    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 336.6k Views 89 Watching
    • Didier BurD Offline
      Didier Bur
      @pep75: the only thing I can tell is that there is "something" wrong. 😄
      Seriously, please open the ruby console, launch the tool, and copy-paste-post the error message(s) here, so I can figure out what's wrong.
      Or download the version 1.4.2., see top of thread
      DB
      • tpstigersT Offline
        tpstigers
        Top-Down spray works fine. When I try the perpendicular spray, though, I consistently get this error ("This shape is not available yet"):
        “I have an existential map; it has 'you are here' written all over it”
          Didier Bur
          @tpstigers: Perhaps you didn't red the doc: it is said that this experimental tool only works with the point tool and spray shape tool 😉
          DB
            tpstigers
            @didier bur said:
            Thanks. I did read the doc. I guess I should have read it with my brain turned on.
            • Terry
              Ah very cool! 😎
              Thx for the resizable Dialogue box! 👍 👍 👍
              for the next release : does it possible to have 24 #components?
              (it's the 24 possible positions of a "cubic volume")
              If you are interested I have yet the script for generated these components
              (In python for Blender made by zeauro for 2.56 Blender) 😎
              So import these 24 objects in SU from Blender, then run CompoSpray 😄
                Didier Bur
                Je n'ai toujours pas capté de quoi tu parles 😲
                DB
                  Instead of a limited set of combo boxes, why not have a single listbox where you can select multiple list item? And have any selected in SketchUp also appear selected in the dialog when you open it?
                    Didier Bur
                    @TT: as said in the doc: "I could have made multi-select lists, but I didn't because you wouldn't have that possibility to "balance" the amount of each component."
                    Nice idea !
                    DB
                      C'est curieux parce que c'est hyper simple 😄
                      Si j'ai un module cubique (je prends un dé à jouer à 6 faces pour bien figer le concept)
                      Ce dé à 24 positions possibles dans une boîte cubique de sa taille!
                      ça c'est évident 😄
                      Si maintenant avec ton plug, je fais tomber ces 24 cubes dans une colonne à base carrée de la taille du dé, et d'une hauteur quelconque(x*le dé) j'ai une colonne composée de modules superposés de façon aléatoire.
                      Et bien si à la place du dé j'ai un module cubique légèrement plus compliqué, du genre se raccordant sur chaque face mais non symétrique à l'intérieur j'obtiens des métas structures pavant l'espace de manière non périodique! ☀
                      C'est pour cela que j'ai besoin de 24 composants au lieu des 8 actuellement 😄
                      Toute cette bidouille pour simuler ce que je demandais ailleurs, une affection d'une famille de composants (complexes) à un un ensemble de composants "simplex" 😄
                          Didier Bur
                          Say you have filled 3 dropdown lists with component named 'A' and filled the other lists with components 'B' 'C' 'D'.
                          The scripts randowmly selects what component to drop in a list that is, in our case [A,A,A,B,C,D].
                          That's-to-say, component 'A' has three times more chances to be selected than components B,C, and D.
                          A multiselect list would only provide a list in which a component appears once.
                          DB
                            Gotcha!
                            • Z Offline
                              zunkian
                              Hi Didier!
                              First of all, thanks for a cool plugin for SketchUp.
                              Unfortunately, when I am adjusting the dials for altitude, steepness, scale, etc., the dials won't move!
                              It is sort of locked in their position.
                              What do you think is wrong?
                              Andy
                                Didier Bur
                                Several users reported such a weird behaviour of sliders.
                                I'm still wondering why this happens sometimes.
                                Please post here what your OS is, what web browser do you use, what version of Javascript is installed on your machine.
                                Regards,
                                DB
                                  @didier bur said:
                                  Regards,
                                  I have had terrible problems getting consistency with sliders in webdialogs - what slider are you using ? I use 'tigra' [no connection!] and that seems the simplest and robust...
                                  • mitcorbM Offline
                                    mitcorb
                                    I don't see how French kids ever learn to spell 💚
                                    • JClementsJ Offline
                                      JClements
                                      Hi Didier:
                                      Any chance you could add a "Help" button to the toolbar which would open the PDF file?
                                      Regards, John
                                        Didier Bur
                                        Why not, good idea.
                                        @TIG: I'm using a custom slider programmed in js by K. Gilbert http://kegisiteweb.com/presentation.php. It's copyright free but rather old, that's maybe why it freezes under some specific configurations os/web browser/javascript version ?
                                        It is in the JS folder in CompoSpray folder, and I've only added some trivial functions at the end of the file.
                                        DB
                                          gistman
                                          "Plugin downloaded 12179 times" I just wanted to say thank you for all of your work. You and others here have made SU such a great tool.
                                            Mra
                                            Anyone else getting the error "Cannot place component on selection" when it is just a basic ground mesh and assigning using the "point" method?
                                            • 13
                                            • 14
                                            • 5 / 14
