    Question: How to convert soft edges to hard edges?
    5 Posts 4 Posters 3.7k Views 4 Watching
    • charly2008C Offline
      charly2008
      Hi to All,
      yesterday, when I read a thread, the idea came to me how can i convert soft edges into hard edges. Any help is welcome.
      Charly
        Individually: with the Shift+Ctrl+Eraser tool.
        Altogether: select all then go to the soften/smooth edges dialog and pull the slider to the left until all turns into hard edges.
          There's also a plugin...,
          http://forums.sketchucation.com/viewtopic.php?t=13645
          That speeds this action up
          • TIGT Online
            @charly2008 said:
            Hi to All,
            Charly
            Erase >> Edge[s] are Deleted
            Erase+Shift >> Hard Edges > Hidden Edges
            Erase+Ctrl >> Hard Edges > Soft Edges
            Erase+Shift+Ctrl >> Soft Edges > Hard Edges
            To turn Hidden Edges > Hard Edges do this: View > Hidden Geometry > 'on' - Select just Edges and in 'Entity Info' un-tick 'Hidden' box.
            You can also remove a selection's 'Soft' and/or 'Smooth' edge settings by un-ticking those boxes in 'Entity Info' too [this is an alternative to using the Erase tool with modifier-keys]
            Also you can pick the 'Smooth/Soften' dialog and set values to 0% then all of the selected edges >> Hard Edges.
              charly2008
              Hi Csaba, Rich and TIG,
              I thank you all for the quick reply. Sometimes you do not see the forest because the trees. I feel like a beginner.
              Charly
