    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    How to draw an edge with an angle and distance
    25 Posts 4 Posters 1.8k Views 4 Watching
      @dan rathbun said:
      @TIG: I think hit=rayt[0][0] would return the x coordinate of pt ?
      Yes.
      rayt[0] => Geom::Point3d
      rayt[1] => Array<path of entities>
        You're right - my daft typo... I've corrected the original šŸ˜’
        hit=rayt[1][0]
        • Dan RathbunD Offline
          Dan Rathbun
          When done.. you will need to test the hits array members and retrieve objects that are certain types.
          <span class="syntaxdefault">hit_facesĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā hits</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selectĀ </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">Ā e</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">][</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">instance_of</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)</span><span class="syntaxdefault">Ā </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">hit_compsĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā hits</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select&nbsp;</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">Ā e</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">][</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">instance_of</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance</span><span class="syntaxkeyword">)</span><span class="syntaxdefault">Ā </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">Ā </span>
          ..etc ...
          I'm not here much anymore.
            Dan Rathbun
            Hey you missed my boo-boo I had written hits.each instead of hits.select
            (corrected the code..)
              Dan Rathbun
              morc ... use [ code=php ] and [ /code ] tags around your sourcecode when you post it here.
              I sent you a PrivateMessage, explaining how.
              You are missing 2 end statements at the bottom, just before the **}** closing of the block.
                morci429
                Tig it isn't working.
                guys could u have a look at the code and tell me what do you think?
                require 'sketchup.rb'
                UI.menu("PlugIns").add_item("Fire Arrows") {
                ents = Sketchup.active_model.entities
                Sketchup.active_model.selection.each do |e|
                if e.is_a? Sketchup;;Face
                ce=e.bounds.center
                en=ce.offset(e.normal, 100000.mm)
                cl90=ents.add_cline(ce, en)   #a vertical line
                tr=Geom;;Transformation.rotation(ce, Z_AXIS, 45.degrees)
                en.transform!(tr)
                cl45=ents.add_line(ce, en)   #a 45 deg line
                vec=ce.vector_to(en)
                dist=ce.distance(en)
                hits=[]
                pt = Geom;;Point3d.new
                pe=ce.clone ### set up a copy of the point to raytest from
                goon=true
                while goon
                  rayt= Sketchup.active_model.raytest(pe, vec)
                  goon=false if not rayt
                  pt=rayt[0]
                  hit=rayt[1][0]
                  goon=false if ce.distance(pt) > dist
                  hits << [pt, hit]
                  pe=pt ### look from last hit point...
                end#while
                hits.each do |s|
                if s[1][0].is_a? Sketchup;;Face
                hit_face = s.bounds
                zmin = hit_face.min.z
                zmax = hit_face.max.z
                h = zmax - zmin
                h = h.to_m
                UI.messagebox s[1][0]
                UI.messagebox h
                tr=Geom;;Transformation.rotation(ce, Z_AXIS, -90.degrees)
                en.transform!(tr)
                cl135=ents.add_cline(ce, en)  #a 135 deg line
                #en=ce.offset(Z_AXIS, 5000.mm)
                #tr=Geom;;Transformation.rotation(ce, X_AXIS, -45.degrees)
                #en.transform!(tr)
                #cl135=ents.add_cline(ce, en)  #a 135 deg line
                #tr=Geom;;Transformation.rotation(ce, X_AXIS, 90.degrees)
                #en.transform!(tr)
                Thanks Dan,
                i added the two end statements. but the complier doesn't like line 31 ]
                pt=rayt[0]
                thanks again Dan
                  Error messages?
                  Unexpected behaviour?
                  It always help to be specific to what isn't working.
                    morci429
                    Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:31 C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:7:in each'
                    C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:3:in `call'
                    Sorry if i wasn't clear enough
                      Try adding a test after the goon=false if not rayt like
                      next if not rayt that way it will jump.
                      I notice that your 'line' creation is a bit muddled - you a make one then transform the end_point [en] BUT doing so around the Z_AXIS leaves it where it is - do it around the X_AXIS or Y_AXIS...
                        Dan Rathbun
                        morc..
                        EDIT:The problem is that the API doc does not say that if the ray does not hit anything, the raytest method just returns nil.
                        If you read the API for Model.raytest(), you'll see that the first argument must be an Array; the second optional argument (added in SU8.0M1,) is the wysiwyg_flag that sets whether to hit hidden geometry.
                        EDIT:Actually the method is smart enough to know what you mean... you don't really need an Array arg, unless you want to use the wysiwyg_flag %(#BF4000)[argument.
                        So you can to call it this way:]
                        rayt= Sketchup.active_model.raytest( **[**pe, vec**]** )
                          morci429
                          ...*[snip]*... reposted [in later post](http://forums.sketchucation.com/viewtopic.php?f)
                            Dan Rathbun
                            Added a note at the bottom of the API doc page for Model.raytest() informing readers of the nil return value, when no geometry is "hit."
                              morci429
                              guys i think you are right, the hits array is empty. the ray isn't hitting any geometry. Still trying to find out why though
                                Rather than start with convoluted code try a simple 'one-liner' pasted into the Ruby Console...
                                Draw two rectangular faces place them one above the other, above the origin.
                                rt=true;p=ORIGIN;while rt;p rt=Sketchup.active_model.raytest(p,Z_AXIS);p=rt[0]if rt;end
                                it should produce something like this
                                [Point3d(0, 0, 16.9685), [#<Sketchup::Face:0xbea3ae8>]] [Point3d(0, 0, 39.3701), [#<Sketchup::Face:0xbea3ad4>]] nil
                                NOW you know it's working........
                                  morci429
                                  Mission accomplished
                                  Thanks to you all Geniuses
                                  • 2 / 2
