    [Plugin] CleanUp
    974 Posts 217 Posters 1.1m Views 217 Watching
      @dave r said:
      Scale up a copy and do whatever it would be that creates the tiny faces. then I just delete the big copy leaving the original where it was and complete.
      Scaling the instance doesn't make a difference, does it? As when you modify you always deal with the source data, the definition - so an instance scaled would (should) mean no difference. ...though SU always surprise me...
        Well, no, it doesn't (or shouldn't) but, well...
        I frequently run into models where someone has drawn something small with it scaled up, made it a component and then scale it down without opening the component. When you bring another copy in from the component library, it is a giant. I generally just wait to make the component until after correcting the size. I guess I could also open the component for editing and scale down the geometry, too.
          Ruturaj
          Thank you sir .......... 😉
          Its very best tool in world .........
          Thanks,
          RuturaJ
          • 3 Offline
            3rdEye
            Hi TomTom,
            first of all:
            Thank you for this plugin, it´s one of my first time favorites!!!
            Anyway, after upgrading to the last released version (also updated TT Lib to the latest), i got the new cleanup dialog somehow messed up when it pos up - does anybody know how to fix this?
            The formatting of the lines is somehow messed up...
              Hover the cursor over the right edge of the dialog box. You'll get a double-headed arrow. Click to grab the edge of the box and move the right edge inward.
              • 3 Offline
                3rdEye
                @dave r said:
                Over the cursor over the right edge of the dialog box. You'll get a double-headed arrow. Click to grab the edge of the box and move the right edge inward.
                Hmm, if I understand u right, I should resize the box - is it what u mean? I tried, but whatever size i make, the messy look stays. The checkboxes and lines and background do not lineup.
                thx for the fast reply!
                  That's odd. If resizing doesn't work, my next inclination would be to close SU and delete the registry entry for WebDialog_TT_CleanUp. then reopen SU and run CleanUp again. It may straighten it out. At least the registry entry will get rewritten. If you want to try that and are unsure of how to do it, drop me a PM.
                  • bagateloB Offline
                    bagatelo
                    Sorry, but it's not working: 😳
                    undefined method `add_group' for #<Sketchup;;Group;0xf18f5d8>
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;969;in `remove_materials'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;967;in `each'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;967;in `remove_materials'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;935;in `merge_similar_materials'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;495;in `cleanup!'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;438;in `show_cleanup_ui'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;160;in `call'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;160;in `initialize'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;143;in `call'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;143;in `close'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;143;in `initialize'
                    I try to clean this component:
                    http://sketchup.google.com/3dwarehouse/details?mid=4d0acb2641fa8dff27170042f46719ed&prevstart=0
                    But it's not working. 😳
                    • 3 Offline
                      3rdEye
                      So we found the issue @ least:
                      If u are using TT_Cleanup make shure u have installed internet explorer 8, else the webdialog menue might not be displayed correctly.
                      thx again for your great plugins, Tom!
                      • bagateloB Offline
                        bagatelo
                        With older version of cleanup:
                          diegog321
                          Thank you:
                          This is the most essential plugin of all.
                          Keep up the good work!
                            @3rdeye said:
                            Hi TomTom,
                            first of all:
                            I'm guessing you are still have IE6 installed? Absolute minimum supported IE is IE7 - but I strongly recommend updating to IE8. (Soon IE9)
                              Ah - you're using SketchUp 6. Seems to be an error in the SU6 spesific code for removing materials. I didn't get around to test that. I'll have a look at it.
                              • bagateloB Offline
                                bagatelo
                                Both my Sketchup and Internet Explorer are Eight!!
                                C:/Program Files (x86)/Google/Google SketchUp 8 >>> (eight)
                                  But you haven't updated to the latest maintenance release, have you? Versions prior to the recent M1 release need to use a workaround to merge materials - which is where the bug lies.
                                    Version 3.1.3
                                    • Fixed bug in merge materials for SketchUp version prior to SU8M1.
                                    • bagateloB Offline
                                      bagatelo
                                      I updated everything.
                                      Do not worry,thomthom. I use the old version. Thanks.
                                        What version does About SketchUp say?
                                        Did you try CleanUp 3.1.3 which I just released a few minutes ago?
                                        • bagateloB Offline
                                          bagatelo
                                          Yes, Sir.
                                            That is not the latest SketchUp version. There is an update to SU8 you are missing.
                                            Btw - 3.1.3 is working now, right?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 48
                                            • 49
                                            • 13 / 49
