    [Plugin] Multi face offset
    49 Posts 15 Posters 70.7k Views 15 Watching
    • pep75P
      pep75
      IT'S WORKING! Thank you!!! But the offset.rb and the multioffset.rb that can be downloaded from this topic are different than the ones you've send....strange huh?
      Nevertheless thank you!!
      Grtz and a happy new year!
      Pep
        I have tweaked the code slightly over time BUT they should still be the same basic functions ? πŸ˜‰
        • G
          gariglianot
          Hi guys, I know I'm poking into a discussion that is already 4 years old, but, il seems I have the same problem that pep 75 had... i have both multifaceoffset.rb and offset.rb, but gives me the same error message, and doesnt offset... could TIG perhaps post the scripts that he sent to pep75 that where working? I need it!!!!! thanxxx
            Here they are...OffestTools.zip
              Avex
              Hi all
              I have a question, how can I get a rounded offset?
              For doing something like that --->
              • olisheaO
                olishea
                good question!!
                This is a great plugin. I know a simple way to improve it.
                After the plugin has executed the offsets....it should prompt the option:
                "Keep the offset face selected=1 Keep original faces selected = 0" (as in yes/no)
                Is this possible? It would allow JPP/scale (for example) immediately on offset faces, without having to select them all manually. Wings 3D has a similar feature with its multiple offset feature.
                Or a plugin to select inverse faces of a mesh? ❓
                oli
                  And about the round Plugin from a Polygon above?
                  And there from the selection of all polygons because make one by one is a little tiedous πŸ˜„
                  • olisheaO
                    olishea
                    I have a little difficulty understanding what you mean, Pilou.
                    oli
                      VoronoΓ― XY By Mattc
                      http://www.3dsaloon.fr/phpbb3/download/file.php?id=3666
                      Say I have that πŸ˜„
                      But now how to "round" the polygons as asked 2 posts above by Avex 2 years ago? πŸ˜‰
                      • olisheaO
                        olishea
                        Ahhhh.
                        I would happily pay for a Voronoi TOS style plugin.
                        Why not multiple offset and then Artisan? edit, maybe it's not so "true" though.
                        oli
                        • P
                          parkmancarter
                          I have the plugin working in SU8Pro, but only have the option to set the offset distance. What about all the other wild (and potentially very useful) options that appear in this video?
                          The ability to keep faces or not, to do a sequence of offsets, etc... is this a different plugin??
                            Multiple Offsets (list etc...) is by Sdmitch πŸ˜‰
                            • 3 / 3
