tst_main', at line #123, I've added a trap so there is no crash and it now works, writing the needed registry entry the first time you use the tool, and so all is now well...building_structure_tool.rbtst_main.rb
                                macannurc
                                thanks to both tak2hata & Tig πŸ€“
                                I can finally test it, and it seems a plugin with great potential
                                Google SketchUp Pro 7 (7.0.10248)
                                Mac OSX 10.4.11, old PPC G4
                                  tak2hata
                                  Thanks TIG!
                                  It was not hit on at all where I am necessary to put up the hand.
                                  It was doubted that it was a problem of the inch in my conception.
                                  Now It work with your help!
                                  EDIT: by TIG - An updated version of all of the files is now available here...
                                  http://forums.sketchucation.com/viewtopic.php?p=315482#p315482
                                  Hi,howardhong!
                                  I'm grad to see you.
                                  Help from Korea and other countries will surely recovers Japan.
                                  Therefore, we also work hard.
                                  Thanks for all!
                                  best regard.
                                  by TAK2HATA
                                  • HumpmetwiceH Offline
                                    Humpmetwice
                                    Is there anyway to add beam sizes to this?
                                      paddyclown
                                      just a word: thankyou ! πŸ‘
                                      well done guys, a nifty tool is born... maybe you should get together with Goh who does the 1001bit tools ? Between you you may just turn SU into the only fun BIM program out there πŸ˜„
                                      all the best...
                                        In the folder 'building_structure_tool' there are two CSV files:
                                        default_pflist.csv contains the steel sizes and standard sizes of other things used in the tool
                                        You can edit those in plain text editor - e.g. around line #151
                                        ##STEEL_BEAM,β€œSœ¬—À,,,,,,
                                        b15,H-150x75x5x7,,,,matSTEEL,BLACK,BLACK
                                        b19,H-198x99x4.5x7,,,,matSTEEL,BLACK,BLACK
                                        This 'b15' is one country's standard 'code', and the 4 relevant sizes in 'mm', 'material' etc... but you can add your own - just ensure that the ',' count is the same...
                                        You could also add other things like additional items at the end...
                                        Also default_pipelist.csv contains 'tube' code/sizes.
                                          Bob James
                                          Does anyone have a "Rosetta Stone" to convert these codes into USA codes?
                                          • W Offline
                                            watkins
                                            Don't forget this:
                                            301 Moved Permanently
                                            (www.cad-addict.com)
                                            and this:
                                            Flange Beams and Columns
                                            Wide-flange and I-flange beams and columns
                                            (sketchup.engineeringtoolbox.com)
                                            There is also beamtool.rb and Steels.rb which can be found here http://rld.crai.archi.fr/rld/plugins_list_az.php
                                            Regards,
                                            Bob
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 17 / 17
