    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.4m Views 329 Watching
      John,
      Is the line you are selecting part of the group? If so, that would explain the message. The line must be outside the group for it to work.
      @N08/5126930295/" target="_blank" rel="noopener noreferrer nofollow ugc">
      http://farm5.static.flickr.com/4067/5126930295_1fe489e2ba.jpg
      In this image the line is being selected. The component to be bent is above it.
      • C
        clovis
        the line is outside the group .
        Mostly sketchup tells me [ please select a line that is on the red axis ]
        what may i do ??
        • C
          clovis
          and it does not work even if my line is on the red axis ...
            You need three things to use the tool
            A Group or Component-instance.
            A Line drawn along the red-axis to determine the extent of the actions.
            A Curve [e.g. an Arc] - this is often drawn to have similar extents as the Line [but not necessarily].
            Preselect the Group/Component.
            Run the tool and follow the prompts.
            Pick the Line.
            Pick the Curve.
              TIG beat me to it. Can you post a screen shot of what you're trying to do?
              • C
                clovis
                Pick the Line.
                Pick the Curve.
                Toggle the 'Ends' using the Arrow-Keys etc as prompted etc...[attachment=0:rnii52fu]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:rnii52fu]
                I EXACTLY DO AS YOU SHOW ... but Can t select the "lone line on the red axis" , as sketchup does not notice it .. always the same error message
                I might try to re instal the plug in ...
                  The Lone Line on the Red Axis must be exactly that.
                  It cannot be connected to other things ???
                  The cursor changes to a ___ to show it needs a line...
                  • Chris FullmerC
                    Also, it only works on the original red axis. So if you have changed your world axis, you will need to reset it. To do this, right click on one of the axis lines and choose "Reset". That should re-align it to the world axis. Perhaps that is cause of the problems. Let us know how it goes. Also, if none of this works, you can also upload your model, or a small portion of it here so we can test it. Thanks!
                    • GaieusG
                      I think the best is to use this plugin in and "empty" file. f you make a component of what you want to bend then align the component axes according how the plugin should work then you can right click > save as... and open the new file, you can experiment without any risk then when done, in the original model, right click again and "reload".
                        madib
                        I have a question about installing shape bender on my computer. I copied the .rb and the folder into my plugin folder. Now that I start sketch up it gives me the error: Error Loading File clf_shape_bender_loader.rb
                        No such file to load -- progressbar.rb
                        how can I fix that?
                        cheers
                          how can I fix that?
                          cheers
                          The download page explains that you need to get that separately - ~6 lines down http://forums.sketchucation.com/viewtopic.php?p=147395#p147395
                          It's free from Smustard.com.
                          Put it into Plugins and restart... 😉
                          • C
                            clovis
                            YEP it works .... in fact , just needed an empty file ... @ Chris F. : i think the axis were changed , that was my problem !
                            Thanks for your help dudes!!!
                              Angelwing
                              Hi Guys typical that a first post is a question
                              Can anyone tell me in simple terms how to install Shape Bender on a Mac.
                              I have previously installed make faces 1.4 and that seemed easy although I cant find where it is installed now either 😳
                              Andy
                                Andy
                                It's pretty much the same as on a PC!
                                Type/Copy+Paste this into the Window > Ruby Console Sketchup.find_support_file("Plugins") it returns the correct folder into which you should put any scripts etc.
                                Download the 'clf_shape_bender_v055.ZIP' file linked in the first post.
                                Extract the contents of the ZIP to a temporary location.
                                A good Unzip tool will ask and put the contents into a folder - perhaps on your Desktop - [usually named after the ZIP file's name - 'clf_shape_bender_v055'].
                                That folder should contain a script clf_shape_bender_loader.rb and a folder [clf_shape_bender] containing several support files [the main '.rb' file and several '.png' image files for the toolbar buttons etc].
                                Move/Copy the separate .rb file and the folder into the ../Plugins/ folder, overwriting anything already there.
                                Do NOT take any of the files out of the subfolder or think to put them into ../Plugins/ - it will break just things !
                                IF you might have moved files out of that subfolder then I suggest that you check the contents of the ../Plugins/ folder against the contents of that subfolder and remove the incorrectly located ones from ../Plugins/.......
                                • L
                                  leminilab
                                  Hi everyone,
                                  I'm trying to model this kind of paper walls :
                                  So I modeled the oval component (because I'm so good at modeling 🤣) but now I'm trying to make the bend and as you can see I haven't been very succesful at it using shape bender so far... 😒
                                  So my question is : Can anyone help me? 😄
                                  Thank you so much for reding this!
                                  Nicolas
                                  • "Live every day as if it were your last and then some day you'll be right."
                                  • "ThomThom rules!!!"
                                  • L
                                    leminilab
                                    Copy along path power!
                                    I'll leave the message anyway in case it may help a noob like me someday (I like to think I'm not the only one to ask doh questions 😄)!
                                    Thanks a lot for everything!
                                    Nicolas
                                      DeltaCommando5
                                      I've installed the progressbar.rb and the bender tool, and it's not showing up in the plugins menu. Why?
                                        Did you tick the Shape Bender box under Window>Preferences>Extensions?
                                        • mitcorbM
                                          mitcorb
                                          Out of curiosity, what work is left to be done for Shape Bender to move out of Beta designation?
                                          EDIT: I retract my question. I just noticed in the first post the answer.
                                            DeltaCommando5
                                            Ya, it's checked. Still nothing.
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 63
                                            • 64
                                            • 35 / 64
