    Curve Based Upon Varying Given Heights
    17 Posts 10 Posters 878 Views 10 Watching
      thebreadking
      Hi all,
      This seems like it'll only need a quick response, but we'll see. I'm looking to create a curved line, floating in space, that slopes to varying Z-heights along its path, dependent on the heights I prescribe. I guess the easiest way to describe it is that I'm trying to create a single-line path that would look sort of like a roller coaster.
      How I have it set up so far: I've drawn a series of flat curves (height of 0) around my project site. At the end points of each curve I have created a vertical line up to a specified height. In my head I can weld these curves together to create a path, and then initiate a plugin that would allow me to select the flat curved path and the vertical lines, which would result in the ascending and descending curved line I mentioned above.
      It seems like a very easy request, I just don't know of the proper plugin to create it. Any ideas?
      For a little background, I plan on using this floating curved line to create a sloping camera path from which I'll use SU Animate to generate scenes from for a walkthrough video.
      • honoluludesktopH Offline
        honoluludesktop
        Not sure what you are asking, but the following was built by first locating the vertical line, changing the model axis, adding the rectangular face, and finally drawing the arc. You can later remove the face (while retaining the curved line), and return the axis to its original position and orientation.Temp02.png
          thebreadking
          I guess it would have been smarter and easier just to post an image of what I'm trying to achieve, please see attachment.
          The blue line indicates the flat curvilinear path (z-value of 0). Each of the black lines are along the vertical axis and have an endpoint of varying heights. I'm looking for a plugin that would allow me to select the flat curvilinear path, then select the vertical lines, and the plugin's outcome would be a new curvilinear path that follows that of the existing flat curves, but ascends and descends based upon the height of the endpoint of the vertical lines. Essentially turning that flat curvilinear path into one with varying elevations. Hopefully that makes more sense.
          Does such a plugin exist? Thanks again.
            Could you share this file? I am not promising anything just thinking. 😒
            • mitcorbM Offline
              mitcorb
              It seems you would want to specify xyz values for key points such as the transition point for sequential curves and key points for the curves' "attitudes",that is, maybe the xyz value of the midpoint of each curve. Obviously, you might also need to specify the xyz of the centerpoints of all the radii.
              After all this precise input, you will probably still have to do some proportional/"eyeball" reshaping.
              But then, maybe somebody already worked all of this out--in Sketchup--but I don't know that.
                thebreadking
                You'll find it attached. I have no problem doing it the difficult way (with all of the precise input as mitcorb mentioned), but I've had such success with finding the appropriate plugin for difficult tasks I was hoping there would be one for something like this.
                If there isn't, I may end up using Curve Shearing for each individual segment and see how that goes. Its not automatic, but its the easiest thing I can think of for the time being.
                Curvilinear Path Example
                  honoluludesktop
                  As outlined previously:Temp00.png
                    gulcanocali
                    Hi thebreadking,
                    I believe Tgi3D SU Amorph has a very nice and easy solution to your problem. Please see the video below. I created the video in one shot, it is unedited, so a bit long (still only 3 mins 12 secs though).
                    Please note that you would not be able to do this easily with the free Training Edition as your curves exceed the limit of the max. number of vertices allowed in the free version. I have not tried it myself but you should be able to work around that by limiting the number of vertices in each curve to less than 10 and working with more curves.
                    [flash=480,390:1jivq7s2]http://www.youtube.com/v/XqHsDoiuYPY?fs=1&hl=en_US[/flash:1jivq7s2]
                    Gulcan Ocali
                    Product Manager
                    http://www.Tgi3D.com
                    • W Offline
                      wyatt
                      You could use Extrude Edges by Edges and Tools on Surface. First group all the vertical lines and weld the path into a single curve. The highest desired elevation appears to be at the start of the path; copy that vertical line to the end point. Group these lines. Extrude edges by edges using this group and the flat animation path you've drawn. Now use Line on Surface to connect the vertical points you've drawn. When the degree of curvature between the two points nears or is greater than 18 0degrees, you'll need to calculate the midpoint elevation and draw to that intermediate point before continuing on. The process isn't automated, but I think it will be easier than manually figuring all of the centerpoint elevations. Hopefully this makes sense; I can post something if it doesn't.
                        Roger
                        This is interesting as I was trying to explain to my son how Greek stone masons were able to perfectly replicate the entasis from one column to the next without having paper plans of computer files. At Didyma a stone was found with many varying length lines spaced every inch over the face of the stone. Nobody was sure what it meant until some one took those lines and spaced them the same distance apart as the length of the stone drums that make up a temple column. It turned out that the lines were the actual width measurement of the columns but the height of the drums on the stone were compressed from several feet to an an inch or two. The teams of workmen would all go to the same stone to reset their compasses as they worked ther way up the column. As a result not only were the columns practically seamless, butthey all matched to the thousanth of an inch even though hundred of workment were working the columns independently.
                        http://www.azcreative.com
                          honoluludesktop
                          Didyma, what part of Arizona is that?-)
                            Roger
                            It is west of Honolulu. Turkey. I thin the measure rock was in a tunnel and archeologists missed the significance of thelines for years because of poor lighting. One day grazing light from the tunnel mouth hot the wall just right and researches had one of those aha! moments.
                            Didyma, Turkey.
                              honoluludesktop
                              I knew it sounded familiar. I think my dad's friend Barry, took me there when I was a child:-)
                                Does this work? The red is the path through the Z-values given. With more Z-values, the path would be smoother in its elevation changes.
                                Curvilinear Path Example1.skp
                                • mitcorbM Offline
                                  mitcorb
                                  The path defined is simply the midline. If this is for a roller coaster, you'd need a ribbon.
                                  And the paths for the edges will need to vary to compensate for centripetal effects.
                                    If you separate out the vertical lines and the curves by grouping the lines you can use the Move tool to adjust the ends of the curved parts to the tops of each line... They simply snap to them...Capture.PNG
                                      mac1
                                      Your elevation ticks are way under sampled. There are many curves that can fit the data( plan view) you have presented. If you want just a picture then what Dave has shown is great but if its use is for some real world application then you will have to establish some criteria on the spacing of you elevation samples and usually based on some type of rms error etc. 😞
