    How to draw an edge with an angle and distance
    25 Posts 4 Posters 3.4k Views 4 Watching
      You're right - my daft typo... I've corrected the original šŸ˜’
      hit=rayt[1][0]
      • Dan RathbunD
        Dan Rathbun
        When done.. you will need to test the hits array members and retrieve objects that are certain types.
        <span class="syntaxdefault">hit_facesĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā hits</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selectĀ </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">Ā e</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">][</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">instance_of</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)</span><span class="syntaxdefault">Ā </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">hit_compsĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā hits</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select&nbsp;</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">Ā e</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">][</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">instance_of</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance</span><span class="syntaxkeyword">)</span><span class="syntaxdefault">Ā </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">Ā </span>
        ..etc ...
        @TIG: I think hit=rayt[0][0] would return the x coordinate of pt ?
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          Hey you missed my boo-boo I had written hits.each instead of hits.select
          (corrected the code..)
          • Dan RathbunD
            Dan Rathbun
            morc ... use [ code=php ] and [ /code ] tags around your sourcecode when you post it here.
            I sent you a PrivateMessage, explaining how.
            You are missing 2 end statements at the bottom, just before the **}** closing of the block.
              morci429
              Tig it isn't working.
              guys could u have a look at the code and tell me what do you think?
              require 'sketchup.rb'
              UI.menu("PlugIns").add_item("Fire Arrows") {
              ents = Sketchup.active_model.entities
              Sketchup.active_model.selection.each do |e|
              if e.is_a? Sketchup;;Face
              ce=e.bounds.center
              en=ce.offset(e.normal, 100000.mm)
              cl90=ents.add_cline(ce, en)   #a vertical line
              tr=Geom;;Transformation.rotation(ce, Z_AXIS, 45.degrees)
              en.transform!(tr)
              cl45=ents.add_line(ce, en)   #a 45 deg line
              vec=ce.vector_to(en)
              dist=ce.distance(en)
              hits=[]
              pt = Geom;;Point3d.new
              pe=ce.clone ### set up a copy of the point to raytest from
              goon=true
              while goon
                rayt= Sketchup.active_model.raytest(pe, vec)
                goon=false if not rayt
                pt=rayt[0]
                hit=rayt[1][0]
                goon=false if ce.distance(pt) > dist
                hits << [pt, hit]
                pe=pt ### look from last hit point...
              end#while
              hits.each do |s|
              if s[1][0].is_a? Sketchup;;Face
              hit_face = s.bounds
              zmin = hit_face.min.z
              zmax = hit_face.max.z
              h = zmax - zmin
              h = h.to_m
              UI.messagebox s[1][0]
              UI.messagebox h
              tr=Geom;;Transformation.rotation(ce, Z_AXIS, -90.degrees)
              en.transform!(tr)
              cl135=ents.add_cline(ce, en)  #a 135 deg line
              #en=ce.offset(Z_AXIS, 5000.mm)
              #tr=Geom;;Transformation.rotation(ce, X_AXIS, -45.degrees)
              #en.transform!(tr)
              #cl135=ents.add_cline(ce, en)  #a 135 deg line
              #tr=Geom;;Transformation.rotation(ce, X_AXIS, 90.degrees)
              #en.transform!(tr)
              Thanks Dan,
              i added the two end statements. but the complier doesn't like line 31 ]
              pt=rayt[0]
              thanks again Dan
                Error messages?
                Unexpected behaviour?
                It always help to be specific to what isn't working.
                  morci429
                  Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:31 C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:7:in each'
                  C:/PROGRA~1/Google/GOOGLE~3/Plugins/Fire Arrows.rb:3:in `call'
                  Sorry if i wasn't clear enough
                    Try adding a test after the goon=false if not rayt like
                    next if not rayt that way it will jump.
                    I notice that your 'line' creation is a bit muddled - you a make one then transform the end_point [en] BUT doing so around the Z_AXIS leaves it where it is - do it around the X_AXIS or Y_AXIS...
                    • Dan RathbunD
                      Dan Rathbun
                      morc..
                      EDIT:The problem is that the API doc does not say that if the ray does not hit anything, the raytest method just returns nil.
                      If you read the API for Model.raytest(), you'll see that the first argument must be an Array; the second optional argument (added in SU8.0M1,) is the wysiwyg_flag that sets whether to hit hidden geometry.
                      EDIT:Actually the method is smart enough to know what you mean... you don't really need an Array arg, unless you want to use the wysiwyg_flag %(#BF4000)[argument.
                      So you can to call it this way:]
                      rayt= Sketchup.active_model.raytest( **[**pe, vec**]** )
                        morci429
                        ...*[snip]*... reposted [in later post](http://forums.sketchucation.com/viewtopic.php?f)
                        • Dan RathbunD
                          Dan Rathbun
                          Added a note at the bottom of the API doc page for Model.raytest() informing readers of the nil return value, when no geometry is "hit."
                            morci429
                            guys i think you are right, the hits array is empty. the ray isn't hitting any geometry. Still trying to find out why though
                              Rather than start with convoluted code try a simple 'one-liner' pasted into the Ruby Console...
                              Draw two rectangular faces place them one above the other, above the origin.
                              rt=true;p=ORIGIN;while rt;p rt=Sketchup.active_model.raytest(p,Z_AXIS);p=rt[0]if rt;end
                              it should produce something like this
                              [Point3d(0, 0, 16.9685), [#<Sketchup::Face:0xbea3ae8>]] [Point3d(0, 0, 39.3701), [#<Sketchup::Face:0xbea3ad4>]] nil
                              NOW you know it's working........
                                morci429
                                Mission accomplished
                                Thanks to you all Geniuses
                                With your input, this post could be even better šŸ’—
                                • 2 / 2
