    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 1.2m Views 667 Watching
    • m.wendtM Offline
      m.wendt
      Hi All,
      I'm not very new to SU although I did just register here today and goodness, I wish I had taken the time 3 years ago to find this forum: it seems I have truly been missing out!
      I thought it right to at least introduce myself, say that I look forward to taking in the expansive knowledge which I'm sure is here, for I know that I'll be learning new things daily again (which I miss) about this program.
      Right now I see myself at a moderate knowledge base for SU.
      I use SU mostly for hobby reasons, although I am slowly compiling a few furniture lines for potential use later on.
      Well, I believe that's enough for personal introduction, now to start exploring the forum..
      • H Offline
        hhenk
        hello Gaieus,thanx for your reply.
        I was looking for the plugin 'Mover'.
        On a Dutch forum this plugin was mentioned in order making an animation in which
        the viewer walks through a room and doors open nicely before you walk onto another room.
        My goal in using SU is make drawings of different rooms, maybe fill them with artpieces, animate them,so people can have some idea of what is possible in an exhibition space.
        maybe also other plugins are usable in this case.
        hhenk
          Well, as far as I know, Mover does not animate objects:
          http://sketchuptips.blogspot.com/2007/08/plugin-mover-2.html
          There are a couple of object animating plugins like Proper animation, Keyframe animation or SketchyPhysics however.
            Shavedpeach
            Hello My Name is Shavedpeach, I am a developer in IMVU and I am trying to learn SketchUp to Make 3D Meshes for virtual Products. In the neo1471 link i was given a Plugin called Meshout, to Facilitate Loading my Files to The IMVU Previewer. I have loaded the files to Sketchup Plugins Folder Several times but can't get the Plugin to load. I am using the plugin Loader also. I just got the Pro 8 Version of SketchUp and was looking forward to creating Mesh, Perplexed now, Any suggestions
            ~Peach~ 😞
            Fetish&Fun ~Shavedpeach~
            • mitcorbM Offline
              mitcorb
              I do not know anything about the plugins you mentioned, but my first guess would be to go in Sketchup to Window>Preferences>Extensions and see if there is a blank checkbox for the plugin you want.
              EDIT Also, if there is a toolbar associated with it, go to View>Toolbars and check it in the list.
                Shavedpeach
                Here is what the README file says that comes with the script - after a bit of detective work πŸ˜’
                The script file itself is named " meshout.rbs" and should be placed in the "Plugins" folder within the Sketchup folder.
                Example:
                C:\Program Files\Google\Google SketchUp 8\Plugins\meshout.rbs
                Remember to delete any previous versions of this script that may be in the folder.
                After placing the script in its appropriate location, relaunch Sketchup.
                A new menu item should appear as Plugins > MeshOut v0.3.22 > Export IMVU File Set ...
                It will ask you to save your model before performing an export. The name of the exported files will default to the name of your model. A single XSF file should be generated containing the skeleton information. Each mesh will then be exported into separate XMF files as well as their associated textures. The file itself is encrypted so it's not possible to see what code is being used to run it, make menus etc...
                If all else fails try the novel idea of contacting the script's author πŸ˜•
                [This product was made by ApocalypseSurvivor all rights belong to ApocalypseSurvivor.
                RPVU are simply a host for this file and take no credit for the creation of MeshOut...
                Any problems feel free to ask at http://www.rpvu-imvu.com
                  Shavedpeach
                  @tig said:
                  Shavedpeach
                  Example:
                  I extracted the Files Directly to the Plugins Folder for SketchUp, as far as I know the Guy has Disappeared
                  it Mentions something on the Neo link...
                  IMVU has 37,000 Developers and its an Expanding Market. 3D Max has ruled there, But there are Quite A few Who Would like to Use Sk SketchUp if the File Conversion Issues were resolved. If anyone who is Familiar with the Ruby Script Would Be interested in creating a New Conversion Plug in there is a Lot of PPL who would Benefit. Peach πŸ˜„
                    Shavedpeach
                    Issue is Resolved TY
                      Please explain 'how' πŸ˜’
                      • StilTegS Offline
                        StilTeg
                        Good Day to Thee πŸ˜‰
                        I am new on this forum but I have been enjoying working with SketchUp for over 1 year now. I found some very useful plugins here recently and decided to join ...
                        Hope I might even be useful ...
                        doing technical engineering on SketchUp ... without plugins
                          Welcome Matthieu and enjoy yourself here!
                            Shavedpeach
                            I am totally New and Didn't Know that SKU had to be closed and Reopened before the new Plugins Loaded HAHA sorry I am learning though πŸ˜›
                            You will Be Happy to Know I have a Copy of "SketchUp 8 For DUMMIES" ...on hold for me at Barnes&Noble haha πŸ˜› ~Peach~
                              Shavedpeach
                              I may have spoke to Early, I got 1 file to Load but now I try to load my new xmf file in the previewer and it doesn't take. In the SketchUp Users Group it says that it won't work with 8, the first one i did loaded as a Mesh, so i don't understand why this won't. This is the link to the Previewer where it needs to load http://dl.dropbox.com/u/14571558/InstallPreviewer_372.9-20070514.exe Also there is an Updater which takes it to a current version http://dl.dropbox.com/u/14571558/IMVUPreviewerUpdater.exe If this is an Ongoing Issue for Present and Future SketchUp users perhaps there is a Need to Update the Plugin or redesign it for the Future SketchUp users...I have the feeling that AS will not be doing so ~Peach~
                              Here is an Acompanying Link where they explain the Meshing process involved http://www.imvu.com/creators/education_center.php?tutorial_id=2225474 ...If SketchUp is to remane Viable as a Tool to IMVU Meshers There needs to be a Resolve to the issues involved. If anyone is game to Help us out with a File Conversion Plugin for IMVU that will take us to the Present and future of IMVU i know there will be a LOT of Greatfull PPL ~Peach~ πŸ˜•
                                Shavedpeach
                                IMVU Tries to Make its self User Friendly to Creators, Of ALL the 3D Modeling programs Available [3D Max,Maya,etc.] SketchUp is Reasonably the Most Hands on user Friendly Program Available, Creators Like Me Want the Ability that SketchUp Offers, I hope My Appeal has brought the Situation to Clairity. I am forced to go to SketchUp 7 to get benefit of the MeshOut Plugin and as I have 8 PRO I hate the Idea ~Peach~
                                  Shavedpeach
                                  This is a Current post by Sintek in his Group and He is a SketchUp User and Helps with it for others
                                  Re: MESH QUESTION
                                  January 10, 2011 11:12PM
                                  I am in the process of writing a guide for meshout, it should be available soon, so if you want to hold on??
                                  in the mean time get it from here
                                  credit to ApocalypseSurvivor [www.smelczerczyk.karoo.net]
                                  oh and v8 of sketchup is not good, v 6 or v7 are the best with meshout 😞 ~Peach~
                                    drgbdy
                                    Hi all, names Ken... Just dropping by to say hello to everyone.
                                      Hi Ken and welcome (and happy sketching!)
                                        Beagletorque
                                        Hi everybody, just starting out with SketchUp..... Lots of very helpful stuff here, thanks.
                                        Andrew
                                          Hi Andrew,
                                          Enjoy the adventure. Don't be afraid to post if you've difficulties or just want to showoff πŸ˜‰
                                          Word of warning - there's a member called Gaieus who's a bit deranged. No doubt he'll poke his head in at some stage!
                                            Ha! Look who is speaking!
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 72
                                            • 73
                                            • 43 / 73
