    How to draw an edge with an angle and distance
    25 Posts 4 Posters 2.9k Views 4 Watching
      morci429
      Guys sorry i don't mean to be pushy, put after i fired the arrow from centroid I’m looking for a built in function in either add_cline or even add_line to retrieve all the faces that intersect with my line.
        @morci429 said:
        Guys sorry i don't mean to be pushy, but after i fired the arrow from centroid I’m looking for a built in function in either add_cline or even add_line to retrieve all the faces that intersect with my line.
        At each step as you add the 'line' you have two points ' ce' and ' en', the vector ' vec=ce.vector_to(en)' returns the 'arrow'.
        Now ' dist=ce.distance(en)' will help us keep track of how far we are going from ' ce'
        New use a 'raytest' to find the intersections...
        <span class="syntaxdefault">hits</span><span class="syntaxkeyword">=[]<br /></span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">ce</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">clone </span><span class="syntaxcomment">### set up a copy of the point to raytest from<br /></span><span class="syntaxdefault">goon</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">true<br />while goon<br />  rayt</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">raytest</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> vec</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  goon</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">false if not rayt<br />  pt</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">rayt</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  hit</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">rayt</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">][</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  goon</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">false if ce</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">distance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> dist<br />  hits </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> hit</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  pe</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pt </span><span class="syntaxcomment">### look from last hit point...<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#while<br /></span><span class="syntaxdefault"> </span>
        ' hits' is an array of arrays of the points and what was hit at each one...
        Repeat this for each 'ray' you are making.
        If you want to find ALL intersections forget the ' dist' test...
          @dan rathbun said:
          @TIG: I think hit=rayt[0][0] would return the x coordinate of pt ?
          Yes.
          rayt[0] => Geom::Point3d
          rayt[1] => Array<path of entities>
            You're right - my daft typo... I've corrected the original 😒
            hit=rayt[1][0]
            • Dan RathbunD
              Dan Rathbun
              When done.. you will need to test the hits array members and retrieve objects that are certain types.
              <span class="syntaxdefault">hit_faces </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> hits</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">][</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">instance_of</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">hit_comps </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> hits</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select&nbsp;</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">][</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">instance_of</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}</span><span class="syntaxdefault"> </span>
              ..etc ...
              I'm not here much anymore.
              • Dan RathbunD
                Dan Rathbun
                Hey you missed my boo-boo I had written hits.each instead of hits.select
                (corrected the code..)
                • Dan RathbunD
                  Dan Rathbun
                  morc ... use [ code=php ] and [ /code ] tags around your sourcecode when you post it here.
                  I sent you a PrivateMessage, explaining how.
                  You are missing 2 end statements at the bottom, just before the **}** closing of the block.
                    morci429
                    Tig it isn't working.
                    guys could u have a look at the code and tell me what do you think?
                    require 'sketchup.rb'
                    UI.menu("PlugIns").add_item("Fire Arrows") {
                    ents = Sketchup.active_model.entities
                    Sketchup.active_model.selection.each do |e|
                    if e.is_a? Sketchup;;Face
                    ce=e.bounds.center
                    en=ce.offset(e.normal, 100000.mm)
                    cl90=ents.add_cline(ce, en)   #a vertical line
                    tr=Geom;;Transformation.rotation(ce, Z_AXIS, 45.degrees)
                    en.transform!(tr)
                    cl45=ents.add_line(ce, en)   #a 45 deg line
                    hits=[]
                    pt = Geom;;Point3d.new
                    pe=ce.clone ### set up a copy of the point to raytest from
                    goon=true
                    while goon
                      rayt= Sketchup.active_model.raytest(pe, vec)
                      goon=false if not rayt
                      pt=rayt[0]
                      hit=rayt[1][0]
                      goon=false if ce.distance(pt) > dist
                      hits << [pt, hit]
                      pe=pt ### look from last hit point...
                    end#while
                    hits.each do |s|
                    if s[1][0].is_a? Sketchup;;Face
                    hit_face = s.bounds
                    zmin = hit_face.min.z
                    zmax = hit_face.max.z
                    h = zmax - zmin
                    h = h.to_m
                    UI.messagebox s[1][0]
                    UI.messagebox h
                    tr=Geom;;Transformation.rotation(ce, Z_AXIS, -90.degrees)
                    en.transform!(tr)
                    cl135=ents.add_cline(ce, en)  #a 135 deg line
                    #en=ce.offset(Z_AXIS, 5000.mm)
                    #tr=Geom;;Transformation.rotation(ce, X_AXIS, -45.degrees)
                    #en.transform!(tr)
                    #cl135=ents.add_cline(ce, en)  #a 135 deg line
                    #tr=Geom;;Transformation.rotation(ce, X_AXIS, 90.degrees)
                    #en.transform!(tr)
                    Thanks Dan,
                    i added the two end statements. but the complier doesn't like line 31 ]
                    pt=rayt[0]
                    thanks again Dan
                      Error messages?
                      Unexpected behaviour?
                      It always help to be specific to what isn't working.
                        morci429
                        Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:31 C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:7:in each'
                        C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:3:in `call'
                        Sorry if i wasn't clear enough
                          Try adding a test after the goon=false if not rayt like
                          next if not rayt that way it will jump.
                          I notice that your 'line' creation is a bit muddled - you a make one then transform the end_point [en] BUT doing so around the Z_AXIS leaves it where it is - do it around the X_AXIS or Y_AXIS...
                          • Dan RathbunD
                            Dan Rathbun
                            morc..
                            EDIT:The problem is that the API doc does not say that if the ray does not hit anything, the raytest method just returns nil.
                            If you read the API for Model.raytest(), you'll see that the first argument must be an Array; the second optional argument (added in SU8.0M1,) is the wysiwyg_flag that sets whether to hit hidden geometry.
                            EDIT:Actually the method is smart enough to know what you mean... you don't really need an Array arg, unless you want to use the wysiwyg_flag %(#BF4000)[argument.
                            So you can to call it this way:]
                            rayt= Sketchup.active_model.raytest( **[**pe, vec**]** )
                              morci429
                              ...*[snip]*... reposted [in later post](http://forums.sketchucation.com/viewtopic.php?f)
                              • Dan RathbunD
                                Dan Rathbun
                                Added a note at the bottom of the API doc page for Model.raytest() informing readers of the nil return value, when no geometry is "hit."
                                  morci429
                                  guys i think you are right, the hits array is empty. the ray isn't hitting any geometry. Still trying to find out why though
                                    Rather than start with convoluted code try a simple 'one-liner' pasted into the Ruby Console...
                                    Draw two rectangular faces place them one above the other, above the origin.
                                    rt=true;p=ORIGIN;while rt;p rt=Sketchup.active_model.raytest(p,Z_AXIS);p=rt[0]if rt;end
                                    it should produce something like this
                                    [Point3d(0, 0, 16.9685), [#<Sketchup::Face:0xbea3ae8>]] [Point3d(0, 0, 39.3701), [#<Sketchup::Face:0xbea3ad4>]] nil
                                    NOW you know it's working........
                                      morci429
                                      Mission accomplished
                                      Thanks to you all Geniuses
