    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
      d12dozr
      Here are some legitimate places to donate:
      World Vision or text β€œ4japan” to 20222 to send a $10 donation to the group. It will show up on your next mobile phone bill.
      The American Red Cross also accepts donations via text message. Text "redcross" to 90999, and you can make a $10 donation to the organization.
      Contribute $10 via the Salvation Army - text "japan" or "quake" to 80888.
      More contribution info here: http://news.blogs.cnn.com/2011/03/13/tsunami-aid-and-relief-how-you-can-help/?hpt=T1
      http://goo.gl/f7ooYh
      • utilerU
        utiler
        I'm with you Frederik. The Earthquake in Japan is horrific. The images broadcast around the world defy belief.....
        tak2hata, I am glad to hear you are OK. Be sure to provide us a credible ste to donate too; I will be more than happy too.
        Take care,
        Andrew
        Just Curious...
          dtrarch
          Dear tak2hata
          Needless to say out hearts go out to the people of Japan and most personally to yourself as an example of generosity and the goodness of your people.
          World Vision and the Red Cross are secure recommends to send help to.
          Thank you for giving us all a heads up to help.
          We pray for you all.
          David Rich Architect
          aka dtrarch
          • W
            watkins
            For those in the UK, here is a news bulletin from the Disasters Emergency Committee:
            ERROR: The request could not be satisfied
            (www.dec.org.uk)
            They point to the Red Cross as the most competent organisation to help in a developed country like Japan:
            (www.redcross.org.uk)
            Save The Children have also launched an appeal:
            http://www.savethechildren.org.uk/en/japan-earthquake-and-tsunami-appeal.htm?sourcecode=A11038054
            Regards,
            Bob
            • T
              tak2hata
              Thank you a lot.
              At present, because I am away from a horrible place,I am safe.
              Please use this plug-in without holding back because it is completely free.
              It is hope that it is the most insufficient in Japan now.
              The following are donation. πŸ˜„
              Hi,d12dozr and watkins.
              "Red Cross" is a famous group also in Japan.
              That is one of best choices.
              And the site made by Google also accepts donation.
              http://goo.gl/saigai
              If you have google wallet,it is easy to donate.
              by TAK2HATA
              • H
                howardhong
                i'm in seoul, korea
                i got a lot of photos from japan
                it's really,really big disaster
                we korean people's now gethering a donations for japanese
                and rescue team of 200 with 3 military aircraft was sent this morning
                and tanker ship of LNG is ready to start
                lets pray for japanese people
                  maxosmedia
                  Error Loading File building_structure_tool.rb
                  no such file to load -- building_structure_tool\tst_main.rb
                  MacOSX SU8
                    maxosmedia
                    Cant click "Next point". Any tool. Tools dont work now on Mac
                    MacOSX SU8
                      MacOSX SU8
                      I suspect you have misinstalled from the zip file.
                      When a script comes in a zip file you usually get one script [.rb] file and a folder containing everything else that the rb file 'loads' or needs to work.
                      The 'loose' rb file and the folder MUST be put into your Plugins folder exactly as they are arranged in the zip file.
                      Do not move files from the subfolder into the Plugins folder.
                      This shows the only two additional things that you should have in your Plugins folder after the installation.Capture.PNG If you have put some of the files in Plugins that should actually be in the subfolder then please move/remove as needed...
                      • G
                        gistman
                        Seems like a fantastic tool, although I can't get it to work- "Can`t click "Next point". Any tool." Same as maxosmedia. I'm using windows XP with SU v7 and reloaded it as TIG suggested. I was wondering if there is conflict with another plug-in? Just a guess as I have no experience writing ruby.
                          maxosmedia
                          MacOSX SU8
                          This shows the only two additional things that you should have in your Plugins folder after the installation.[attachment=0:3vlvifww]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:3vlvifww] If you have put some of the files in Plugins that should actually be in the subfolder then please move/remove as needed...
                          TIG, Thank you! I just did. Therefore, no error at this point. Error may be found in document building_structure_tool.rb strings 5β€”10:
                          %(#FF0000)[require 'building_structure_tool\tst_main.rb'
                          require 'building_structure_tool\tst_extend_to_face.rb'
                          require 'building_structure_tool\tst_extend_to_structure.rb'
                          require 'building_structure_tool\tst_chamfer_structures.rb'
                          require 'building_structure_tool\tst_grow_to_structure.rb'
                          require 'building_structure_tool\tst_grow_to_face.rb']
                          These lines contain a "" instead of the "/" for macintosh file system.
                          If I correct the document building_structure_tool.rb, the tool is loaded with no error messages, but the tool does not work!
                          • T
                            tak2hata
                            Hi, TIG and maxosmedia.
                            Thank you for helping.
                            I am out now.
                            I will correct it after.
                            I will investigate the cause.
                            Please wait for a while.
                            by TAK2HATA
                            • Bob JamesB
                              Bob James
                              Same for me.
                              • P
                                paddyclown
                                @bob james said:
                                Same for me.
                                yeh, me too 😞, no second click possible, (SU pro 8 on Vista platform)....
                                  I have now loaded the tool and get the same problems...
                                  Here are two 'tweaked' files that work.
                                  Replace one in Plugins and the other in the tool's own subfolder.
                                  I have swapped the \ to / in the 'require' statements.
                                  I have trapped a 'read_default' error. The author having used/tested the tool for some time won't have realized that his code crashed if a particular registry entry was missing [probably as he had written that entry ages ago in earlier tested code], but because it crashes at the start the entry never gets written ! In 'tst_main', at line #123, I've added a trap so there is no crash and it now works, writing the needed registry entry the first time you use the tool, and so all is now well...building_structure_tool.rbtst_main.rb
                                    macannurc
                                    thanks to both tak2hata & Tig πŸ€“
                                    I can finally test it, and it seems a plugin with great potential
                                    Google SketchUp Pro 7 (7.0.10248)
                                    Mac OSX 10.4.11, old PPC G4
                                    • T
                                      tak2hata
                                      Thanks TIG!
                                      It was not hit on at all where I am necessary to put up the hand.
                                      It was doubted that it was a problem of the inch in my conception.
                                      Now It work with your help!
                                      EDIT: by TIG - An updated version of all of the files is now available here...
                                      http://forums.sketchucation.com/viewtopic.php?p=315482#p315482
                                      Hi,howardhong!
                                      I'm grad to see you.
                                      Help from Korea and other countries will surely recovers Japan.
                                      Therefore, we also work hard.
                                      Thanks for all!
                                      best regard.
                                      by TAK2HATA
                                      • HumpmetwiceH
                                        Humpmetwice
                                        Is there anyway to add beam sizes to this?
                                        • P
                                          paddyclown
                                          just a word: thankyou ! πŸ‘
                                          well done guys, a nifty tool is born... maybe you should get together with Goh who does the 1001bit tools ? Between you you may just turn SU into the only fun BIM program out there πŸ˜„
                                          all the best...
                                            In the folder 'building_structure_tool' there are two CSV files:
                                            default_pflist.csv contains the steel sizes and standard sizes of other things used in the tool
                                            You can edit those in plain text editor - e.g. around line #151
                                            ##STEEL_BEAM,β€œSœ¬—À,,,,,,
                                            b15,H-150x75x5x7,,,,matSTEEL,BLACK,BLACK
                                            b19,H-198x99x4.5x7,,,,matSTEEL,BLACK,BLACK
                                            This 'b15' is one country's standard 'code', and the 4 relevant sizes in 'mm', 'material' etc... but you can add your own - just ensure that the ',' count is the same...
                                            You could also add other things like additional items at the end...
                                            Also default_pipelist.csv contains 'tube' code/sizes.
                                            • 16
                                            • 17
                                            • 1 / 17
