    1.5k Posts 471 Posters 3.4m Views 470 Watching
      Yeah, it just fills the hole but you can delete the fill easily.
      However in the file, the round radius was set to 7' 7/8". I figured that about 3/8" is the max "desired" radius so you may want to revise that.
      delete this
      end up with this
      • fredo6F Offline
        @frommer1 said:
        I tried rounding the corners on the left hole and it is gone. the hole on the right is untouched. Please help! i tried erasing the center and the only way it shows up is if i delete some lines on the roundover
        As pointed out by Bob James and Gaieus, the rounding took place, but Sketchup automatically created a face when RoundCorner build the edges of the rounding.
        This may happen in those situations, and actually not easy to detect and correct.
        • F Offline
          Frommer1
          @bob james said:
          @frommer1 said:
          @gaieus said:
          Could you attach the file,please? (Maybe a "before" and an "after" version of the same geometry in it)
          Here is is. i tried rounding the corners on the left hole and it is gone. the hole on the right is untouched. Please help! i tried erasing the center and the only way it shows up is if i delete some lines on the roundover
          I clicked on the area where the left hole should be. It was "filled in" as evidenced by the blue dots. I then deleted the "blue dot" area and was left with a rounded edge hole as expected.
          Thanks a lot. i did what you said and got the required result. I am new to Sketchup and am still learning!
          • N Offline
            nalkhayat
            I hope you can help me out with my error message? I posted a screenshot (above).
            • fredo6F Offline
              I don't see the screenshot anywhere.
              Can you open the Ruby console, and check if there is anything displayed when you click on one of the RoundCorner icon.
                Here is the post with the ruby console error and the screenshot:
                http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&p=303719#p303719
                • fredo6F Offline
                  @Gaieus: thanks for the information
                  @Frommer1: I think I know what the issue is.
                  On RoundCorner, there is a trace file created for Mac, because some Mac users have signaled problems with performance. See that post http://forums.sketchucation.com/viewtopic.php?f=323&t=33021#p291152
                  The problem comes from the fact that the setup of the Mac system prevents to create files in the Sketchup Plugins directory and sub-directories from a program. This is where RoundCorner stops working.
                  I would suggest that you try to change the security settings of the the SU Plugins folder, because anyway, you'll get the same problem when the script saves the parameters for further reuse.
                    Really? ... I think I have to check my plugins. Think Selection Toys tries to do this.
                      arhetip
                      I'm joining the fan club Fredo... Excellent work.
                        dcdesign
                        I'm unable to access the RoundCorner tool in SU8 with a 'Limited' User account.
                        I did not have this issue in SU7 using this same 'Limited' User account.
                        Also in contrast, the Curviloft tool opens without issue in SU8 using the same 'Limited' User account.
                        If I change the 'Limited' account to an 'Administrator' account the RoundCorner tool opens without issue.
                        I tried a new download and overwrite extraction of the RoundCorner tool and LibFredo6.rb just for grins to see if there was any change, but there was none. Also, SU7 has been removed so I know it's being extracted into the SU8 plugin directory.
                        I'd rather not have to log in to the 'Administrator' account in order to use the 'RoundCorner' tool.
                        Any suggestions or work-arounds would be appreciated. Using XP Home SP3.
                        Ruby Console output-
                        Error: #<Errno::EACCES: Permission denied - C:/Program Files/Google/Google SketchUp 8/Plugins/Fredo6Trace.txt>
                        C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Core_36.rb:593:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Core_36.rb:593:in open'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Core_36.rb:593:in trace6' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:313:in init_palette'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:128:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:42:in new'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:42:in launch' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:33:in action__mapping'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:117:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:117:in launch_action'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb:143:in launch_action' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb:159:in startup'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:672:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:672:in command_invoke'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:654:in build_config_commands' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Traductor.rb:874:in call'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Traductor.rb:874:in `add_command'
                        • fredo6F Offline
                          In general, it is recommended to have those permissions to create and write files in the SU plugin folder and subfolders.
                          1. to store updates to default parameters (they are normally in the DEFPARAM_Dir folder). In the case of RoundCorner, all parameters are saved across sessions in file RoundCorner.def in that folder
                          2. For traces when applicable.
                          3. For other purposes.
                          On Vista and Windows 7, you may even have problems with security access when you update the plugin, due to the convoluted way Windows manages security for files.
                          I will however publish a version without traces (or ask the user where to put them)
                          • fredo6F Offline
                            NEW RELEASE: RoundCorner 2.2c- 23 Feb 11
                            This release deactivates the traces that were not necessary and could cause problems when the user does not have all write permissions in the SU Plugins directory.
                            There is no functional evolution compared with 2.2a
                            Please see main post for download
                              chromecatz
                              Ok, so I have to wait for the next release?
                              I am sorry but I am not using Windows anymore -)
                              I was used to work with sketchup 7 and the round corner plugin without any problems.
                              I have download and install curviloft, it works really fine and quick.
                              I have retry roundcorner, still having the same problem.
                              thanks fredo
                              Then, it would be helpful if other Mac users could tell if they have similar performance issues.
                              Hi Fredo,
                              I would really love to use your plugin, but am having similar problems involving the round corner plugin being very slow to load, selecting edges/faces, executing and using the RC interface. When I open the RC tool palette, SU and the entire computer slows considerably. The cursor freezes and I am unable to select out of the SU program and I am unable to use the cursor to select options in the RC or SU tool palette. This occurs regardless of how complex the geometry is i.e. box, or multifaceted solid. Permissions are set to read & write in the plugins folder on the Mac HD. I've browsed this thread, but don't know if this issue has been resolved yet. Thanks for your help.
                              DETAILS:
                              Mac OS 10.6.4, Intel Core i7
                              Round Corner 2.2c and LibFredo6 loaded in plugins folder
                              Best.
                              • fredo6F Offline
                                Chromecatz,
                                No progress so far, because I cannot reproduce the problem.
                                Could you drop the two attached files into the ROUNDCORNER_Dir_22 folder, then, after restarting Sketchup, exercise one the laynch of the plugin, the selection of edges and the generation of geometry.
                                RoundCorner_Tool.rb
                                RoundCorner_Algo.rb
                                Also, could you have the Ruby console open during this process, just in case you would see a message.
                                There is a trace file generated, FredoTraceRoundCorner.txt in the SU Plugin directory. Could you post it back or send it by PM.
                                Thanks very much.
                                  deanlegg
                                  Hi Fredo
                                  I just downloaded this but i didnt get LIBFREDO_Dir_36 or Libfredo6.rb
                                  Have I missed something
                                    @deanlegg said:
                                    Hi Fredo
                                    Re-read the first post from whence you downloaded the main tool... It tells you that the you need to download the Lib AND has a link to get it...Capture.PNG
                                      deanlegg
                                      😳 Doh!!
                                      Thanks Tig
                                        Tikva2
                                        Hi, i have a problem, and i really don`t know what to do...
                                        http://s009.radikal.ru/i308/1103/87/efabcbbcf61d.jpg
                                          axiaosnail
                                          wonderful!It improves my efficiency.Thanks!
                                          • fredo6F Offline
                                            Tikva2,
                                            Could you post the model.
                                            It looks like you have an extra edge on the face.
                                            fredo
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 73
                                            • 74
                                            • 67 / 74
