    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 333.3k Views 89 Watching
    • Didier BurD Offline
      Didier Bur
      Charly,
      I don't see any problem here: the face is selected, so the dropdown list contains "selected faces" and "vertices of faces".
      Close the dialog box, unselect all, re-launch compoSpray, it should now display the usual dropdown list , right ?
      charly.swf
      DB
      • charly2008C Offline
        charly2008
        Hi Didier thanks,
        I tried it again, now I have understood it.
        If in the dialog box the component is selected, but no face is selected, than the pull down menu with the shapes is shown.
        If in the dialog box the component is selected and the face is selected than the spray type menu is shown.
        Charly
          charly2008
          Now that I have understood correctly, it excites me to return to the experiment.
          Charly
          Untitled.skp
          • simon le bonS Offline
            simon le bon
            Now I see what it is possible to achieve with Charly, I'm one step more contrite that Compo Spray doesn't work for me 😞
            -s
              Didier Bur
              Patience Simon... je vais publier la v 1.4.2 bientôt.
              With an experimental directional spray:
              DB
                simon le bon
                Ah c'est chouette!!
                et le directional spray va décupler les possibilités. 😄
                (ça mérite la patience 😉 )
                😎 simon
                • pep75P Offline
                  pep75
                  Hey Didier!
                  I really can't get it working...I see the dialog still, I read your manual, pressed Spray but It doensn't do anything....What is wrong?!
                  Thanks!!
                  Grtz
                  Pep
                    Didier Bur
                    @pep75: the only thing I can tell is that there is "something" wrong. 😄
                    Seriously, please open the ruby console, launch the tool, and copy-paste-post the error message(s) here, so I can figure out what's wrong.
                    Or download the version 1.4.2., see top of thread
                    DB
                    • tpstigersT Offline
                      tpstigers
                      Top-Down spray works fine. When I try the perpendicular spray, though, I consistently get this error ("This shape is not available yet"):
                      “I have an existential map; it has 'you are here' written all over it”
                        Didier Bur
                        @tpstigers: Perhaps you didn't red the doc: it is said that this experimental tool only works with the point tool and spray shape tool 😉
                        DB
                          tpstigers
                          @didier bur said:
                          Thanks. I did read the doc. I guess I should have read it with my brain turned on.
                          • Terry
                            Ah very cool! 😎
                            Thx for the resizable Dialogue box! 👍 👍 👍
                            for the next release : does it possible to have 24 #components?
                            (it's the 24 possible positions of a "cubic volume")
                            If you are interested I have yet the script for generated these components
                            (In python for Blender made by zeauro for 2.56 Blender) 😎
                            So import these 24 objects in SU from Blender, then run CompoSpray 😄
                              Didier Bur
                              Je n'ai toujours pas capté de quoi tu parles 😲
                              DB
                                Instead of a limited set of combo boxes, why not have a single listbox where you can select multiple list item? And have any selected in SketchUp also appear selected in the dialog when you open it?
                                  Didier Bur
                                  @TT: as said in the doc: "I could have made multi-select lists, but I didn't because you wouldn't have that possibility to "balance" the amount of each component."
                                  Nice idea !
                                  DB
                                    C'est curieux parce que c'est hyper simple 😄
                                    Si j'ai un module cubique (je prends un dé à jouer à 6 faces pour bien figer le concept)
                                    Ce dé à 24 positions possibles dans une boîte cubique de sa taille!
                                    ça c'est évident 😄
                                    Si maintenant avec ton plug, je fais tomber ces 24 cubes dans une colonne à base carrée de la taille du dé, et d'une hauteur quelconque(x*le dé) j'ai une colonne composée de modules superposés de façon aléatoire.
                                    Et bien si à la place du dé j'ai un module cubique légèrement plus compliqué, du genre se raccordant sur chaque face mais non symétrique à l'intérieur j'obtiens des métas structures pavant l'espace de manière non périodique! ☀
                                    C'est pour cela que j'ai besoin de 24 composants au lieu des 8 actuellement 😄
                                    Toute cette bidouille pour simuler ce que je demandais ailleurs, une affection d'une famille de composants (complexes) à un un ensemble de composants "simplex" 😄
                                        Didier Bur
                                        Say you have filled 3 dropdown lists with component named 'A' and filled the other lists with components 'B' 'C' 'D'.
                                        The scripts randowmly selects what component to drop in a list that is, in our case [A,A,A,B,C,D].
                                        That's-to-say, component 'A' has three times more chances to be selected than components B,C, and D.
                                        A multiselect list would only provide a list in which a component appears once.
                                        DB
                                          Gotcha!
                                          • Z Offline
                                            zunkian
                                            Hi Didier!
                                            First of all, thanks for a cool plugin for SketchUp.
                                            Unfortunately, when I am adjusting the dials for altitude, steepness, scale, etc., the dials won't move!
                                            It is sort of locked in their position.
                                            What do you think is wrong?
                                            Andy
                                            • 13
                                            • 14
                                            • 5 / 14
