    How to draw an edge with an angle and distance
    25 Posts 4 Posters 2.3k Views 4 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @morci429 said:
      i looked at the links and i still can't see how can i specify an angle
      Sorry, I left out the link to Geom::Transformation class,
      ... and TIG showed how to use it (above,)
      EDIT. (TIG had it right,) Disregard this:except that the second tranform should be -45.degrees (not -90.degrees,) so you have an angle 135 degrees off the face's plane.
      @morci429 said:
      P.S i don't know the coordinates of the point the arrow going to stop at
      After you transform the end points, you can save the en var and you have the end points, OR you also have vars referencing the new clines.
      You can get the endpoints using the .end() instance method for Sketchup::ConstructionLine class, ie:
      ep45 = cl45.end
      I'm not here much anymore.
        morci429
        Thank you so much guys I’m starting to feel like you are magicians 😄
          morci429
          Guys sorry i don't mean to be pushy, put after i fired the arrow from centroid I’m looking for a built in function in either add_cline or even add_line to retrieve all the faces that intersect with my line.
            @morci429 said:
            Guys sorry i don't mean to be pushy, but after i fired the arrow from centroid I’m looking for a built in function in either add_cline or even add_line to retrieve all the faces that intersect with my line.
            At each step as you add the 'line' you have two points ' ce' and ' en', the vector ' vec=ce.vector_to(en)' returns the 'arrow'.
            Now ' dist=ce.distance(en)' will help us keep track of how far we are going from ' ce'
            New use a 'raytest' to find the intersections...
            <span class="syntaxdefault">hits</span><span class="syntaxkeyword">=[]<br /></span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">ce</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">clone </span><span class="syntaxcomment">### set up a copy of the point to raytest from<br /></span><span class="syntaxdefault">goon</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">true<br />while goon<br />  rayt</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">raytest</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> vec</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  goon</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">false if not rayt<br />  pt</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">rayt</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  hit</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">rayt</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">][</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  goon</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">false if ce</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">distance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> dist<br />  hits </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> hit</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  pe</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pt </span><span class="syntaxcomment">### look from last hit point...<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#while<br /></span><span class="syntaxdefault"> </span>
            ' hits' is an array of arrays of the points and what was hit at each one...
            Repeat this for each 'ray' you are making.
            If you want to find ALL intersections forget the ' dist' test...
              @dan rathbun said:
              @TIG: I think hit=rayt[0][0] would return the x coordinate of pt ?
              Yes.
              rayt[0] => Geom::Point3d
              rayt[1] => Array<path of entities>
                You're right - my daft typo... I've corrected the original 😒
                hit=rayt[1][0]
                  Dan Rathbun
                  When done.. you will need to test the hits array members and retrieve objects that are certain types.
                  <span class="syntaxdefault">hit_faces </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> hits</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">][</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">instance_of</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">hit_comps </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> hits</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select&nbsp;</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">][</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">instance_of</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}</span><span class="syntaxdefault"> </span>
                  ..etc ...
                    Dan Rathbun
                    Hey you missed my boo-boo I had written hits.each instead of hits.select
                    (corrected the code..)
                      Dan Rathbun
                      morc ... use [ code=php ] and [ /code ] tags around your sourcecode when you post it here.
                      I sent you a PrivateMessage, explaining how.
                      You are missing 2 end statements at the bottom, just before the **}** closing of the block.
                        morci429
                        Tig it isn't working.
                        guys could u have a look at the code and tell me what do you think?
                        require 'sketchup.rb'
                        UI.menu("PlugIns").add_item("Fire Arrows") {
                        ents = Sketchup.active_model.entities
                        Sketchup.active_model.selection.each do |e|
                        if e.is_a? Sketchup;;Face
                        ce=e.bounds.center
                        en=ce.offset(e.normal, 100000.mm)
                        cl90=ents.add_cline(ce, en)   #a vertical line
                        tr=Geom;;Transformation.rotation(ce, Z_AXIS, 45.degrees)
                        en.transform!(tr)
                        cl45=ents.add_line(ce, en)   #a 45 deg line
                        hits=[]
                        pt = Geom;;Point3d.new
                        pe=ce.clone ### set up a copy of the point to raytest from
                        goon=true
                        while goon
                          rayt= Sketchup.active_model.raytest(pe, vec)
                          goon=false if not rayt
                          pt=rayt[0]
                          hit=rayt[1][0]
                          goon=false if ce.distance(pt) > dist
                          hits << [pt, hit]
                          pe=pt ### look from last hit point...
                        end#while
                        hits.each do |s|
                        if s[1][0].is_a? Sketchup;;Face
                        hit_face = s.bounds
                        zmin = hit_face.min.z
                        zmax = hit_face.max.z
                        h = zmax - zmin
                        h = h.to_m
                        UI.messagebox s[1][0]
                        UI.messagebox h
                        tr=Geom;;Transformation.rotation(ce, Z_AXIS, -90.degrees)
                        en.transform!(tr)
                        cl135=ents.add_cline(ce, en)  #a 135 deg line
                        #en=ce.offset(Z_AXIS, 5000.mm)
                        #tr=Geom;;Transformation.rotation(ce, X_AXIS, -45.degrees)
                        #en.transform!(tr)
                        #cl135=ents.add_cline(ce, en)  #a 135 deg line
                        #tr=Geom;;Transformation.rotation(ce, X_AXIS, 90.degrees)
                        #en.transform!(tr)
                        Thanks Dan,
                        i added the two end statements. but the complier doesn't like line 31 ]
                        pt=rayt[0]
                        thanks again Dan
                          Error messages?
                          Unexpected behaviour?
                          It always help to be specific to what isn't working.
                            morci429
                            Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:31 C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:7:in each'
                            C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:3:in `call'
                            Sorry if i wasn't clear enough
                              Try adding a test after the goon=false if not rayt like
                              next if not rayt that way it will jump.
                              I notice that your 'line' creation is a bit muddled - you a make one then transform the end_point [en] BUT doing so around the Z_AXIS leaves it where it is - do it around the X_AXIS or Y_AXIS...
                                Dan Rathbun
                                morc..
                                EDIT:The problem is that the API doc does not say that if the ray does not hit anything, the raytest method just returns nil.
                                If you read the API for Model.raytest(), you'll see that the first argument must be an Array; the second optional argument (added in SU8.0M1,) is the wysiwyg_flag that sets whether to hit hidden geometry.
                                EDIT:Actually the method is smart enough to know what you mean... you don't really need an Array arg, unless you want to use the wysiwyg_flag %(#BF4000)[argument.
                                So you can to call it this way:]
                                rayt= Sketchup.active_model.raytest( **[**pe, vec**]** )
                                  morci429
                                  ...*[snip]*... reposted [in later post](http://forums.sketchucation.com/viewtopic.php?f)
                                    Dan Rathbun
                                    Added a note at the bottom of the API doc page for Model.raytest() informing readers of the nil return value, when no geometry is "hit."
                                      morci429
                                      guys i think you are right, the hits array is empty. the ray isn't hitting any geometry. Still trying to find out why though
                                        Rather than start with convoluted code try a simple 'one-liner' pasted into the Ruby Console...
                                        Draw two rectangular faces place them one above the other, above the origin.
                                        rt=true;p=ORIGIN;while rt;p rt=Sketchup.active_model.raytest(p,Z_AXIS);p=rt[0]if rt;end
                                        it should produce something like this
                                        [Point3d(0, 0, 16.9685), [#<Sketchup::Face:0xbea3ae8>]] [Point3d(0, 0, 39.3701), [#<Sketchup::Face:0xbea3ad4>]] nil
                                        NOW you know it's working........
                                          morci429
                                          Mission accomplished
                                          Thanks to you all Geniuses
